Question about B&K AVR-507 Receiver
B&k avr-307 7.1 receiver
The left and right channels on the B&K will not work,all the rest are fine.Could it be the fuses ?If so,How can I determine which ones ?They seem to have a spring-load design.Thanks.
4 Suggested Answers
  • 3 Answers
SOURCE: Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
Posted on Feb 28, 2009
  • 62 Answers
SOURCE: Need Value of Receiver and Comparible replacement
it the fuses y it not working replace the fuses !
Posted on Jun 10, 2010
  • 62 Answers
SOURCE: How much is the AVR-307 worth? What would is a
about 200.00-300.00 in the market place !
I have lost all sound from my left front speaker on my AVR 135 They are Bose spreakers The system is 13 years old. Is it woorth fixing?
anything that works well is always worth investigating for a repair
it could be a simple fuse for that side amplifier, loose , broken speaker wire
have it checked out and then decide if it is worth repairing
Sep 25, 2016 | Harmon Kardon Harman/kardon Avr 130 5.1...
Only left channel working on avr 1912
Sounds like a possible amp problem. Probably needs to go in for repairs.
Jan 07, 2013 | Denon Avr-1912 Home Theater Av Receiver...
There is no sound from left speaker
The audio output stage on the left channel has failed or blown a fuse. Check the speaker wires carefully, if okay! I recommend a pro to examine the receiver.
Apr 08, 2012 | Harman Kardon AVR 225 Receiver
Jun 07, 2010 | B&K AVR-307 Receiver
I have a Harman/Kardon AVR 325. Left speaker not working with TV
How is TV audio (from the cable box) getting into the Receiver? If digitally, you wouldn't be missing any one channel on a connection malfunction, you'd lose them all. If analog, swap the channels around to isolate the problem (and reconsider using digital).
Feb 11, 2010 | Onkyo HTR500 Receiver
The left channel on my denon avr-1507 no longer works. The speaker tests out fine. Is there a fuse that can be swapped for this or some other easy fix?
there are no speakers fuses on this model it only shows relays so your probable couse is your left channel went bad specially if you like to play it loud and for long periods of time ( I recomend that you have it repaired by a profesional ) good lock ,, I have the service manual in case you need it
Dec 16, 2009 | Denon AVR-1507 Receiver
Denon 1906 all the right channels speakers not working
when turn on the amp,the volumn cannot under control
Oct 10, 2009 | Denon AVR-1906 Receiver
Denon AVR-1507 No sound on left front channel
Because the sound is only faint says to me that the power amp that controls the left channel is faulty. You need to look at the device(s) on the heatsink and probably replace them.
Dec 28, 2017 | Denon AVR-1507 Receiver
Left channel not working
The first thing I would check has already been done, the only other thing would be fuses. I am preety sure there is a protection fuse at ever channels output to protect against a dead short. I am sure you have already fixed this problem but I thought I would give it a try. Let me know what you found.
Jul 13, 2008 | Denon AVR-3802 Receiver
B&K AVR-507 Receiver Logo
126 people viewed this question
Top B&K Audio Players & Recorders Experts
shaun taylor
Jerry Greenberg
Jerry Greenberg
Are you a B&K Audio Player and Recorder Expert? Answer questions, earn points and help others
