Back to:
Tags:
HP Photosmart 3210 Printer
HP Photosmart 3210 Problem??
posted by wwpauljd on Jun 26, 2008
The problem with the HP Photosmart3210 didn't go away after I did everything you said.........=(
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 27, 2008
Not Rated (0)
scott gibson
Rank:Wiz Wiz
Rating: 81%, 17 votes
i'm a bit in the dark, need more info
1st does the printer power up.
2 have you had your printer perform a nozzle check
3 have you had your printer perform a nozzle cleaning
4 are you trying to use your old ink cartrige if so stop get a new one.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on HP Photosmart 3210 Problem??:
I don't want to Accept this solution
Can you Help with these Printers problems?
Strikes on blue and light blue box when performing a...
I'm using standard 8.5 x 11 paper but coppier error states...
i'm losing a bunch of lines between printed pages of what...
and previous installations cease to function. Also, the...
do you have something for a scanner to work on a mac?
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
