Question about SanDisk Audio Players & Recorders
Computer will not dispay sandisk, mp3 player will not go past sandisk screen
  • 8,596 Answers
Reset the player first. If it keeps going to that screen, try a different usb port. Then download the Sansa Recovery Tool from the Sandisk website. If Recovery fails to resolve, then do a firmware upgrade.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 26, 2008
OK PEOPLE!! have asked this same question over and...am getting the run around...please don't make me continue asking for help with this question. its a sandisk mp3 mini clip, and this issue is getting any...
Use SanDisk MP3 Players
SanDisk is an electronic device manufacturer that creates various types of MP3 players under the SanDisk Sansa product line.
The SanDisk MP3 players range in storage capacity, starting at 512mb, and are intended to operate on the Windows operating system.
Most SanDisk MP3 players also include a built-in video player with a color screen, an FM radio tuner, and a memory flash card slot to expand the MP3 player's storage capacity.
Use SanDisk MP3 players to take your computer's MP3 library with you and listen to music wherever you go.
1. Verify that your computer meets the operating specifications required to sync the SanDisk MP3 player with the PC.
All SanDisk MP3 players require Windows XP or later; Windows Media Player; and a USB 1.0 port. A USB 2.0 is important if you want high-speed music syncing.
2, Check that the SanDisk MP3 player has a full battery charge.
All SanDisk MP3 players have a rechargeable lithium ion battery, and some SanDisk devices have a replaceable battery.
The battery icon on the top right-hand side of the SanDisk MP3 player's screen displays the current status of the battery's charge.
If the battery is low, recharge it before using the SanDisk player for the first time.
To charge, connect the player to your computer's powered USB port using the included USB cable.
The SanDisk player's screen will display a yellow charging icon.
Unplug when charging is complete.
3. To turn on the SanDisk MP3 player for the first time, unlock the "hold" switch on the top of the MP3 player by sliding it so that the orange tab does not appear.
Then, press the "power button" once.
Wait for the SanDisk MP3 player to respond.
The thumbweel of the player will flash a light and the screen will turn on to display the player's menu options.
Turn off the SanDisk player by holding down the player's power button for two seconds.
Wait for the screen to display "Goodbye" before releasing the button.
4. Practice resetting the SanDisk MP3 player to solve critical software errors and to fix the MP3 player if it freezes.
To reset the player, hold down the power button for fifteen seconds.
This resets the MP3 player to its original factory settings and can help resolve any problems you encounter while using the SanDisk MP3 player.
5. Connect the SanDisk MP3 player to your computer using the included USB cable.
Once the computer has sensed the connected device, the SanDisk player's screen will display "Connected" and the SanDisk Portable Media Player will be listed under Other in your computer's My Computer window.
6. Add music to the SanDisk MP3 player.
Double-click the Portable Media Player listed in the My Computer window.
Double-click the Music folder.
Select the MP3 files that you wish to load onto the MP3 player and drag them into the Music folder.
The player will load them into its internal memory and make them available for playback once the device is disconnected from the computer.
7. Sync your MP3 song playlists from Windows Media Player to the SanDisk MP3 player.
Create a playlist in Windows Media Player and connect the SanDisk MP3 player to your computer (see Step 5).
Once its connected, Windows will display a dialog box. In the box, click "Sync digital media files to this device."
In the next window, click Set Up Sync. In the menu, click Personal Playlists and then select the playlists that you wish to transfer to the SanDisk player.
Click the Add button then push the Finish button to transfer your Windows Media Player playlists to the MP3 player.
Aug 09, 2013 | SanDisk Clip Audio Players & Recorders
I cannot acses my ipod from computer to update my songs
First, plug both ends if the wire in the right places. Then, after you log in, turn on your mp3 player. My Sansa Fuze will appear in the My Computer folder; yours probably will too. To add anything, you have to access it from My Computer-> [name of mp3 player] ->Music/Video/Pictures to add these things. While you're pasting stuff to the mp3 player, the screen of the mp3 player will say "writing"- don't unplug your mp3 player until the screen just says "connected". The media will refresh, and the content should be available
Feb 04, 2010 | SanDisk Sansa e250 MP3 Player
My sandisk sansa clip mp3 player won't go past the start upscreen
Do a master reset on all the usb ports on your pc and reset the mp3 if you can.
Jul 06, 2009 | SanDisk Sansa Clip MP3 Player
Stuck on finalizing update and computer wont recognize.
yet i don´t know much about your mp3 ..
is there any reset "button" if so try that
May 25, 2009 | SanDisk Sansa m250 MP3 Player
Sansa c150 not working properley please repair it
I have 1 g used and it wont let my load anymore and all the songs come up as A is my player dead
thanks
Oct 02, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Help
Do not use windows media player! go to my computer and open up the MP3 folder, copy and paste the songs into the folder. If this does not work it is the MP3 player
Jun 16, 2008 | SanDisk Sansa c200 MP3 Player
MP3 will not charge
change usb cable or clean usb port and connector
Mar 06, 2008 | SanDisk Sansa e270 MP3 Player
Won't go past SanDisk logo screen
you have to take it off hold because when you first get it it's on hold
Dec 25, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
63 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
