FixYa.com
Tags:
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Brushes won't spin on hoover steam vac ls (by 6 users)
posted by richmond1273 on Jun 26, 2008
the brushes on the base of the vac don't spin anymore but the brushes on the attachment work just fine. everything else works just fine. i have cleaned the front screen where the spin indicator is and there is nothing obstructing the brushes. thanks.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by crogers67, posted on Aug 20, 2008
My problem is the same. The machine works great, but the brushes no longer turn. I've cleaned the screen and checked the spring. Nothing seems out of order, but they will not turn.
I'd LOVE to find a true solution!
Comment by samueljohn, posted on Jul 31, 2008
I have the same problem with the brush not turning. Has anyone come up with a solution to this problem as of Aug 1, 2008.
As to Joe Blow's solution, doesn't he have enough to do????
Comment by jackie3621, posted on Jul 20, 2008
have taken sweeper head apart as far as I can but run into sealed unit for brushes. I'm afraid to go any farther because of the water issue. If I break the seal I'm afraid the cleaner won't work at all.
Comment by bhewittjr, posted on Jul 13, 2008
i have the same problem
Comment by Guest, posted on Jun 29, 2008
I have the same problem with my hoover carpet cleaner. I can not get the brushes to spin. Everything else still works so what do I need to do to fix the problem.
Best Solution
Inappropriate (40)
joeblow674
Rank:Apprentice Apprentice
Rating: 40%, 1 votes
I think i can help. I just had the same problem and had it serviced. Luckily i am good friends with the service man and he showed me exactly everything that needed to be done to remedy the situation.
FIRST: Go out to the garage and get the red can of gas used for the lawn mower.
SECOND: Find a nice open area and place the Hoover vac in the clearing.
NEXT: Douse the SteamVac with a liberal amount of gasoline.
FINALLY: Careful! Now this part is tricky. Light match, and apply to cleaner and watch it melt.
Hope this helps! Have a nice day!
Rating Locked! (?) richmond1273 has rated this solution as Inappropriate
Solution #2
posted on Aug 02, 2008
Not Rated (0)
schnoodleDo
Rating: 0%, 0 votes
I have the SteamVac Dual and there's a screen on the underside of the unit. It's beneath the brushes and it's red. You have to pull and wiggle it to get it out. With the machine unplugged, lay the unit with the handle on the floor. In the owner's manual ( http://www.hoover.com/pdfs/manuals/F7222900.pdf ) this is shown on page 10 figure 3-2. Clean that screen.
If they still won't spin, then take the brushes out. Again, with the unit on the floor, you simply grab the unit firmly and pull towards you. It's much easier to remove than the screen. I took the brush unit outside and blasted it with the house. You'll have to pull out whatever fur balls are clogging it but eventually you'll see that the brushes spin freely with the water squirting on them. Plug the brush unit back in and - in my case - they started spinning.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Vacuums problems?
Hoover SteamVac Carpet/Upholstery Deep...
need manual for Hoover steam...
I need a manual for this steam... Answer This...
hoover steam vac deluxe 15
hoover steam vac deluxe 15 spin... Answer This...
the best wet & dry vacuum...
dear expert, please guide me to... Answer This...
will not pick up water
hoover vac will not pick up... Answer This...
NEED MANUAL FOR HOOVER...
hoover steam vac spin scrub Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
