Question about Kenwood KDC-MP822 CD Player
Won't turn on!
I just bought a '93 Ford Taurus w/ KDC MP822 and I can't not get it to turn on. When I start car the face opens and then closes but nothing else happens. Help. I have never had a radio like this?
  • 1 more comment
  • Anonymous Nov 29, 2008
    I have the mentioned radio and the face will open and reclose after approximately five seconds; without illumination from the screen. What would be your opinion on a fix? Would the two ribbon cables fix this problem aswell? Thanks in advance.
  • Michael Lambeth Nov 29, 2008
    I have the mentioned head unit and the face will open and re-close after approximately five seconds; without illumination from the screen. What would be your opinion on a fix? Would the two ribbon cables fix this problem as well? Thanks in advance.
  • simonmw75 Apr 14, 2009
    If i replaced the two ribbon cables, and the display still doesn't work, what would you suggest i do next?
    President:
  • 624 Answers
This is a common problem with this model of Kenwood. It is caused by the ribbon cables that connect both displays to the main board.
here are those part numbers:
J84-0153-05
J84-0154-05
One of these ribbon cables needs to have the connector jack removed from the old cable and soldered on to the new cable.
It is not the most difficult job in the world, but without prior experience you could end up causing more damage than you started with. This is true with all electronics.
I can not guarantee that this will fix your problem, but in about 95% of these models it does fix them.
If you decide to get it fixed at a service center you can expect the cost to be from $100 to $125, depending on the cost of the part and the labor rates of the service center.
This is a higher end unit from Kenwood and the repair is well worth the cost as long as it doesn't exceed about $180, then it may be at the point when it makes more sense to just buy a new one with the full warranty.
I hope you found this information helpful and if you did a good rating of "FixYa" would really be appreciated.
Let me know if you need anymore help,
Dave
Posted on Jun 28, 2008
2001 ford taurus power draining new battery & new alternater won't work when cables are removed from battery
That suggests that the problem is in the harness, something in the connector or wiring is causing an open circuit. You will need to have the circuit tested to find the fault. Ford alternators have known connector issues & new aftermarket connectors are readily available at most auto parts stores.
Oct 25, 2017 | 2001 Ford Taurus
Why won't my 2004 Ford Taurus 3.0L idle?
Sounds like the EGR valve is stuck in the open position.Take it off and clean the off of it and make sure the pintle will open and close because it should be closed when the engine is at idle speed.If it is open at idle then it is allowing exhuast gasses in and will choke the motor out.
Oct 24, 2012 | Ford Taurus Cars & Trucks
My 2001 ford taurus won't start but everything is working on the insise of the car
close all the doors, lock them all with the key and then unlock the drivers door with the key and start the car that should reset the theft interlock
Feb 10, 2012 | 2001 Ford Taurus
The radio opens with lights and lsights go out and immediately closes. Keeps opening and closing with no sounds. After doing so for a bout a year... radio came on. However did not come back on when I...
It sounds like it could be a bad ribbon cable. There are two ribbon cables in the deck, so it could be either one, or both. There is also a face position sensor lever inside the deck that goes bad.
Jul 22, 2011 | Kenwood KDC-MP822 CD Player
Just opens and closes but does not otherwise work
Hi and thank you for using fixya:
Please check the fuses on the back of the unit going to cables and speakers. if this dont work then you have an internal unit problem
thanks
good luck
Jun 29, 2010 | Kenwood KDC-MP822 CD Player
When i turn the car on the control panel on the Kenwood excelon KDC-X769 jus starts on opening and closing but never stays opens
you may have a bad face position sensing lever inside the deck, or bad gears. it could even possibly be bad flexible cables.
Jun 20, 2010 | Kenwood eXcelon KDC-X769 CD Player
Unit only has power for a few seconds
could be a couple of things..1. issue with your ground connection 2. ventilation
May 29, 2009 | Kenwood eXcelon KDC-X879 CD Player
Taurus wont start
keep your foot on the gas until the car warms up
Jan 29, 2009 | 1993 Ford Taurus
93 Ford Taurus GL 3.0 V6) whrer exactly is the solenoid?
it on the starter check under the car it shoud be in the front of the engine on the dirvers side but if i were you take the start to autozone or advance and have it tested if it is the solenoid just replace the whole thing it not worth just fix the solenoid it self
Oct 09, 2008 | 1993 Ford Taurus
Kenwood KDC-MP822 CD Player Logo
319 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
