Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
Freezer Working Refrigerator not... follow-up
22yoop,
Thanks very much for your reply!
So I just had my son check and 'yes' there is frost on the back of the freezer. So it looks like your suspicion is correct.
With that said, what do I do now? I presume I need to clean the frost off of the back, but otherwise how do 'de-frost' the freezer coil? Also, how do I access the freezer coil.
Guess the next question is once I 'de-frost' how do I prevent from happening again. Are there parts that should be replaced or do I simply need to do a better job of maintaining.
Thanks very much for your help.
-Fred
  • acorniv Aug 08, 2008
    We bought this model refrigerator two years ago with a one year warranty. A year and one week later, the refrigerator part stopped working. We paid Sears to come out and the serviceman said the fan was broken, and that he has to change them all the time in this model - he showed us how flimsy they are. He talked us into an extended warranty and 'fixed' it so we'd be able to buy it even though our original warranty had run out. It's been a year and one month and the refrigerator ( but not the freezer) is again not working. Sears says our warranty ran out a month ago, and that they never sell extended warrantys for more than a year for this product (?). We can't hear or feel the fan so plan to replace it ourselves. We'd like to find a stronger fan, and also to know why this part breaks so easily. Is it possible something else is wrong with the refrigerator that is causing this?
    The information given here indicates that is the case. So what do I do about the fact that the fridge really wasn't repaired a year ago, or that this model is just plain flawed to begin with? Also where can I find a stronger ( metal) fan? BTW, for others dealing with this, shop around for fans. The Kenmore model ranges from 25.00 to 55. and probably more, depending on where you buy it.
  • 828 Answers
Cleaning the frost off the back is only scratching the surface of the problem. The back wall of the freezer section must be removed to expose the real point of the problem. Behind the back wall there are two main items, the heaters and a defrost termination switch. To check the heaters unplug the connections at each end and read them with an Ohm meter. If no reading the circuit is open and the heater is bad. Some heaters are of the glass tube radiant type and some are of the cal rod type. Most modern refrigerator have gone to the radiant type of heaters. By simple observation you can sometimes see the point of break in the heater as a burnt spot. If the heaters are open they must be replaced.
Posted on Jun 28, 2008
  • James Helmer
    James Helmer Jul 02, 2008
    Your are welcome.
I have a side by side and the freezer is working fine and refrigerator is not cold
Hello.
If you open the freezer door and look on the back wall do you see frost build up on the back wall?,if so yes thier is frost build up in the freezer heres what to check.
DEFROST HEATER ...remove back wall of freezer and you will see a black heater at the bottom of the coil thats frosted up,it looks similar to the bake element in your oven,or in some cases it is going to be a spiraled wires inside of a glass tube. To check it,use a multimeter set to the lowest ohms of resistiance setting and follow and find the wires at the top of that frosted coil,unplug/disconnect those wires and check for continuty with around 5-20 ohms of resistiance. If it has that amount of ohms the heater is good. If your meter display does not change or displays OL the defrost heater is broke and needs to be replaced
DEFROST TERMINATION THERMOSTAT... it's round and has 2 wires and clips to the top of that frosted up coil. IT MUST BE CHECKED WHEN COLD SO BEST TO DO WHEN FROST IS STILL BUILT UP. To check it disconnect the wires on it and check for ZERO ohms of resistiance. As with the heater if the meter display OL or doesnt change,it is the problem
DEFROST CONTROL...it is hard to check for a semi unskilled person and if the heater or defrost t-stat check good its going to be the problem. It will NOT be in the freezer it could be on back wall or inside the control panel in the refrigerator section.
Good luck,
Gene
Aug 16, 2011 | Hotpoint Refrigerators
My son left fridge door open, from 1-2 hours. it doesn't seem to be cooling now. Is there a problem or does it take a while for condensor to come back on?
What has happened is that the evaporator (the cooling coils inside the freezer) have frosted up due to all the moist air which entered the refrig with the door open. This frost has blocked the normal flow of air within the refrigerator/ freezer. Turn unit off, unload freezer, and leave freezer door open for several hours to allow built up frost to melt. Better yet, remove the panel at the back of the freezer and melt the frost off with a hair blower.
Dec 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Nov 08, 2009 | GE PSS25MGN Side by Side Refrigerator
Refrigerator not cold
first check your damper door from the freezer to the refrigerator compartment make sure its in the proper position. Then turn off the refrigerator for a few hours until the heavy frost melts away. turn on the refrigerator check the refrigeration cycle, is it working properly, is it going into defrost are the defrost heaters working.
Feb 21, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Both sides are not cooling
Leaving the door open allowed an unusual amount of moisture laden air to enter the refrigerator, resulting in excessive frost build up on the evaporator. That frost is blocking the cooling coils so air can no longer pass through them. You can fix this by unplugging the refrigerator for a day or so, allowing the frost to melt, or taking the back wall out from behind the freezer shelves and melting the frost off with a hair blower.
Jan 11, 2009 | Whirlpool GC5SHEXNS Side by Side...
Fridge/Freezer not cold
Yes, replace the defrost heater and melt the frost with a hair dryer which is blocking air flow over the evaporator. The frost blocked coils (behind the freezer wall ) results in very poor cooling.
Jun 14, 2008 | GE GSS22JFMWW Side by Side Refrigerator
The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Feb 17, 2008 | Frigidaire FRS26ZSG
Whirlpool top freezer problem
Check for frost build-up behind back wall in freezer. If there is a heavy frost build-up, it's not defrosting. This will restrict airflow to refigerator section and can stop fan. If fan is stuck again and it's not because of frost, replace evaporator fan motor.
Nov 12, 2007 | Whirlpool ET1FHTXM Top Freezer...
Ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Aug 10, 2007 | Whirlpool ET1FHTXM Top Freezer...
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
