Question about Apple Power Mac G4 Dual Mac Desktop
G4 MAC LOCKING UP
After boot, after few minutes, the computer locks up, I have changed the hdd and reload, changed the memory, what else can it be? system board, cpu, heat sync, and are they expensive to replace?
  • Glenn Upton-Fletcher May 11, 2010
    Is there any history of this unit being dropped, fallen over etc.?
  • Andrew Bowmaker
    Andrew Bowmaker May 11, 2010
    By locking up, do you mean freezing, or slowing down? Do you hear clicking coming from you MAC sometimes?
    Problem Solver:
  • 5 Answers
After boot??? Have you tried holding down the shift key (Safeboot). If you can log into your account then check startup items in systemprefs/user accounts/startupitems
If it still crashes you need to create a new user account. Log in and if that works then copy all data from old account by using Batch Mod on old users folder. Do not copy anything from user library.
Posted on Jul 15, 2008
Mac g4 added more memory won't boot up
Possibly not twins, must be same chips.
remove insert old if not damaged and see it it reboots
May 17, 2013 | Apple iMac G4 Desktop
Why does my Apple iBook G4 display ''you need to restart your computer''?
Have you added memory to the machine?
If so, is the memory to the right specification?
Mar 08, 2013 | Computers & Internet
Imac g4 freeze restart
This is a sign of memory issues with your Mac. Replacing the memory should not be very expensive.
Oct 10, 2012 | Apple iMac G4 Desktop
G4 power light flashes
Thank for contacting Fixya, I will be glad to assist you.
Here are some steps you can try to resolve the issue:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the startup sound for the third time.
• Release the keys and allow the Mac to start up.
If neither of these processes do not work, have your RAM memory checked, as this could be a factor in your G4 not booting up.
One other factor to consider, especially given consideration of the flashing light and no boot up, depending on the type of G4 mac you have, would be the power supply, which is what gives your G4 the power to boot up and function.
Hope this helps.
Regards,
-The MacTechTrainer
Jul 10, 2012 | Computers & Internet
Powerbook g4 Aluminum 15 LCD
it could be the inverter to the display, or the graphics chipset or the connection between them.
Nov 02, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Canoot get Mac to boot up all the way
there is a hardware fault or full hdd ...
thi guys will help Micromen - London
Aug 30, 2009 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
No sound what-so-ever
Do you have the Apple Hardware Test Utilities Disk. If so, restart the computer with that cd inside. It will do a diagnostic and determine if there is a defect with the hardware.
If not, power off the computer.  Wait about 2 minutes. Then press and hold down the power button til you hear a long beep noise. then release. allow computer to finish booting up. Then do a sound test again.
let me know if this helps.
enov8
Mar 07, 2009 | Apple PowerBook G4 Mac Notebook
My Aluminum Powerbook G4 wont boot up
Insert the system CD, restart the computer holding down the C key until it boots using the CD. Then run through the initial screens as though you are going to reload the system software until you are given a menu bar. Select Disk Utility from the menu bar when you can and then you can run disk first aid and 'Repair disk'. If this works OK then you are back up and running after a restart. Otherwise you will have to reload the system. Note: when you have booted of the CD, you should be able to access the hard disk and retrieve any files you want first to an external disk or memory stick before reinstalling the system software. Good luck - TT
Dec 03, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
G4 MAC PROBLEM
When you ran diagnostics, were you starting up from the AppleCare CD/DVD (or whichever diagnostics disc it was)? If you were and the system didn't crash, that would likely point to a software problem causing your trouble. Have you tried booting up in 'safe mode' by holding down the SHIFT key? That would be my next troubleshooting step. Also, what computer is this?
Jun 26, 2008 | Apple Power Mac G4 Dual Mac Desktop
Mac G4 Laptop wont boot up
This can often be fixed using a tool like Disk Warrior, but you will have to have another Mac to make the repair. See if you can boot into Firewire target mode (by holding down the T key while starting up the computer. You will get a big Firewire icon on the screen if this work. If you can do this, then you can attach the computer to another Mac using a firewire cable and use disk utilities to check out your disk and attempt to repair it. My experience is that Apple's disk repair will rarely fix this, but Disk Warrior almost always will.
May 16, 2007 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apple Power Mac G4 Dual Mac Desktop Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
