Question about Car Audio & Video
Cant locate my radios fuse - Car Audio & Video
  • 1 more comment
  • Anonymous Mar 13, 2009
    i have checked all fuses in fuse box for radio,all ok, is there another fuse on radio and how do i get to it
  • pjoosten Apr 16, 2009
    I also have a dead radio in my 2008 F150.
    I checked the fuses in the fuse box and all seems to be OK.
    Also I have heard of a fuse in line with the 12V DC wire to the radio with some models, but do not know if this is also the case with a 2008 F150.
    How could a fuse blow: If you sump-start the car and by accident reverse the folarity for a few seconds the fuse could blow.
    The radio cannot damage really. It has a polarity reversal diode at the DC power input for protection.
    I only hope I checked the right fure?
    Phill
  • larry_edward May 10, 2009
    the radio is a jvc, the car a 1996 camaro rs. there was a lose wire in back, orange, but radio was working, but cutting off. when putting radio back in dash, the orange wire touched metal, and radio went out completely. All fuses, including one in back of radio look good. I am told radio fuse is in a different fuse box near dash and door panel
    President:
  • 624 Answers
If you tell me what kind of radio it is, make and model, I may be able to help you better. You can find that information on the display for many radios, and on the bottom or back of the radio for others. Too much information is always better than too little information.
Many car stereos have the fuse right in line with the power wires (yellow and red, sometimes the black ground wire) coming from the harness on the back of the radio. It is rare that a radio has a power fuse on the inside of the radio. Some pioneers have a RCA ground fuse on the board inside the radio which require a technician to replace.
Some radios have a fuse right on the connector jack for the wiring harness on the back of the radio.
If the radio is completely dead, it is a possibility that the fuse has blown. But a new question then comes up. Why did the fuse blow?
Sometimes it can happen from playing the radio too loud, but even then, the fuse should not blow. But it is possible. Sometimes it is a shorted speaker, a bad amp IC, or another shorted component.
If you find the fuse make sure that you replace it with the same type and ratings. Most car radios use a blade fuse. Some have the glass tube type when they are inline with the power wires.
Once again, if I know what kind of radio it is, I may be able to tell you just what type of fuse to use, not all radios use the same fuses.
If you replace the fuse and it blows again, you really should take it in for service.
If your radio is not dead, the fuse is not a likely problem.
I hope this helps and let me know if you need any more help.
Dave
Posted on Jun 26, 2008
I see no answeres to know questions
Hi Tony:
If it is a stock radio, the fuse should be in the fuse panel. Check the user manual or google an enquiry with make, model, and year, with the key words -radio fuse location.
If it is an aftermarket radio it may have an in-line fuse on the electrical supply. Finding that may involve some searching and wire tracing.
Cheers.
If you want more info from me, reply as a comment to this post.
Nov 19, 2015 | Cars & Trucks
The rear radio power wont come on. how can i fix?
if you have the original owners manual check there for fuse location.
Sep 14, 2014 | 1998 Oldsmobile Silhouette
2000 nissan pathfinder cant find fuse box
could be a fuse, but i doubt it. if half the panel lights are out on the radio itself, there is either a blown bulb inside the radio, or some other problem. if it is the panel surrounding the radio, it may just be a blown bulb or two. as far as the fuse box location, there are four solid options. under the dash by your left foot, on the opposite side in the passenger footwell, on the side of the dashboard, or under the hood. hope this helps
Aug 14, 2012 | 2000 Nissan Pathfinder
The cigarette lighter and srereo not working cant locate fuse onhonda leged 1997
they are their somewhere if not look under the bonnet in the power distribution box but the radio is a seperate fuse also many radios have a fuse in the back of them
May 19, 2012 | Honda Cars & Trucks
I dont have the owners manual. My 02 f250 super duty. The radio fuse is out and cant locate it
the fuse for the radio is the 11 fuse (20amps) and its located in the central juction box that's the fuse panel that is located inside of the vehicle. also check for fuse 32(5 amps) fuse 16 (15 amps) and fuse 42 (15 amps) all this fuses are in the same fuse panel and sre related with the radio i hope that this could help you
Feb 13, 2011 | 2002 Ford F250 Super Duty SuperCab
I cant find the location of reverse light fuse,it's not also located in fusebox
Try looking under the hood most cars have 2 fuse boxes and if what your looking for isnt in 1 its in the other. If you cant find it you might need to get a fuse tester and try all the fuses it could be with another fuse ie: radio, wipers, etc...
Feb 09, 2011 | 2008 Chevrolet Express
Cant restart car radio
This sounds like an easy fix. I would locate the fuse that is for your radio, and try that. It is probably blown.
Feb 19, 2010 | 2007 Mercedes-Benz ML320 CDI
My car radio went out i cant locate the fuse box i have a 95honda civic
fuse box for radio is located under hood. passenger side by the battery.
Sep 22, 2009 | Car Audio & Video
STILL CANT LOCATE THE INTERIOR FUSE BOX HONDA ACCORD 1.8 1996 MOD
The 96 Accord interior fuse box is under the dash, drivers side. Look for the small access panel with a thumb twist on it. Picture below:
99631fb.jpg Fuse location in box is #1 below:
309c947.jpg Good luck.
Regards
Jul 21, 2009 | 1996 Honda Accord
Cant find fuse box to change the radio fuse
check below your stering wheel ore on the passanger side for box also hanes books help you on this
Jul 21, 2009 | Honda Accord Cars & Trucks
Car Audio & Video Logo
383 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
