Question about Samsung Digimax S1000 Digital Camera
Memory card i have a samsung s630... and i can't figure out how to unlock the memory card... its an emergency! memory card locked I have my card locked.I want to unlock it
    Scholar:
  • 116 Answers
Hi Aisha,
I had the same problem but and i checked the small tab on the side of the card. it was in unlock position. i subsequently fixed the card adaptor to rest firmly on the side of the switch using a small paper wedge on the opposite side. This cleared the problem. However card adaptor should now not be removed otherwise you may revert to original problem
Regards,
Luwangula
Posted on May 21, 2009
    Scholar:
  • 78 Answers
Hi Aasha,
To unlock an SD card, you should locate a small tab on the side of the card. Be careful when reinserting the card to make sure you do not lock the card again.
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jun 26, 2008
3 Suggested Answers
Indian Guru
  • 32 Answers
SOURCE: memory card
what do umean if u mean unlocking the card to removing the card from the slot just given a push downwards to card and it will come out automatically pull it then
Posted on Apr 25, 2007
Gwenivie
  • 39 Answers
SOURCE: memory card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Posted on Jan 12, 2008
CARD LOCKED IN ES70 SAMSUNG CAMERA
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If that doesn't do it, try another card.
Sep 17, 2011 | Samsung Digimax S630 Digital Camera
My samsung s630 digital cameral is stuck on card lock how to i fix this
It's not the camera, it's the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 13, 2011 | Samsung S630 Digital Camera
My screen says card locked when taking photo
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 22, 2011 | Samsung Digimax S630 Digital Camera
I have the samsung s630 and i have taken some pictures on it before i got a memory card. i want to save them to my memory card, but when i insert the memory card those photos wont show up. how do i get...
If you remove the card from the camera and connect the camera to your computer with the USB lead, you should see the camera's internal memory as a disk drive on the computer. If there is a memory card inserted, you will see that memory instead.
Unlocking individual pictures is done with the same function that locked them. It is probably on a menu available when you are viewing the pictures on the camera.
Oct 20, 2010 | Samsung S630 Digital Camera
Card lock.?
Friend dont worry it so simple
Insert u r card into card reader and then change its format
Up to
Fat or Fat 32 Into NTFS and format it if it is formated then it will be ok
Jul 25, 2009 | Samsung Digimax S630 Digital Camera
Samsung digital camera S750
there will be a little slide lock on the side of your memory card you just need to unlock it
May 31, 2008 | Samsung Digimax S630 Digital Camera
CAMERA SAYS MEMORY CARD IS LOCKED
There is a small sliding tab on the side ot the card. Slide it the other way
Apr 22, 2008 | Samsung Digimax S630 Digital Camera
Memory card
- Turn off camera
Jan 01, 2008 | Samsung Digimax S630 Digital Camera
Card Locked?
There is a switch in the memory card, you just have to slide it upward.
If you are using a new memory card, format it first.
Do the following:
- Press Menu/ Ok button
- Go to Set Up 2
- Select Format
- Select Yes
Nov 13, 2007 | Samsung Digimax S630 Digital Camera
Memory card
Apr 22, 2007 | Samsung Digimax S600 Digital Camera
Samsung Digimax S1000 Digital Camera Logo
102 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
