Question about Fisher Paykel EcoSmart GWL15
Fisher Paykel washing machine GWL10
Had a very bad storm . Will not turn on.I think its fried.
What can we do.
  • julie87 Jul 22, 2008
    my washing machine is just over a year old, was doing a load of washing and it cut out wont trun back on thought it might have been the power point but plug some thing else in it and it works fine, pluged the machine in to another power point and it wont turn on what can i do
Had the same problem with some other appliances. If you're not afraid to open the washer up, it's likely there's a fuse that has blown. If you can find a source for the EXACT same fuse (specs on the body of the fuse), replace it, or you may wish to risk a house fire by bridging the fuse with a piece of electronics solder.
Posted on Aug 13, 2008
Fisher paykel GWL11 will not power on (yes the circuit is on)
Check the water pump under the machine. These pumps fail, but are easy to replace. Ours was short circuited and actually sparked when the power button was pushed. Same no lights, no power. We had a GWL10 model, but I'm sure the GWL11 is similar.
Aug 13, 2014 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10 fault code 104
your display or pump could at fault here.
measure resistance at pump,
if resistance in less than 33 ohms, replace your pump.
Check display plug for bent pins.
Feb 03, 2013 | Fisher and Paykel Washing Machines
Fishwe&Paykel GWL10 won
It could be the out of balance switch faulty & need replacing.
Nov 17, 2012 | Fisher Paykel EcoSmart GWL15
I have a 10 year old Fisher & Paykel GWL10 washing machine. Fault code 1 is coming up. The machine turns completely off. The longer it cools down, the longer it goes before turning off again. This...
Code 1 - usually means on the later models of Fisher & Paykel is a faulty Motor Control Module, often though one would have to replace both as well as the display module.
Anyway - it sounds like the electronics are overheating hence the intermittent problems you are experiencing.
May 27, 2011 | Fisher Paykel EcoSmart GWL15
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
I've got a fisher paykel gwl10 top load washing machine
Check the pipes leading to water pump for wetness also the door seal,If all pipes are dry and look ok then it could be due to the water seal and bearings braking down.
Jun 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel wahsing machine GWL10 stuck in rinse cycle.
no power from the control board to the diverter.replace control is about $150.00 for the part
Jan 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GWL10 US won't spin
Buy an new one and trash this one
Sep 13, 2008 | Washing Machines
Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Mar 29, 2008 | Washing Machines
its possible that the pump is either going bad or there is somethin gin the pumps/sump assy. on this model the unit generally tends to shut down when the pump overheats, and will only restart when the pump cools off, a warnig obout replaing hte pump if need be is the pump is actually 220v. you MUST UNPLUG MACHINE BEFORE SERVICING. its a foriegn brand remember so theres abuncha wierd wiring and the pump is one of them!
Mar 25, 2008 | Fisher and Paykel IWL12 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
226 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
