Question about Dell E173FP 17" LCD Monitor
Monitor aspect hi my moniter has black bars running across the top and bottom like a widescreen film and i cannot find a option on the monitor to resize the screen to fit or make it vertically wider. any suggestions?
I think you need to check all capacitor in vertical section. Maybe there is a leaky capacitor, and one the cause of black bar.
Posted on Jun 27, 2008
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
How to zoom in on info
When TVs first appeared, they had an picture ratio of 4:3, which matched that of most movie screens at the time. Terrified of losing their business, movie studios struck back with "widescreen" films using 1.85:1 or 2.35:1 ratios. When widescreen TVs started appearing, they emulated those same ratios, but many TV shows (and some movies) were still in 4:3---and we were eventually left with a bit of a mess. Canny manufacturers, including LG, have solved the problem by allowing you to adjust the picture ratio on the TV to fit the program you're watching. If it's not set properly, however, your image will look distorted or cut off. A quick bit of troubleshooting can fix the problem easily.
  1. Press the "Menu" button on the remote and scroll down to the "Option" title (it should be second from the bottom ). Then select "Aspect Ratio." You should see a list of ratio options. You simply need to pick the one which fits the show you're watching.
  2. Choose the 4:3 ratio for older movies and TV programs. You should see a pair of bars on the left and right side of the screen. (That's okay: the bars keep the program in the same proportion in which it was filmed.)
  3. Select the 16:9 ratio for widescreen movies and for more recent shows to match their longer width. For some movies, you may see black bars and the top and bottom of the screen. Again, that allows the movie to be shown in the manner it was filmed.
  4. Pick "Set By Program" to automatically switch the LG TV between 4:3 and 16:9 to match whatever show is on at the time.
  5. Select "Horizon" to horizontally expand the image onscreen. It will fill the whole screen---eliminating the black bars to the left and the right---but it may look distorted.
  6. Use the "Zoom 1" option to zoom the image forward. That will eliminate the black bars at the top or the bottom of the screen, though you will cut off the edges of the image.
  7. Pick the "Zoom 2" button to select a midway point between "Horizon" and "Zoom 1." The picture is stretched, but not as much as with "Horizon," and fills the screen, but doesn't cut off as much as "Zoom 1."
  8. Use the "Cinema Zoom" button to enlarge the picture to fit the screen. This option allows you to adjust the proportion to your liking, rather than use the set proportions of the other aspect options.
  9. Exit the menu when you are done and watch your programming normally.
Feb 04, 2011 | LG Televison & Video
I can't get a full screen picture black band across top and botto
try adjusting the aspect ratio. on widescreen movies or shows you will still get the black bands on the top and bottom. if you play with the aspect ratio you can sometimes get rid of it
Apr 19, 2009 | Protron PLTV3250 32 in. LCD Television
Widescreen tv=widescreen movie still have black on top & bottom
Sorry, you didn't provide enougb information for anyone to accurately answer your question. The most important thing you omiited was the nature of your video source. If anyone does answer this, I assure you it will be a wild guess. Here's my wild guess:
Your HDTV has a widescreen aspect ratio of 16:9. For every 16 units of width, there are 9 units of height. That ratio matches the exact ratio used in widescreen television broadcasting. However, most feature films (movies) on DVD have an aspect ratio of 2.35:1 or even wider than that. These films will display with horizontal black bars at the top and the bottom, so that you can see the full image. Unless you choose to use one of your TV or your DVD player's options to zoom or crop the image, the bars are 'correct' and there's nothing wrong.
Another possibility is that you have not configured your video source, such as a DVD player, to 'know' that you have a widescreen TV. Nearly all DVD players ship configured to output using a NON-widescreen aspect ratio, so you must adjust this setting using your player's setup menu. The same is true for most cable boxes and satellite receivers.
Finally, just because your TV is widescreen, the video source itself may not be. Most standard-definition broadcasts are NOT widescreen, for example.
If you re-post your question with adequate information about which video source exhibits this problem, I'm sure you will get much more specific and helpful answers.
Dec 30, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
DVD WS does not display right on Samsung 40'' HD 1080P LCD TV
Check the aspect ratio of your widescreen DVD. I'll assume that your flat panel TV is widescreen, which would mean it has a ratio of 16:9. Some movies are even wider than that (i.e. 2.35:1), so it would be normal for you to see black bars at the top and bottom. Look for a WS DVD described as 16:9 (usually shown on bottom on back). This should fill your TV screen and not distort the image. If you still see the black bars, you will need to check your DVD menu settings for widescreen aspect, and supply more info on the DVD player and TV.
Nov 30, 2008 | Televison & Video
Now using an hdmi to dvi cable - screen size has reduced
Your digital box should have aspect settings as well. When watching HD TV and or movies there is a possibility to get the black bars on top and bottom. It all depends on the ratio it was filmed in.
Nov 18, 2008 | Philips Televison & Video
Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
Jul 22, 2008 | Samsung BD-P1400 Blu-Ray Player
Aspect ratio changing on ATI radeon hd2400 pro
My wifes DELL has a F key with a blue icon that does that
take a look at the BLUE symbols and see if there is one showing a rectangle with either blue bars on each side or similar
When she presses it the screen changes to a 4:3 aspect with black bars on each side
Jul 03, 2008 | Computers & Internet
Getting 4:3 aspect ratio
off the monitor for few hours and use it
tell me what happens then
May 15, 2008 | Computers & Internet
Widescreen
Unfortunately, a cinema screen is even wider than a widescreen TV. Because of this (in order to keep the original aspect ratio), even with a widescreen TV you still end up with the black bars top and bottom.
Check the aspect ratio of the DVD (Should be printed on the back of the case somewhere).
Unless it says 1.85:1 or 16:9 Anamorphic, you will get the black bars. (Many films on DVD are 2.35:1 or even wider!)
Have you got any different picture modes on your TV. I've got a Toshiba and it has something called 'cinema mode' which does eliminate the bars. Unfortunately it does it by zooming in on the picture slightly, so you loose a bit off the side of the picture and the image does get a little grainier.
Hope this helps.
Matt
Feb 29, 2008 | Philips DVP3020 DVD Player
Dell E173FP 17" LCD Monitor Logo
69 people viewed this question
Alun Cox
