Question about RCA HD50LPW42 50" Rear Projection HDTV
RCA HD50LPW42 problem
My tv will power on then the light will blink repeatedly then the tv will go back off. I saw someone who had the same problem and you said it was the capacitors. Is it something easy enough I could do myself or should I call out someone. And how much does that usually cost?
  • 2 more comments
  • TheDigitizer Jun 26, 2008
    It comes on and I guess it's the color wheel that starts making noise. Then it blinks 5 times and goes off. Then comes back on and repeats.
    Thanks!
  • jan08 Jul 07, 2008
    TV stays on for about 60 sec, then video goes off (sound not affected) light blinks 5 times. About 60 sec later video comes back, slowly as when you've turned tv off too quickly. This repeats as long as it has power.
  • TheDigitizer Jul 16, 2008
    Well I got the color wheel in which was slightly different than the original. I took the board for the color wheel index off of the old one and put it on the new one. The new one had an adapter for the other plug and plugged in it. So everything seemed good to go. Turned it on and it was definitely quieter.... but it still does the same thing. The color wheel starts up for a few seconds then quits. Then the power light blinks five times and stays lit. The process then repeats. It's the same problem I had before.
Same problem here, blinks 5 times
Posted on Sep 15, 2008
  • RCA Master
  • 8,617 Answers
Your chassis is the ATC311 the capacitor issue is with the ATC336 chassis. How many times does the led blink?
Posted on Jun 26, 2008
  • Sonny Berry
    Sonny Berry Jun 26, 2008
    you need color wheel number 212184 you can get a replacement color wheel at the following link which has free shipping and free tech support for instalation and the indexing proceedures.Here's the link.
    http://servicemanuals.vstore.ca/
I have a RCA HD50LPW42, the tv stopped showing the picture awhile back but the sound continued when the tv was turned on. Now the sound has gone out too. When I turn the tv on the green power light blinks...
You may have two problems with your TV. This TV has a history of a color wheel issue, was making grinding noise? Have you ever changed the lamp?
It may be a bad color wheel and the lamp, you may want to do a visual inspection.
It is easy to replace the lamp but more likely the color wheel is the problem.
The part# for the color wheel is 212184, the part# for the lamp is 260962
Best of luck
Nour Sabre
www.aaatvservice.com
Nov 16, 2011 | RCA HD50LPW42 50" Rear Projection HDTV
I just bought the HD50LPW42 from someone he said it needs a color wheel. When I turn the TV on the green light comes on but I don't get any picture. What is a color wheel and is it needed to just watch the...
Most DLP TVs have a color wheel. This allows the TV to be manufactured with a single chip to control the color for each spot on the screen and a white light source. As the wheel rotates, the desired color light gets transmitted to the screen. This happens so fast that most people do not see the screen refreshing each color.
Here is one source for a color wheel for your TV: http://chaparral.shopjimmy.com/catalog/product/view/id/200632/s/rca-color-wheel-212184/ . This is a part reclaimed from a TV that was damaged in shipping so it was only used during factory testing. The part number is RCA 212184.
Usually the symptom of a failing color wheel is the TV being very noisy on startup (a whining sound) followed by it shutting down. Although other problems can be involved - for example a power problem going into the assembly with the wheel (there is a motor that turns the wheel).
I hope this helps.
Sep 29, 2010 | RCA HD50LPW42 50" Rear Projection HDTV
RCA HD50LPW42 dlp, does not turn on
If capacitors are swollen,vented or puffed up on top replace them .You may just need to replace your Lamp.CK all fans make sure they are running. Mats Electronics has Best Price for Lamps 1-800-628-1118
Let me know if you need more help.
Mar 23, 2010 | RCA HD50LPW42 50" Rear Projection HDTV
Rca hd52w59 tv. power light blinks three times in
Thats usually caused by the CP150, CP114 and CP120 capacitors which will need replacement. You can get that repair kit at www.tvrepairworld.com and the kit contains the CD with instructions for the repair.
Dec 14, 2009 | Televison & Video
RCA HD50LPW42. Sound so loud it sounds like a jet engine coming from TV (very loud whining sound). I assume this is my color-wheel, but I'm not sure.Turns off when TV turns off.
You need a replacement color wheel or have yours rebuilt since the RCA color wheels are on nationwide back order. You can get your wheel rebuilt at the following link
Sep 08, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Vertical lines appear on screen...
You have a defective light engine. Contact RCA support. Sometimes they will warranty these even after the 1yr warranty has expired.
May 16, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
My RCA is screeching
To install the color wheel, turn off and unplug the tv, take off the lower back casing (17 star type screws), remove the lamp door, remove the lower back casing. Look just left of the lamp you will see 3 smaller star type screws near a small circuit board (which is on the color wheel), remove those screws unplug cable from color wheel, unplug other end of 2nd cable from tv circuit board (just to the upper left nearest to the color wheel.
All you have to do is install the color wheel, plug in both cables, put the back on and place the lamp door back in its position, the lamp door pushes in a lillte blue lever which allows the lamp bulb to light up.
I'm in the process of doing the same myself on my RCA same model. Where did you buy the color wheel from?
rw9704
Jan 06, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Sawing noise
Sounds like the same problem I encountered with my TV might be
ballast.
Dec 31, 2007 | RCA HD50LPW42 50" Rear Projection HDTV
50 inch 1999 TheatreView Television
#1 When I turn on the TV the power button comes on then blinks 6 times then goes off for a few seconds then repeats the cycle. I have sound over my surround system during this time but no picture.
#2 My sound would crackle and pop every once and a while until now it does nothing. I have to watch it with the surround sound on.
Nov 26, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD50LPW42 50" Rear Projection HDTV Logo
285 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
