<p><span><span>Code
Description :</span></span><span><br />
<span>These Nokia codes will work on most Nokia Mobile
Phones</span><br />
<span>(1) *3370# Activate Enhanced Full Rate Codec (EFR)
- Your phone uses the best sound</span><br />
<span>quality but talk time is reduced by approx. 5%</span><br />
<span>(2) #3370# Deactivate Enhanced Full Rate Codec
(EFR) OR *3370# ( Favourite )</span><br />
<span>(3) *#4720# Activate Half Rate Codec - Your phone
uses a lower quality sound but you</span><br />
<span>should gain approx 30% more Talk Time.</span><br />
<span>(4) *#4720#</span><span> </span><span>Deactivate</span><span> </span><span>Half Rate
Codec.</span><br />
<span>5) *#0000# Displays your phones software version,
1st Line : Software Version, 2nd</span><br />
<span>Line : Software Release Date, 3rd Line :
Compression Type. ( Favourite )</span><br />
<span>(6) *#9999# Phones software version if *#0000#
does not work.</span><br />
<span>(7) *#06# For checking the International Mobile
Equipment Identity (IMEI Number).</span><br />
<span>( Favourite )</span><br />
<span>(8) #pw+1234567890+1# Provider Lock Status. (use
the "*" button to obtain the "p,w"</span><br />
<span>and "+" symbols).</span><br />
<span>(9) #pw+1234567890+2# Network Lock Status. (use
<span>(10) #pw+1234567890+3# Country Lock Status. (use
<span>(11) #pw+1234567890+4# SIM Card Lock Status. (use
<span>(12) *#147# (vodafone) this lets you know who
called you last.</span><br />
<span>(13) *#1471# Last call (Only vodofone).</span><br />
<span>(14) *#21# Allows you to check the number that
"All Calls" are diverted to</span><br />
<span>(15) *#2640# Displays security code in use.</span><br />
<span>(16) *#30# Lets you see the private number.</span><br />
<span>(17) *#43# Allows you to check the "Call
Waiting" status of your phone.</span><br />
<span>(18) *#61# Allows you to check the number that
"On No Reply" calls are diverted to.</span><br />
<span>(19) *#62# Allows you to check the number that
"Divert If Unreachable (no service)"</span><br />
<span>calls are diverted to.</span><br />
<span>(20) *#67# Allows you to check the number that
"On Busy Calls" are diverted to.</span><br />
<span>(21) *#67705646# Removes operator logo on 3310
& 3330.</span><br />
<span>(22) *#73# Reset phone timers and game scores.</span><br />
<span>(23) *#746025625# Displays the SIM Clock status,
if your phone supports this power</span><br />
<span>saving feature "SIM Clock Stop Allowed",
it means you will get the best standby time</span><br />
<span>possible.</span><br />
<span>24) *#7760# Manufactures code.</span><br />
<span>(25) *#7780# Restore factory settings.</span><br />
<span>26) *#8110# Software version for the nokia 8110.</span><br />
<span>(27) *#92702689# Displays - 1.Serial Number,
2.Date Made, 3.Purchase Date, 4.Date</span></span><span></span><br />
There should be a button on your TV remote that will be called "Display" or "P in P".
The display button usually displays which input you have selected, such as: SAT for Satellite; AV1, AV2, AV3 or AV4 - depending on how many inputs your TV has, to plug in devices like a VCR or DVD recorder/player.
Otherwise, if you have a more sophisticated TV, it could be that you have accidentally pressed the "P in P" button, that selects the Picture in Picture mode. If you have done this, your TV will display the main picture of the input you have selected, plus another input, (such as SAT or AV1 or AV2 etc. as I've mentioned above). If the AV1 or AV2, etc. input is not active (not switched on) then that input will only display a blank (black) picture in the top left corner of the screen.
Hope this helps...
