Question about Saeco Aroma Espresso Machine
My saeco aroma gets blocked.Sometimes he water will come out and other times it won't.
  • 3 more comments
  • aboldt Jul 21, 2008
    Machine heats up,lights indicate it is ready to run, but sometimes nothing will come out. I know water gets to the ground espresso beans, because they are wet when I give up and dump it, but nothing comes through the filter thing. I worry about the pressure build up when the machine is that hot and nothing is coming out. I've checked to see if water will run through the filter just at the sink, and I think it does. I've tried checking to see if the holes are blocked and I don't think they are.
  • Ray mcleod Sep 28, 2008
    hello, just purchased my saeco aroma and unfortunately when turned on get my expresso, water pours out from the above portafilter where it is in contact with the rest of the manchine. What is going on? Things are tight, the handle slightly turned until stiff as suggested, nothing coming out of the two nozzles towards the cups just above where the is contact, Please help me out! ray
  • Anonymous Dec 17, 2008
    I have the same problems. Sometimes the water comes out and sometimes it doesn't. My machine is only about a year old! Help!!
  • Anonymous May 01, 2009
    same problem. works okay in the morning. for some reason, in the afternoon, nothing comes out. the noise from the pump diminishes which makes me suspect its not working properly. recently cleaned machine and portafilter. possible link to temperature. when i turn it on and leave it on for a long time before making the espresso, seems to work better. was not like that when new.
  • KaffeSumpen May 11, 2010
    How old is the machine?
    how old is the filters ?
    Do you use the same kind of grinded espresso beans all the time?
Hi: i posted one of problems above (may 1,2009). the way i finally solved the problem was to use an ultrasonic cleaner to clean the portafilter. just running cleancaf cleaner through it is not enough. i ran the ultrasonic cleaner for several hours to clear all the holes in the filter and also get all the unseen gunk out of the portafilter. now, i do this once every few months and it works like a charm.
Posted on Dec 20, 2009
While the exact symptoms above are a bit vague, the problem I had with mine was roughly that: one time I'd grind the coffee and it worked fine and the next time it was just jammed and I'd have to regrind the coffee because I'd made the grounds wy too fine and the filter holes would be plugged. If I "made coffee" with an empty filter, the machine would press out water. If you use a burr grinder for your coffee you can control the particle size and most problems like this have gone away since I made the switch to a burr grinder (though changing coffee types can cause your grinder to grind a bit differerently and still catch you grinding too fine).
A 2nd related problem that reduces flow gradually over time (and which I thought was the machine's pump failing) is that the stainless steel filter will become impacted with ultrafine coffe oils and deposits over time (say a year or so, but would depend on your water supply and frerquency of use etc). There is a miraculous solution to that problem: soak your filter in a lye solution for a few hours. The lye will completely disolve those oils and your filter will be clean as new. What a relief it was for me to discover that.
Posted on Feb 02, 2009
  • 3 Answers
Hi!
Had this problem. Fixed it by taking off the O ring at the bottom of the porta filter and turning the bottom plate under the water stream. Doing that every 3 - 4 day will certainly help.
Posted on Jan 21, 2009
I have a saeco aroma coffee machine that will not turn on.. This machine has only two thermostats and no reset button visible. Could there be one inside the boiler or should I keep looking?
The Saeco Brand is under the Philips umbrella of companies. The Aroma line is not considered user serviceable beyond descaling and cleaning. However, most devices that heat water tend to have a fusible link somewhere in the power circuit. If you're already poking around inside, trace the power connection (obviously with the machine unplugged) through to the heating elements, sensors, etc. You might find a small "bit" that looks scorched or burnt.
Otherwise, it might be good to contact Saeco and see if there's an authorized repair center near you. The Aroma is definitely pricey enough not to just dump and replace like an old Mr. Coffee.
Jan 04, 2017 | Saeco Coffee Makers & Espresso Machines
Saeco how to reset
called saeco helpdesk and with their assistance found the reset button inside the machine (open the top with a screwdriver). there are three termostates. on the middle one there is a button. when you push it you hear a metallic sound. then you have to close everything and put it on again.
how to avoid this problem: it is important that there comes no air into the heater. So you have to watch the water supply carefully and leave the air out from time to time.
Sep 16, 2009 | Saeco Aroma Espresso Machine
Saeco aroma compact SE 2GR turns on, but only heats the water.
I had replace my on off rocker switch on my aroma nero after a couple of years I was able to swap out my switch for heating the steam as a temporary fix I purchased a replacement switch from Sacco at that time but I think now you might have to go to a secondary parts dealer I have kept this machine a live for over 12 years and am now going back to it after fighting with my new automatic machine sure it was easy but the taste just was not the same the kids can have it they put so junk in their coffee how would they know pbjh2o@yahoo.com
Sep 05, 2009 | Saeco Aroma Espresso Machine
Saeco Aroma steemer spit out a lot of hot water
This is normal. The solution is to let the steam wand run for a few seconds to purge all of the liquid water from the system before you begin steaming your milk. It will take about 10 seconds or so. You can do it into the drip tray, into a pitcher or bowl, onto a rag, or even on the counter. The key is not to put your milk under the wand until all of the liquid water is gone and all that is left is steam. Good luck!
Feb 28, 2009 | Saeco Aroma Espresso Machine
My Saeco Aroma Expresso machine has water leaks
I think you have to replace the gasket in the machine where the portafiller fits on the machine.
Make sure your filter is clean before you replace any gasket.
/Mirran
Aug 22, 2008 | Saeco Aroma Espresso Machine
Saeco Aroma Espresso Machine.....doesn't draw water.
You have to take a bellow pump or similary and fill with water, after that you have to open the steam knob and put force in the water from the bellow pump into the water inlet on the machine.
Hope this will help you, let me know if it works.
/Mirran
Aug 16, 2008 | Saeco Aroma Espresso Machine
No water coming out
Well on a Aroma I allways test to see if its just not air in the machine.
Turn on the machine.
press the coffe button.
Then press the steamer button ( dont turn off the coffe button.)
Do it come out hot water from the steam nossle then after a while?
Then turn of the steam button, if the filter is not blocked there should now come water from the coffe outlet.
Jul 21, 2008 | Saeco Aroma Espresso Machine
Saeco Aroma Espresso pump not drawing water
Hi Espressoless,
You have to force in water to the machine, to this you need a bellow pump or similar and force it into the water tank inlet when you do a priming.
Dec 30, 2007 | Saeco Aroma Espresso Machine
Coffee Makers & Espresso Machines Logo
986 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
