Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Ice make problem
My ice maker will not dispense ice. I have cleaned the shute and their is no blockage. It will dispense water, Also when you engage the dispenser arm the motor does not work.
  • Biker Bob Jun 26, 2008
    My ice maker makes ice and dumps the ice into the bin in the door. I can not get ice from the ice bin to the glass.
    The fridge is a Whirlpool GD25DIXHS02 it is a 2 door side by side
    Genius:
  • 1,122 Answers
I THINK WHAT YOUR SAYING IS YOU HAVE ICE AND WATER IN THE DOOR AND YOUR GETTING WATER IN THE DOOR AND NO ICE,IF THE ICE TUBE IS CLEAR YOUR PROBLEM LIES IN THE INLET WATER VALVE OR THE ICE MAKER ITSELF,YOU CAN JUMP THE WATER VALVE TO SEE IF IT SHOOTS WATER TO THE ICEMAKER,FIRST PULL FRIG. OUT,REMOVE BACK PANEL,TAKE TWO LEADS OFF THE VALVE NOW GO SEE IF YOU HAVE WATER STILL COMING OUT OF THE DOOR,IF YOU DO THESE ARE THE LEADS YOU NEED,FIND A OLD POWER CORD YOU NEED TWO CLAMP FITINGS OR GATOR CLIPS,SLIP THEM ON THE TWO TERMINALS ON THE WATER VALVE ,THEN PLUG THE CORD INTO A OUTLET AND COUNT TO 5 AND UNPLUG,NOW GO TO THE ICEMAKER AND PUT YOUR HAND IN THE WELL AND SEE IF YOU FEEL WATER IF NOT YOUR VALVE IS BAD,IF THERE IS WATER IN THE WELL YOUR ICEMAKER IS BAD,GET THE MODEL NUMBER FROM INSIDE THE FRIG. AND CALL LOCAL APPLIANCES PARTS STORE AND GET THE NEW PART,LET ME KNOW-MIKE
Posted on Jun 26, 2008
  • MIKE major Jun 27, 2008
    I DON'T KNOW WHAT MODEL YOU HAVE BUT ALL ICE CHUTES HAVE A SOLENOID THAT OPENS AND CLOSES THE ICE DOOR CHUTE LOOK UP IN THERE AND SEE IF IT HAS RUSTED AND HAS FROZEN UP,LET ME KNOW-MIKE
Whirlpool side by side refrigerator
Could be blocked up in the shute. remove all ice from the freezer and check that the ice shute (leading to the dispenser outlet) is clear. Let the freezer create a batch of ice (normally about 4 to 5 hours) and see if it dispenses then. If not , it could be a failed auger motor. That is the main corkscrew looking drive which pulls the ice into the shute. Check the icemaker in the freezer, and look for a button on the side or underneath the icemaker. Most manufacturers put one there to test the icemaker. Press the icemaker ice dispenser button and see or hear if the auger is turning.
Aug 26, 2014 | Whirlpool ED5FHEXVS Side by Side...
Tip
Ice makers that don't deliver..
whrilpool ice maker's ( bin on the door model's) makes ice but will not dispense.. ans .. remove the ice bin and rinse with warm water / also clean the delivery shute / make sure all parts are dry .. then the majic . SPRAY THE SHUTE AND BOTTOM OF BIN BOTH SIDES WITH ( PAM) NO BUTTER ) .. THIS SHOULD CONTROL THE PROBLEM . do this on a reg basis and end of problem . you can also use a food grade silcone . .. hope this tip helps **** ..
on Jul 03, 2010 | Refrigerators
Water Shute freezing up in ice maker
freezer maybe turnedup to high ck manufacturing recommendations
Feb 06, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
How to make the ice maker work
Problems with Ice Maker/Water Dispenser
If you are not getting ice, make sure the water valve is open and the ice shutoff switch or arm is not in the "Off"
position. Inspect the ice ejector arm for blockage and remove any trapped ice with a plastic spoon. If you recently
emptied the ice container, remember that it takes your refrigerator up to 24 hours to produce ice.
Low water pressure is the major cause of problems with the water/ice door dispenser. Low water pressure can cause
inadequate water flow and small or hollow ice cubes. Check the water line for kinks that may interfere with water
flow and make sure the water valve is open. A dirty water filter can color the water and ice cubes, impede water
flow or cause water to have an off taste so remove, clean and replace it.
If water is leaking from the door dispenser, make sure the water glass remains under the spout until the water
shuts off completely. If you recently changed the water filter, air that was left in the line may cause water to
spurt from the dispenser. To flush the water line, let water run from the dispenser for approximately three minutes
or until you draw out 1.5 gallons of water. Try to find a container that will fit under the dispenser spout so you
do not have to start and stop to empty the container.
Have a nice day my friend : )
Sep 04, 2011 | Kenmore Side by Side Refrigerator
My ice dispenser dispenses water but is not making ice.
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
May 03, 2011 | LG LRSC26920TT Side by Side Refrigerator
Fridge will dispense water and ice but will not make ice
You question " Fridge will dispense water and ice but will not make ice" If its not making ice then how its dispensing the ice. This is bit confusing me,-------- as per your question i assume you mean to say, that its dispensing the watyer but its not making ice. ------------
Apr 26, 2011 | Refrigerators
GE P5Hs6RGXBDSS sidexside with ice/water disp. Makes ice well but ice not propelled down shute. No blockage
Check to se that the auger is turning when you push the button for ice. If not, replace the auger assembly or the auger motor!!
Jan 31, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice cube maker not working. I saw water frozen in the plastic shute leading to the ice trays.I used a hair dryer to melt the ice in the shute. The white gear IS turning. Still no filling of water. Door...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jan 02, 2010 | Whirlpool ED2FHEXN Side by Side...
No water inflow into ice machine after turning off ice maker -
Hi, sounds sticky to me, or it wants the kids back home. But anyway try finding the travel of the tube, could have fallen off on other side, or has blockage since we have so much junk in our water today. Also although your filter is green if its good, I would take it out and clean it, not replace just clean it, and a must fine hose must be a problem, wish I was there ! Frankie!
May 07, 2017 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker Dispenser is not working.
thanks for the question looks like the ice maker does not cycle there is a electric motor that turns on to drop the ice seems like that doesnt work looks like you need a new ice maker Thanks for the questiuo The appliance doc
Sep 11, 2008 | Kenmore 53603 / 53606 Stainless Steel Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
174 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
