Question about Compaq Presario 700 470024-192 Notebook
Screen displays intermittently
My laptop screen shorts out most of the time....help
  • 41 Answers
First, plug a external monitor and toggle the screen to discard configuration or software problems. If the image displays correctly you have a problem either in the LCD screen or its connection cable.
Open the bezel and check for loose or damaged connection cable. Look specially next to the hinge.
In case the problem is not the cable you might have to get a new LCD. You can have replacement parts and instructions here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ViewObjectID=56222
Posted on Jul 06, 2008
Samsung hlr6167wx xaa
Bad main board part number BP94-01858A.
Feb 15, 2014 | Televison & Video
My screen intermittently goes blank (without lighting). I can see that there is something displayed and a connection to an external monitor shows that everything is working fine. I've disassembled the...
I've seen this problem time and time again. Replacing the inverter fixed it every time. HOWEVER it could always be the CCFL backlight as well. Both fortunately are VERY inexpensive. Changing the inverter is easy but the CCFL will be a little harder. Take your time and remember how to put it all back together and you'll save that $100. I'm sure it's either of those two that's causing the backlight issues. NO NEED to change the entire LCD.
Aug 22, 2011 | Acer TRAVELMATE 8371-944G25 LAPTOP LCD...
My display is intermittently lossing and sometimes no display at all.
i think your screen connection is loose inside you better go n hp service center and repair it coz that happen to me last time tooo
Jul 19, 2010 | HP Pavilion dv6000z Notebook
Screen blacks out while rest is still on, is a dv7-1285dx
This is a backlight issue. Either the HV/backlight board is going bad or the wires that go to it through the hinge is broken/making poor connection.
Rock the screen back and fourth. if it goes on and off, then it is the wires. If not then probabbly the board.
If it is the wires, then you will have to order the screen (off ebay) with the cable (unless you can order just the cable) or you will have to order the backlight board.
Jan 18, 2010 | HP Pavilion dv7-1285dx Notebook
Screen problems
Hi:
The next time your laptop screen is messing up, try to hook the laptop up to an external monitor. If the picture is bad on the monitor too, you have a laptop video card issue. If the picture is good on the external monitor, then you have a problem with your laptop LCD/ inverter.
Nov 11, 2009 | Dell Computers & Internet
Sony vaio vgn nr160e laptop - no display (intermittent). Attached monitor shows display fine and laptop works fine. Screen used to flicker intermittently (last few days).
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 20, 2009 | Sony VAIO VGN-NR160ET Notebook
I have some problems with the display on laptop averatec 3200 the computer is working fine, but i cant see anything on the display. the display is compleately white wen i turn on the laptop.
Problems are possibly due to wires running through the hinges on the laptop which may cause a connection problem/short. Your right. Over time the hinges which house the wires from your screen to your motherboard can wear out causing the monitor wires to have shorts. You may need to contact a professional to replace the screen or to rewire the set.
Apr 04, 2009 | Averatec 3200 Notebook
My HP dv6226tx Laptop display shows only background light.
There is a program you could use called RAdmin.When you connect the laptop to a normal PC,RAdmin allows you to see on the PC monitor what is on the laptop screen.You could possibly use this to transfer data from the laptop to a PC
Dec 15, 2008 | MSI PROCESSOR SUPPORT INTEL CORE 2 DUO...
Intermittent display problem
There's a small plunger just beyond the keyboard which switches the screen off when you close the laptop, this could be sticking. Failing that check the screen cables are secure, reseat the screen
May 18, 2008 | Compaq Presario X1000 Notebook
Compaq Presario 700 470024-192 Notebook Logo
69 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
