Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune water damage!
I messed up and dropped my zune in the toilet. Some one Help!!!
  • 1 more comment
  • cayla123 Jul 10, 2008
    i dropped my Zune in the toilet and it wont turn on please help me!!!
  • emilyalkema Jan 02, 2009
    I dropped mine in the bathtub!! After a little pounding it worked...for about 2 weeks then afraid forever! What do I do?
  • theone1321 Mar 23, 2009
    i had dropped ,my zune in the toilet (yea i know!) and then IMMEDIATELY put it under the hair dryer i did this for quite a bit. thIs was on a friday. i have left it on my radiator and i just tried plugging into the computer on sunday night. it didnt even register. CAN SOME ONE PLEASE HELP ME PLEASE!!
  • 624 Answers
You can try this, but since it has been awhile since it happened there is not much you can do to help it now. First remove any type of power to the unit, batteries, plug to the wall ect. Sometimes you can take the equipment apart, remove as much as you can safely and pat the wet areas with a dry slim towel or any other way that will remove moisture and not break and internal parts, and then right away use a blow dryer to evaporate any remaining moisture. Make sure you do not melt any plastic parts. If you have the proper chemical's you could clean the board, but that would really take a professional to do.
After that let it sit out in a safe area and if possible with some ventilation to it. Wait until the next day and then put it back together and give it a try. if you see any smoke at all, or hear any unusual sounds coming from it (popping, crackling ect.) turn it off and forget about it.
If it does start to work, it may not last long. Once the copper circuit traces and the metal leads get contaminated with moisture they will continue to oxidize even after cleaning them off. The life span has been shortened at best. And it could cause a fire or electric shock at worst.
Sorry to give you the bad news, I do wish you luck, but your best bet is to just get a new one. This one will never be the same again even if it does start working. You could end up wasting a lot of time and effort.
Posted on Jun 26, 2008
  • 502 Answers
If you can open the Zune and put it in a warm place to let it dry out. Clean the remaining residue with a brush. if that doesn't help, you most likely need a new logic board which can be replaced without problems. There are third party Zune repair services, that will fix it for cheap. Even better, I found an DYI Zune repair guide, soyoucan do it yourself too, not that difficult. Part is availableon Ebay. If you can't do it yourself, have a tech savy friend do itfor you.
Posted on Aug 24, 2010
4 Suggested Answers
SOURCE: zune
Just bought a zune and when I try to use it, it says "to start, visit" and it doesn't let me use it.
Posted on May 22, 2008
  • 68 Answers
SOURCE: my zune is not detected by my laptop or zune software.
try to wiggle the zune cord but not to hard
Posted on Nov 22, 2008
  • 502 Answers
SOURCE: water in my zune
Turn the Zune off, then push the left and up buttons as you keep it connected to the computer charger. That will hard reset the Zune. If it doesn't respond to the hard reset it is more likely you have motherboard issue, not a screen issue. Try to clean the corroded parts on the logic board. If that doesn't help, there are parts available on ebay, there is a zune repair guide that will show you how to replace the logic board.
Posted on Feb 28, 2009
How to put music from my laptop to my zune 30gb
Importing Content to Zune Software
Zune software provides several options to import content. By default, Zune software automatically imports content that is downloaded to the following folders:
  • My Music
  • My Videos
  • My Pictures
Zune software monitors these folders for the current user as well as the folders designated for All Users. When content is downloaded to any of these folders, it is automatically imported to the Zune media library.
Zune users can also add a new folder to the list of folders that Zune software monitors, or they can manually drag and drop content from any folder to the Zune media library.
download zune software for which you can sync songs
Jun 06, 2010 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
How can I sync music onto my zune 120GB without using zune softwa
the problem with the zune is that its own by microsoft and you cannot sync music without the software however there is a zune forum that you can check out for advice on how to use the software better.. then check out the forums
May 11, 2009 | Microsoft Zune JS8-00001 Digital Media...
My Zune 30GB Is Menuless...
Try this....
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
May 08, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Water in my zune
okayyy. why would you use water and soap?
You should have took a very very very damp rag and wiped it down.
You most likely need to get a new zune. BUt if your zune every gets wet somehow dont try and turn it on, let it sit for at least 24 will have better chance of it turning on then.
Apr 09, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune 4GB
your zune is screwed, the water more than likely shorted the battery out
Nov 01, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Water in my zune
Hello Rogue_45,
It's hard to know for sure but my feeling is that if the screen has water damage it is probably not going to be the only thing damaged. It sounds like you did everything right to minimize the damage as far as not powering the unit back up until it had completely dried out. However moisture may still have been absorbed by or shorted out some of the other components.
Of course, there isn't any way to know for sure without actually looking at and troubleshooting the unit. You can try looking very careful at the circuit board(s) to see if you can see any obvious signs of water damage or damaged components. If not, then you can try replacing the LCD screen and see what happens.
Best Regards,
"Go Ahead. Use Us."
Jul 01, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune brown 30 gb
I'll post an solution, IF I HAD ONE! (ill get one soon)
Feb 22, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune will not sync
Okay... what you do is Hold your zune in you right hand.. open the toilet bowl with your left.. put the zune in the toilet... and then flush it... or if you have not gotten a zune... just throw the $200+ in the toilet instead.. Because i have the same exact problem as these guys and none of their solutions have worked..
Feb 04, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Can't get my Zune software to forget my device
I had to replace a Zune that was dropped in water. I didn't bother trying to get the Zune program to forget the other Zune. I just attached it and started syncing my stuff. Did you try that? BTW I named the new one the same thing as the old one with no problem.
Jan 12, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
2,843 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
