SOURCE: connection for tv cable to hitachi 42" plasma Tv
there is no cable slot. the monitor is not a receiver. it has no tuner in it. it will need a signal from a tuner box. and that must be fed to the tv with an hdmi cable or a dvid cable for hd to work. see your manual for further information on cables. see your cable supplier for information on hd boxes available in your area. if you do not buy hd service, you will not get an hd signal. so you will see little difference from a non hd device. your dvd player may have hd capabilities, but will also need the same cable to deliver true hd signal.
the good news is that its fixable by using the right equipment.
good luck
mark
SOURCE: Hitachi CLU-4324UG remote
Yes you can put it back,by soldering it back to the circuit board of remote control....
Hope this may help;
DON'T FORGET TO RATE:
SOURCE: HITACHI CLU-5713TSI
Hi i changed the batterys in my remote and now my Hitachi tv that it came with wantwork and every other component that i have. can some one help?
SOURCE: I have an old Hitachi CLU-577TSI remote and want to program it
I solved it myself. I actually found the manuals for both the tv that the Hitachi remote came with and for our LG. The codes for programing the tv the remote came with were all two digit, like 24, 01, 34, etc. All the codes for the LG are three digit codes, 001, 210, etc. So I am pretty sure they will not speak to each other. The Hitachi is just a bit too outdated.
PROCEDURE:
(1) With Plasma turned On, Enter the I2C Service Menu: (Remember, you are doing this without seeing a picture).
Press "EXIT" once, just in case TV Guide is brought up for Set-Up.
Press "Menu" and wait a few seconds.
Press "Menu" ~ "Menu" ~ "8" ~ "Select" Buttons on the Remote:
The Service Menu is entered, even though you can not tell.
Service Menu selection you can not see
To navigate and adjust while in the Service Menu, use the remote control's Cursor Keys.
