Question about Dacor Kitchen Ranges
When trying to pre-heat my oven, It won't until serveral attempts later (maybe 10 ). Then, after baking and stopping the oven, I get an F1 error! What's going on?
  • 1,036 Answers
F1 is listed as "Element Relay circuit Failure".
There will be a current switching relay to the oven - which is faulty - hence why you get the error when it realises it's not working.
This should be replaced to solve future problems.
For your reference, the fault codes are -
F0 Touch pad stuck in depressed position
F1 Element relay circuit failure
F2 Oven temp exceeded the clean runaway temp (self clean) -or- runaway temp (cooking modes)
F3 Short circu!t in oven temp sensor
F4 Open circuit in oven temp sensor
F5 - N/A
F6 Failure in the EEPROM check comparison (only time of day and timer will operate)
F7 Failure of Sef-C1ean auto door latch circuit.
F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking Self-Clean mode.
If this resolves the issue, Please rate accordingly. Thank you.
Posted on Jun 26, 2008
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
Oven wont bake
If this is the design that the oven will click to light they generally will preheat but shut down once they go to standard bake. The oven will try three times to relight but then shuts down and will not try to light again until you reset the oven. If this is the case the oven burner itself is usually the problem. the burner comes with the electrode.
Nov 27, 2013 | Whirlpool Ovens
Oven won't heat
quite possibly the element burnt out .
Sep 22, 2017 | Dacor MCS230SS Millennia Electric Double...
I dont no how to pre heat the oven
To pre-heat an oven is to simply turn it on to the desired temperature and wait 5 to 10 minutes. If you have a timer then set the timer for the desired time you want to pre-heat then begin baking as usual.
There is no magic to pre-heating an oven and everyone that bakes has a different opinion.
Sep 23, 2010 | Ovens
I am attempting to pre-heat oven to 400 degrees but oven heat will not raise above 100 degrees
Hi, Upon reading your post I immediately thought of a bad ignitor for the oven, but I am not sure whether you have a gas oven or a conventional electric range. So...If it is gas, I'd suggest replacing the ignitor for the hot surface ignition. If it's electric the bake element may be at fault although most range's use the broil in the preheat, so it should still climb up to 400, it would just take a really long time. Maybe you can clarify if it's electric or gas and I can try to move you forward from there. Macmarkus :)
Dec 09, 2009 | GE Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Error f1 and beeping sound when the oven is on. Heating non stop.
Your digital panel may still be under warranty. It may be worth your while to have a tech look at it. Something else is going on here.
Jan 12, 2009 | Kenmore 47783 Electric Single Oven
Dacor Oven Won;t Heat
power surges can short out the electonics in appliances. If you can locate where the tech sheet is and I would say its behind the control panel on top, look at the wiring diagram and see if there are any replaceable fuse's. Or a resetable fuse for the heating element. If not check to see if power is getting to the main control bord. If there is power there you may need to replace the control.
Jul 19, 2007 | Dacor ECS130 Epicure Electric Single Oven
Kitchen Ranges Logo
384 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
