Question about GE Profile JTP18 Electric Single Oven
Oven wont turn off
The upper philement of my oven wont turn off at last i umplug the stove
The element is probably burned out and shorted to ground. This will keep it on at all times. The other possible solution is the contactor The contacts may have fused. (Usually caused by a burnt out element)
Posted on Jun 29, 2008
Screw holding metal plate above element in upper oven to the roof has dropped out. The seating in the roof in which the replacement screw inserts has no fixing to take the replacement. Please help?
I came across the same problem on a friend's stove/oven.
It turned out that the threaded plate, like a wide nut, had come loose inside the top space above the oven cavity.
Found the exploded schematic on the web, then we rocked the stove to confirm something was sliding around.
Rather than dismantling the entire stove to retrieve it, I used a 6mm stainless steel pop-rivet to re-attach the element bracket.
Dec 19, 2017 | Ovens
Frigidaire stove
Power outage could have shorted out the control panel. Call the power company and put in a claim with your insurance company. Tis happened to me & I was able to reset the oven, even with a glowing bright & dim panel. Thought everything was ok but the upper oven doesn't stay on & the oven probe doesn't work, but it's too late for me to file a claim.
Sep 05, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Hot Point Gas Stove my burners all turn on but when I turn on oven nothing seems to happen
If you have a pilotless model it is very likely that your oven igniter is bad. This is fairly easy to replace. A contunuity check will show if the igniter is bad.
Nov 25, 2013 | Stoves Ovens
Oven wont come on
Check if plates work. Assuming it is a stove. If they don't then supply turned off or main fuse tripped/melted. If they work, and oven has upper and lower element, turn on each individually. If one works and the other does not, then the cold element is probably open circuit. If neither works, then the oven fuse tripped/melted. It can be that the oven switch is faulty, especially if the oven is old, but that would be the exception, not the norm. If this procedure does not help then you need a multimeter to do some measurements - not for the regular person. If it is just an oven on it's own, check supply or fuse. Further you would need to do some measurements with a meter!
Oct 29, 2013 | Bosch Ovens
Oven door falling down on the Frigidaire stove
Try to replace the hinges the locking mechanism is going out
Feb 08, 2009 | Stoves 720EF Electric Double Oven
Oven won't light
I am assuming this is a gas stove. You probably need a new flint in the igniter. Simple problem. Check your local hardware store for flint, and refer to your manufacturer's manual for how to install it. If it's not there, a quick call to a service technician should answer the problem. hope this has been helpful.
Oct 24, 2008 | Ovens
Oven does not work
According to the manual, the self cleaning latch could be stuck.
If the oven door is open, press STOP/CLEAR to clear display, then depress and hold switch plunger for 6 seconds (Located in the upper right corner of the oven front) and the oven door will unlock.
If the oven door is locked, press STOP/CLEAR to clear the display then apply pressure to the upper right corner of the oven door and the door will unlock. If the "F" code reappears, contact a Sears trained repair specialist.
Sep 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Aug 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Oven not working
Remove the bottom panel from inside the stove. Turn on the stove and see if the igniter glows bright red. If not glowing, replace the igniter. In some cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. In either case the igniter has probably gone bad. ($50.00 to $90.00 for igniter)
May 27, 2008 | Ovens
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
121 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
