Question about Sprint BlackBerry 8703e Phone
Trackwheel the trackwheel stopped working and now i cant use most of the features on y phone can i fix this?
  • Pyr0dyn3 Mar 24, 2009
    i have the same issue, the 8703e has a track wheel on the right hand side of the unit, i'm having to go through sprint to obtain a replacement, the nearest option the rep could use as a replacement fail-code was track wheel sticks. as a precursor to the track wheel going out, it would move the cursor all about the screen, sometimes passing over the wanted option 6 times before i could finally luck out and select the item i wanted. rep stated could have phone out 2-3 days. best bet is replacement imo
  • 2,794 Answers
Is that model have a trackball on it or a wheel on the right side of the unit?
Posted on Nov 12, 2008
How do you text on a black berry 7290
Thanks for giving Fixya the pleasure to solve your problem.
1.In a messages list, click the trackwheel.
2.Click Compose SMS.
3.Click [Use Once].
4.Click SMS
5.Type the SMS-compatible phone number.
6.Click the trackwheel.
7.Click Continue.
8.Type a message.
9.Click the trackwheel.
10.Click Send.
If you have added contacts to the address book, you
can select a contact from the list after you click
Compose SMS.
To send an SMS message quickly from the phone, type
an SMS-compatible phone number. Click the
trackwheel. Click SMS<XXXXXXX>.
Check out the manual from this link.
Rating the solution is highly appreciated if you feel helped.
Good luck and have a nice day
Jun 17, 2010 | RIM BlackBerry 7290
Tip
BlackBerry Tips : copying and pasting text
Press the <b>Alt key</b> and click the trackwheel.scroll button to select text. To copy selected text, press the <b>Alt key</b> and click the trackwheel. To paste the selected text, place your cursor in an editable field, then press the <b>Shift key</b> and click the trackwheel.<br /> <br />
on Dec 14, 2010 | Cell Phones
Tip
Blackberry - Unable to receive email but able to send.
(For Blackberry Enterprise Service only)
Verify if the folder redirection is set up correctly.
Please follow the provided steps and verify that the Inbox is selected to display:
1. With the BlackBerry, go to the Messages screen and click the trackwheel.
2. Select Options, and then select Email Settings and click the trackwheel.
3. From the Email Setting screen, click the trackwheel and choose Folder Redirection.
4. Select Mailbox-Your Name and click the trackwheel. Choose Expand from the list and click the trackwheel again.
5. Use the trackwheel to navigate your folders; click the trackwheel to select the Inbox folder.
Note: this steps are in general and may not have the same UI for newer version of Blackberry but the concept is the same.
If this did not do the trick next will be re-sending of service books and IT policy.
on May 07, 2010 | Cell Phones
Blackberry call barring
To disable call barring
1. On the Home screen, click the Phone icon. The Phone screen appears.
2. Click the trackwheel to view the menu, and then click Options. The Phone
Options screen appears.
3. Click Call Barring. If your SIM card is provisioned for call barring, the Call
Barring screen appears.
4. Select the call barring option that you want to disable and click the trackwheel
to view the menu. Click Disable.
5. Click the trackwheel to view the menu, and then click Save.
You return to the Phone Options screen and your call barring option is disabled.
Jun 19, 2009 | RIM BlackBerry Bold Smartphone
Cant get main page to come up
Turn off Content Protection before manually erasing all data and applications from the BlackBerry smartphone, in order to avoid triggering the scrubbing process:
1). On the Home screen of the BlackBerry smartphone, go to Options > Security Options.
2). Under General Settings, go to Content Protection.
3). If Content Protection shows as "enabled," click the trackwheel of the BlackBerry smartphone and select Change Option to turn off, or "disable," Content Protection.
4). Click the trackwheel again to save and close.
Once scrubbing has been triggered, there is no way of stopping it. The process must be fully completed before the BlackBerry smartphone may be used. Removing and reinserting the battery of the BlackBerry smartphone will only start the scrubbing process again from the beginning.
The duration of the scrubbing process depends on factors such as the actual processor speed of the BlackBerry smartphone, the amount of memory that it has, and the actual memory speed.
Apr 30, 2009 | T-Mobile BlackBerry 7105t Cellular Phone
How do I stop my Blackberry going on to standby
I don't know what you are referring to when you say STANDBY option, so I'll include what I know about the password option. Maybe you mean SECURITY TIMEOUT, or maybe your version calls it standby time..
Setting up a password for the device:
Scroll to select the SETTINGS/OPTIONS icon and press [Trackwheel] to select.
Scroll to select SECURITY OPTIONS and press [Trackwheel] to select.
Scroll to select GENERAL SETTINGS before getting the next menu.
Scroll to select the PASSWORD It should say ENABLED.
For most people the security timeout is set to 1 HOUR.
Setting up the time it takes for the BB to require a password:
Select the line you need to change, and Press [Trackwheel] to access the Menu
CHANGE OPTION should be highlighted Press [Trackwheel] to select.
Scroll UP to select ENABLED and press [Trackwheel] to select.
Scroll to select the SAVE and press [Trackwheel] to select.
System responds with NEW PASSWORD: input your new password press the <-| key.
System will ask you to re-enter your NEW PASSWORD: input your new password again and press <-| key.
Mar 09, 2009 | RIM BlackBerry Bold 9000 Smartphone
How can i configure message services to text someone?
First, I assume you have a service provider, a valid cell phone number and that your service provider has enabled text messaging as part of your plan.
To send a text message, go to "Messages", then click "Compose SMS", "[Use Once]", "SMS".
Type the cell phone number of the person you want to send the message to.
Click the trackwheel, then "Continue".
Type a message.
Click "Send".
If you still are not able to send a text message, you need to verify that "fixed dialing mode" is not enabled. To do that:
Go to Phone Options.
Click "FDN Phone List".
Click "Disable FDN Mode".
Dec 29, 2008 | RIM BlackBerry 7290
Blackberry 7100g
About fixed dialing
If you enable fixed dialing number (FDN) mode, your device only makes calls to contacts on your FDN list. Your device can dial emergency numbers in FDN mode, even if the numbers are not in the FDN list. If your service provider plan includes SMS, you can also send SMS messages to contacts on your FDN list
so if you have this enabled chances are you have to turn it off.
this is how you turn it on so you should be able to use it as a guide to turn it off.
Turn on fixed dialing
1. In the phone options, click FDN Phone List.
2. Click the trackwheel.
3. Click Enable FDN mode.
4. Type the PIN2 code provided by your service provider.
5. Click the trackwheel.
or if you wanna keep it on and add friends to the fdn
Add contacts to the FDN list
3. Click New.
6. Type a name and a phone number.
7. Click the trackwheel.
8. Click Save.
and finally some shortcut keys:
To open the phone, press the Send key.
To end a call, press the End key.
To call a selected contact or phone number, press the Send key. To call a speed dial number, hold the assigned key.
To add an extension to a phone number, press the X key. Type the extension number.
To call your voice mail access number, hold 1.
To type a letter in a number field, hold the Alt key.
To type the first letter on a key, press the letter key once.
To type the second letter on a key, press the letter key twice.
To turn on or turn off mute using the Mute button, press the Mute button.
To turn on or turn off mute using the keypad, press the exclamation point (!) key.
To turn speakerphone on and off during a call, press the period (.) key.
To change the volume during a call, roll the trackwheel.
Aug 02, 2008 | RIM BlackBerry 7100G Smartphone
8700g trackwheel
My Friend, the trackwheel Seems to be Broken. I got same problem as well, i decided to open my BB 8700 and got that one part of the trackwheel in broken, hense dosen't suport the other part when Presing. Need to Replace it !!
Check out this itemon ebay : http://cgi.ebay.com/GENUINE-BLACKBERRY-8700-SERIES-JOG-DIAL-SCROLL-WHEEL-US_W0QQitemZ120356507324QQcmdZViewItemQQptZPDA_Accessories?hash=item120356507324&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Regards
Sameer Tarawneh@Mail.Ru
Jul 01, 2008 | RIM BlackBerry 8700g Smartphone
Connectivity problems with my Nextel Blackberry 7100i
I am not sure this is what solved my problem but it worked after I did this. When you enter the 0000 code, make sure to hit the enter key and not push the trackwheel. That made the connection work.
Oct 29, 2007 | Motorola Mobility H700 Wireless Headset
Sprint BlackBerry 8703e Phone Logo
276 people viewed this question
Top Sprint Computers & Internet Experts
Computer Repairing
Computer Repairing
matt
matt
Are you a Sprint Computer and Internet Expert? Answer questions, earn points and help others
