Question about HP LaserJet 2550L Printer
HP Laser Jet 2550l
The Printer has been stored for 3 months !
When tried it the paper fed thro' ok but had a sticky substance on it. When checked the cartidges they all had more 40% including the toner.
It now prints on the left side of the page but only Yellow & Black.
    Problem Solver:
  • 25 Answers
When moving/storing Laser printers, its suggested that you remove all Toner Carts prior to the unit being moved. The Toner "Dust" (If you will) will settle in the bottom of each cartridge, and become compact. (When LJ's are used on a normal basis, the toner is tumbled around like clothes in a dryer).
Sometimes just turning (Shaking?) your toner carts will help the toner flow better in the drum.
I hope this helps you a little.
Posted on Aug 14, 2008
I wish to clean rollers
Go to an office supply store and ask for printer cleaning sheets. These are heavy paper with a sticky substance on both sides. You run it though the printer a couple of times to pick up the paper dust off the rollers and the paper path in the printer.
Feb 20, 2016 | HP 564 XL Series Ink Cartridge Set for...
Laserjet pro black vertical lines using adf
Do regular prints look ok? If so, then try copying something from the flatbed glass. If that copy has no line then you have something on the glass where the paper passes over when fed through the adf, clean the glass well, you may need to use some rubbing alcohol because often fine bits of adhesive from things like sticky notes will cause the lines but are not obvious to the eye when you inspect the glass.
Jul 31, 2014 | HP LaserJet Pro 400 Color MFP M475DN...
My HP color Laser Jet 2600 printer has a paper jam
Jul 21, 2014 | HP Office Equipment & Supplies
My HP laserjet 2550L is set on Amercan 'letter format' after a reset. I want to print on A4 paper which causes a problem after a few pages. If I change to A4 in the toolbox, on the surface it looks ok but...
Hello,if you are using Microsoft Word, check the page setup and printer settings in Word as you have the option there to change paper size as well as on the printer.
Hope this helps
nicam49
Jan 17, 2011 | HP LaserJet 2550L Printer
Waktu ngeprin sekali lancar setelah itu paper jam atau kerta ngegulung
1. Check and/or Remove Paper from top output assembly.
2. Clean pick-up roller if it appears to be dirty or have sticky substance, etc. Replace roller if worn or damaged.
3. Check if the top paper output and rollers are free of damage.
4. Cycle Power or partial reset printer
5. Put only 10-25 sheets of plain white letter size paper in the input tray
6. Flip the paper stack over to verify printing on correct side.
Please follow the below web link steps
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00311028&cc=us&lc=en&dlc=en&product=439320&tmp_track_link=ot_search
Dec 28, 2010 | HP LaserJet 1020 Printer
Automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Sep 06, 2007 | Samsung ML 1210 Laser Printer
HP LaserJet 2550L Printer Logo
71 people viewed this question
Ben Johnson
