Question about Frigidaire FGQ332ES Gas Dryer
Dryer Won't Start
My Frigidaire Gas Dryer quit.  When the start switch is turned a sound like a jammed buzz comes from the motor and then a thunk from the circuit board.  I would assume the motor is the problem but when the timer is turned to say 30 minutes I believe it used to turn on its own whether the dryer was on or not ( am I right?).  Now it dosn't turn at all.  I have pulled the motor but do not know how to test it.  There are 2 circuits - Start - red and black wires and Run - tan and yellow/brown.  I could hook it to 110v but I'm not sure which is the neutral and which of the colors to hook up for it to run.....   and then am I right about the timer?                                              Perplexed
Use a isolated transformer and just hook up the wires that you think are positive and negative. isolated transformer is so that you do not get killed by a shock
Posted on Jul 07, 2008
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Dryer buzzes but won't start
see the diagram :
1) O.k if the thermostat 2) Thermofuse is o.k is good resultant BUT please 3) Test the door switch for open or defective , if the remain open the motor will NOT START. see the diagram. 4) After changing the switch if the problem remain the same the motor is faulty( centrifugal swithc, etc) need repair or replace. 5) Test the push button start for diryt or open, test the wires for loose, broke, or burn wires too.
God bless you
Jun 09, 2012 | Whirlpool LER4634J Electric Dryer
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
When we press the button to start the dryer, we hear the buzzing but the dryer does not move.
assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Jan 09, 2011 | Frigidaire Electric Dryer
Dryer has power. When the start switch is turned,
Sounds like start winding inside the motor, or a start switch attached to the motor itself.
Jun 22, 2010 | Frigidaire GLEQ642A Electric Dryer
Buzzing noise from dryer and wont start
It sounds like your motor has gone bad....it will buzz really bad when it is trying to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 12, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My frigidaire dryer model NMER336FSO just out of the blue quit working. When I hit the start button i can hear a loan buzz, but it wont turn on.
It sounds like your Frigidaire may have one or more problems. If your push to start switch is defective then it will have to be replaced. You can test the switch itself by FIRST disconnecting power. Then taking the switch out and setting a voltmeter to test for continuity, then pushing the start button to see if there is on and off contact being made. Part number for the start switch is 131469000. If this is okay and you are hearing a buzz or low grumble noise coming from the motor area. this could indicate a bad motor winding and would probably have to be replaced. part number for the motor is 131560100. Sometimes however the motor can become seized or dirty connections to the motor can occur due to debris or dust bunnies. so make sure the dryer is CLEAN. If you give the drum a turn yourself manually, while trying to start the dryer this can sometimes give the motor the kick it needs. however this is only a quick fix, and not permanent. You have a well built simple dryer, and there isn't a whole lot that can go wrong with it. Hope this helps
Thnaks.
Nov 05, 2009 | Frigidaire Dryers
Dryer wont start
open door and spin drum to left then right.
Oct 02, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryer will not start
Hello jslovik,
Welcome
You said, When you turn the knob a buzzing sound starts but that's it. The Buzzing continues as long as the start button is turned. Dryer is only 2 years old. Any help is very appreciated.
It sounds like the starting switch is bad!
10 134398300 Switch,start ,turn type In-Stock $ 11.29It appears in the diagram at the page below in diagram # 10
http://www.pcappliancerepair.com/model-display.php
If you do not know to diagnose this or repair it, please call an authorized tech.
Let me know what you do and how it goes for you?
Huuum
Believed I solved your question.Happy to have been of assistance.
Please remember to leave a rating.
Sep 19, 2008 | Frigidaire FGQ332ES Gas Dryer
Gas dryer
sounds like a bad motor, test capacitor first. also check rollers
Jul 01, 2008 | Frigidaire FGQ332ES Gas Dryer
Frigidaire FGQ332ES Gas Dryer Logo
64 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
