Question about Epson AcuLaser C900 Printer
Epson C900 stops print prematurely, color problems
Hello all,
I just got an Epson C900 working - sort of ;). It refused to take any paper, and I noticed that the paper feed tray (the one built-in) did'nt raise the tray as I supposed it should. I then saw that there was a fix for the Minolta MagiColor 2300 (basically the same machine as I understand it), basically that you just had to push ******* the paper tray down to the bottom to release some sort of solenoid connected to the tray assembly. Sure enough, the fix worked!
Now that I have the printer feeding paper from the tray, it goes through the printer, comes out at the top - but just before the sheet of paper is released (ejected) into the collection bay at the top, it stops! The paper seems almost fully printed, but why does it stop there?
Aditionally, I'm having problems printing color on it. In color modes (not monochrome, that seems to work somewhat) only some faint shades of blue appear, a hint of red and no yellow. This is reported in several places in these forums. There was a timing problem mentioned, maybe this has something to do with it. I have tried manipulating the timing roller.
FYI, the printer has been standing unused for at least 6 months in a dusty space at work, probably getting some kicks from people passing by.
I got it printing, now the goal is to make it print resonably. Any help very much appreciated!
Regards,
Patrik (Sweden)
  • 1 more comment
  • Patrik Nordlund
    Patrik Nordlund Jun 26, 2008
    Adding some more info:
    1. When the paper stops ejecting, the printer reports "paper jam". However, it is very easy to pull the last bit out of the printer, so it isn't really stuck. Maybe not important, but maybe good to know.
    2. I was thinking that the faint color printing problem and the premature stop of ejection is realted? Maybe it stops printing BECAUSE of the bad printing results? Also, the image transfer belt and the drum have the printed page clearly visible left on it. Could the printer detect this and stop printing because of it? I'm sure there's a lot of waste toner in there, as almost none of it sticks to the paper sheet :P.
  • simonITE Jul 08, 2008
    C900 will not fully eject paper (last 2 inches or so) paper has been printed and fused correctly, i cannot see any flags at the output, just get red flashing light and screen says pape jam... any ideas ??
  • colalight Nov 18, 2008
    hello!
    same problem as above :(
  • 43 Answers
SOURCE: Prints gobble-de-gook
try another USB port
Posted on Jan 23, 2008
edandgreta
SOURCE: paper won't feed
My CX4800 developed the same problem. It was an excellent machine until then. I tried everything I could think of, and finally decided it must be the rather large feed in rollers at the right of the paper bin (one below and one above the paper) that had worn too smooth to pull the paper in. It works fine if I will give the sheet a "push" when it starts to go down - but who has time to stand there and push each piece in! It would really be nice if Epson would provide us with inexpensive replacement rollers and instructions for installing them. Guess they had rather we just buy a new printer - which I did, a CX7800, only to find that it will not take the heavy weight photo paper. :-(
Sorry I couldn't help more.
Posted on Aug 04, 2008
SOURCE: paper will not feed through - epson DX4000 printer/scanner
Did you check the thickness? My printer won't feed paper that's to think or thick properly it sould say in the manual what thickness of paper you should use.
Posted on Mar 24, 2009
aicaxz
  • 511 Answers
SOURCE: epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Posted on May 30, 2009
SOURCE: hello.i have a problem with my printer epson
sell
Posted on Feb 11, 2010
Problem printing multiple copies of a single page document
I have a similar problem with an old HP LJ1300. They have not updated the driver correctly and don't intend to fix it. I can't find any reference to AcuLaser C900 on Epson's support page. So maybe they stopped supporting the C900.
May 06, 2010 | Epson AcuLaser C900 Printer
Paused?
The printer probably went offline, as far as your PC is concerned. On your PC, in the properties for that printer, click File and UNCHECK "Work Offline"
Oct 29, 2009 | Epson AcuLaser C900 Printer
Papr Jams and wrong size report
We just solved this problem with our c900.
Basically, a paper jam has caused some probs with the sensors and rollers. After playing with the thing for about 4 hours, i ran some really thick photo paper through it and after a couple of trys where it just screwed up in the back, it then fed through and printed correctly. After that it was fine with all paper types, no more messages, and no more paper getting screwed up in the back. Ian
Jun 19, 2009 | Epson AcuLaser C900 Printer
Colours not mixing properly
reset the printer.
open th right door,without paper then close the door
it work
Jun 07, 2009 | Epson AcuLaser C900 Printer
HELLO PRINTING FADES RIGHT HAND SIDE OF DOC ANY ADVICE ,THANKS IN
Hello I have sorted the growling sound out with a shot of WD40 lube ,but have not sorted out wht the cyan does not print clearly any advice would be helpfull
Nov 14, 2008 | Epson AcuLaser C900 Printer
Epson C900 print shifted down page -
OK after messing about with the drivers I got it to work. I downloaded a driver from Epson singapore and it made no difference. So, I re used the driver from Epson UK and hey presto the thing works again. Why? Good question. Maybe the people in Epson have no idea either.
So, I suggest deleting the driver rebooting the system and reinstalling it. I hope you get it working.
Oct 08, 2007 | Epson AcuLaser C900 Printer
Not printing
there is paper jam or there is the dust in some sensor
Sep 12, 2007 | Epson AcuLaser C900 Printer
Epson AcuLaser C900 Printer Logo
229 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
