Question about Saeco Talea Touch 14-Cup Coffee Maker
Grinder says no coffee beans after grinding, why?
My Talea Touch machine was working beautifully for quite some time, however it now seems to want to grind some beans, not brew any coffee, and say there are no beans. Could the grinder be "blocked" by beans? How do you clean the grinder? My machine seems to eat the beans and not want to give any coffee to us!
  • peter96462
    peter96462 Jun 12, 2012
    I have a similar issue, like ever third or second grinding fails and the machine says "Fill container with coffee"
    New Friend:
Where is The grinder conector At?
Posted on Dec 26, 2015
  • 74 Answers
Does it realease the grinded coffe beans in the dregdraw with out using it?
if that is the case it a very small electricboard on the grinder that has stoped working or the connecter has fallen of from it.
Posted on Jul 11, 2008
  • Slawek
    Slawek Oct 29, 2013
    Can you please specify the location of this board, thanks.
Talea ring the grinder will not stop gringing
The Talea model is with a Ceramic grinder system. This can happen when the grinder outlet is clogged with coffee grounds. Fresh beans cannot enter the grinder as the outlet is clogged. Remember, the grinder in any machine is a grinder. It does not shovel the coffee grounds out and clean the outlet when it is clogged.
1- Check if the grind setting is too fine (powder like). If so change the setting to coarse. Fully automatic machines do not need fine grind. Keep the grind fineness like the table slat grain.
2- Check if the beans are dark roast and oily. Oily beans are a slow poison for any fully automatic machine. Change the beans to Non oily medium roast type.
Oct 16, 2014 | Saeco Talea Ring Plus Espresso Machine
My delonghi esam5500 coffee bean grinder part is not working. seems to be blocked, can see beans moving when it goes to grind but no beans are taken in and it comes up with fill beans compartment? what...
In our case we were lucky. Grinder was blocked by the beans. This is what I have done with our Delonghi 5400. It looked fiddly but was quite simple really. I started from the back panel. Once back panel was removed I had access to 4 corner screws that remove both side panels. Now that give me access to 4 corner screws that hold top of the machine. I l also had to unscrew 5 screws that hold coffee container in place. 4 are visible once the coffee beans container is open, but the 5th is hidden in the middle of adjustment arm with a black cap on top.(adjusting how fine you grind). I used small sharp screwdriver to lift the cap. Once all are out I removed the top of the machine and then the funnely coffee container too. That exposed grinder assembly. Top of the grinder is actually loosely sitting in the lower part of grinder. Twisting it counter clock should release it I Think. Our was not budging, and I had to completely remove the grinder and detach motor but that is quite obvious too, and probably not needed. I just wasn't sure what I was doing. Our machine was out of warranty so... Would be nice if we had some schematics.
Nov 26, 2010 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Talea Giro - Will not grind coffee
Does the spindle spins when you do the grinding? If not the parts in the grinder is broken. If the spindle still spins and you get sort of wood chip grounds, the adjusting wheel has come off the grinder when you adjust the grinder too coarse.You can undo the grinder if you know how to open the machine. Go to my Odea solutions and look up step by step instruction on how to. Itis very similar.All the best.
Jul 11, 2010 | Saeco Talea Giro Espresso Machine
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
Saece Talea - Dispensing failed
Take out the brewing unit and clean it in hot water.
/Mirran
Aug 30, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco magic de luxe grinder problem
Hi Cindy,
Make sure you not get any water in the grinder, if you get water in the grinder then it bean smeary and will not grind the beans.
You have to clean the grinder if you get any moisten in it.
/Mirran
Aug 17, 2008 | Saeco Magic De Luxe Espresso Machine
My Saeco won't grind the beans
There's moisture in the grinder & it's clogged - just dismantle the grinder & clean it, then ensure you don't splash water into the bean hopper when you fill the water tank.
Mar 29, 2008 | Saeco Magic De Luxe Espresso Machine
Bean hopper is full, grinder is grinding...but NO COFFEE!
Sometimes the chamber between the grinder and brewer will clog up. Try: Open the grind all the way up to the highest number. Push the grind button and while grinding move the dose knob (the one with the + - sign toward minus. If it does not kick in and dose try it again. If it does take off then leave it on the high number for 3 coffees. Then while the grinder is turning move the two knobs back to whre they were. If this does not work you can reomve the brew unit and right above where it sits in the machine there is a trap door that you can open. Open it and shove someting like a straw up toward the grinder and you should get a bunch of grounds droppiing down. Then try the above procedure a couple more times. If this does not work you may need to google "Saeco repair" and send it to an authorized repair center.
Aug 15, 2007 | Saeco Vienna Digital Coffee Maker,...
Saeco Talea Touch 14-Cup Coffee Maker Logo
599 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
