Question about Motorola Mobility RAZR V3i Cellular Phone
Wet celphone a month ago, my celphone accidentally got wet with a small amount of orange liquid detergent and now, it won't work. when i try switching my celphone on, all i get is a blank white screen and few seconds later, it dies. even charging won't help. is there still hope of recovering my celphone?
My phone fell in water and I immediately removed the battery and placed both the phone and battery in a deep bowl and covered everything with rice including rice underneath the phone and by the next day it worked fine and I had no problems since them. I'm not sure if this will work for you as your incident happened a month ago but it is worth a try.
Posted on Jun 26, 2008
I take my battery out of my phone and blow dry the phone and the battery. once my step daughter even dropped it in her bath tub and it still worked when i did that. its worth a try.
    Sergeant:
  • 260 Answers
Not really. It is time to get a replacement.
Build up of dirt in tub making clothes dirty... How do I clean inside of machine?
If you use powder detergent ( clay carrier) the build up is from undissolved powder ( clay)
It forms cakes between the spin tub and the outer bowl
The fix is to pull the washer apart and physically remove the caked up mud from all parts of the machine
The prevention of future mud is to use liquid detergents rather than powders
It works like this powder detergents have a small percentage of actual detergent in use and that is dried onto a clay base as a transporter agent
In the wash , the detergent is released but the clay will not dissolve
Most is pumped out with each spin but a certain amount remains , dries and starts the dirt process through the clothes
With liquid detergents there is the same amount of actual detergent but the carrier is water and that is diluted in the spin and completely flushed away
Dec 30, 2015 | Washing Machines
How is liquid detergent dispenced into the dishwasher
What type of dishwasher is this? Is this one of those GE dishwashers with the large resevoir that you fill only once a month of so, or a normal one with a small resevoir that you fill each wash? In either case, there is a relay that either dispenses (pushes out) a certain amount of detergent, or else a relay or "wax motor" that opens the lid during the main wash period.
Mar 22, 2015 | Dishwashers
Would using to much liquid detergant remain in dispenser draw if to much detergant is used
clean your dispencer as you could pull it out and clean it with tooth pick and worm water
Dec 10, 2013 | Kenmore Washing Machines
My Samsung SGH-A797 won't turn on and I'm not sure why.
Look for a liquid contact indicator under the battery usually pink or orange if tripped. Usually looks like a white dot. If it won't come on at all and when plugged into the charger it's highly probable that it got wet at some point. A small amount of water can do a big amount of damage. 11_17_2013_9_56_57_pm.png
Mar 04, 2013 | Cell Phones
What causes a bad smell to come from a washing machine
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very,very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
Dec 12, 2010 | Washing Machines
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
Nov 25, 2010 | LG Washing Machines
What is the partion insert for the washing powder container for?
Welcome to FixYa.
That is the Liquid detergent partition...P/N 8061633. ( part number )
**This from ASKO...
Because ASKO washers use less water than conventional top-loading washers, you need less detergent and fabric softener. We recommend that you use a low-sudsing powder detergent only, preferably a high-efficiency (HE) detergent designed specifically for front-loading washers.
**(Liquid detergents tend to suds more, which make them more difficult to rinse out.)**
Detergent - The amount of detergent needed varies, depending on the detergent you use. For high-efficiency detergent specifically for front-loading washers, you should use the amounts recommended by the manufacturer.
Also, the amount of detergent needed can vary due to differences in water hardness. (Refer to the Use and Care Guide for more details.) If you choose to use a liquid detergent, start out with a very small amount, such as one or two tablespoons.
Hope that answers your question, let me know please.Thanks for choosing FixYa for your repair solutions today. Let me know if you need further assistance.
Please take a moment and rate the solution provided for you as well as a testimony if you feel it warranted.
Good luck.
Regards,
Macmarkus :)
Oct 22, 2010 | Asko W6021 Front Load Washer
Water is pouring out of the detergent dispensing drawer from my 1 year old Samsung clothes washer model WF328AAW. When I opened the drawer, it was full of water. Something must be plugged. Is there...
Pull the drawer out you will find detergent has built up in side the dispenser probably from from way too much detergent, modern front loaders work best with a small amount of detergent and liquid detergent normally will wash better.
Apr 17, 2010 | Samsung WF203ANW Front Load Washer
Mold buildup around interior of drum - odor and spots on clothes
Posted in 2008
I've had my Duet for 5+ years with no odor until the past 6 months or so. Even changing to a more fragrant fabric softener didn't make my cleaned clothes and towels smell clean. I noticed it especially when I would grab my towel after a shower. For a while I thought someone else was using my towel and stinking it up. Then I realized it was the whole laundry. ( I was having my laundry done for me... otherwise I probably would have realized it sooner. After reading all the suggestions for resolving this sour odor I thought I would try some of the ideas suggested that I hadn't already tried. Then it dawned on me that about 6 months ago I switched from a powdered detergent (SA8, an Amwy/Quixtar product) and dryer sheets to a well-known well-ranked Liquid Detergent and a fabric softener. I only switched because my son like the way his friend's laundry smelled when he borrowed a shirt. I was using fragrance-free products. So I had fragrant laundry for a short time. Then it started to smell sour. Maybe this change was the cause. So I've ordered another box of the powdered detergent and I'm going back to dryer sheets.
In the meantime I'm still doing stinky laundry. Same day I order new detergent, I decide to wash a load with some very stained baseball pants. I sometimes use a small amount (1/4 cup) of Oxy Clean, with my detergent but I decided to go full-strength which on the box said 1 cup. Hot water wash. Put it in with the clothes. Same liquid detergent, no fabric softener. When I took out the laundry, for the first time in months, it smelled clean. No stale, sour odor. Next load, nice smell again. Decided to do one more load with 1 cup Oxy Clean again. I'm still going to switch back to the SA8 (which is by the way highly ranked by Consumer's reports) and dryer sheets.
By the way, a few weeks ago I had to disconect the water discharge line behind the washer. The sludgy goo that was in the line and machine where the two connected was disgusting, but didn't smell bad. I cleaned it out with my finger. Ugh!
So it's now several months later. My clothes smell clean, as does my washer. I switched to powder and only occasionally use liquid softener. Still occasionally use the full dose of Oxyclean with a hot load. I occasionally wipe down the door and seal... especially the bottom of the window, and always leave the door ajar when not in use.
May 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Detergent in clothes
How much detergent are you using? I'm wondering if there is a residual amount of detergent left in the washer. Does it have a dispenser? If your washer has a dispenser for liquid detergent you could try pouring a small amount of really hot water into the dispenser to ty to clear it. Then try running a small empty cycle or two with plain cold water. Remember not to ever use more detergent than is recommended for your washer.
Thank you for using Fixya.
Aug 20, 2008 | Fisher and Paykel GWL11 Top Load Washer
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
