Question about Bose VCS-10 Center Speaker
How do i open the speaker to reconecct the wires inside?
My speaker hit hard th e floor and the rear speaker conector jump out i try to push it back but there is no sound? how can i open the speaker to reconecct thw wires inside
There are no screws on this speaker. This speaker cabinet is two pieces. The Bottom plate has all the internals fixed to it and the sides and top are glued to the bottom piece. It takes some doing but the glue bond can be broken. The wire connector posts (Red and Black) connects directly to the vertically mounted soundboard. These post are not soldered so if that electronic soundboard jostles out of its frame rails, the post will lose connection. The post assembly snaps out and I would remove it prior to taking the cabinet apart. It is all very simple and obvious if you get the cabinet open.
Posted on Jan 12, 2010
  • Bose Master
  • 5,568 Answers
It may not be only wires loose; the speaker(or speakers) may be damaged.
The common 'dynamic' speaker has a centered magnet in an assembly that extends the field of the magnet around a coil of wire on a form called the 'voice coil' that is firmly attached to the cone which moves in and out to 'pump' air and produce sound.
The clearances (gap) between the magnet assembly and the voice coil that sits in a narrow space between the magnet and the outer field piece is very small and critical.
Once positioned in the factory, glue is used to keep the field assembly from slipping and rubbing against the voice coil.
A strong shock will break the glue bond and, if severe enough, clamp the voice coil so it cannot move freely any more.
Since the Bose is a quality product, the cabinet may be assembled with glue and screws that are concealed.
If you know someone with a simple multimeter, they may be able to check at the terminals to see if there is any continuity from the terminals to the speaker.
If it doesn't have any, then perhaps only a wire is broken between the terminals and the speakers.
There is with high probability also a filter inside that separates the frequency range and sends the signal to separate speakers that produce different ranges of sound.
Posted on Jun 26, 2008
Audio Wire Diagram
2003 Nissan Murano Car Audio Wire Guide
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Pink/Black
Car Radio Ground Wire: Chassis
Car Stereo Antenna Trigger Wire: Green
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Inside the trunk, under the floor covering.
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): Yellow
Right Front Speaker Negative Wire (-): Brown
Car Audio Rear Speakers Size: N/A
Left Rear Speaker Positive Wire (+): Orange
Left Rear Speaker Negative Wire (-): Black/Pink
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Black/White
Oct 31, 2012 | 2003 Nissan Murano
2010 vw cc trunk will not open from remote or from inside latch
Ran into the same issue with our 2010CC (not Jetta) as in one of the posts. our problem was both the trunk wouldnt open and the rear fog light wouldnt iluminate. traced wires back to compartment that houses battery. in that space the wiring harness from the trunk lid terimates in multiple conectors. before they do that the wires pop out of the trunk lid support. The support had worn the wires through and 3 of them had been cut through. There are 10 brown wires in gthe bunch of 3 -4 different sizes. Check that area for conection problems.
Oct 09, 2012 | 2010 Volkswagen CC
HELP MY HARD DRIVE HAS GONE!
Ok to understand this , you dropped a 1 TB hard-drive external hard drive on the floor? Well considering that it is a external, the cases in most externals are meant to take a beating as well as the hard-drive it self. There is two possiblities I can think of, what could of happened. When the Hard-Drive hit the floor, it could of is disconnected the connection on the hard-drive itself inside the casing, which you will have to pop it open and reseat it. Or the hardrive, arm inside the hard-drive it self snapped or is misplaced, which is unrepairable. Open up the casing and looking for the hardrive it self. Towards the back of the hard-drive is where the connection of th drive is, it is eather sata or orginal set up with his pins based. Take the connection off and put it back on and see if that works, if it didnt, best advise would be is take in in and have the drive tested, see if its still operable.
DrakeTech
Feb 25, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My jeep wont start. i turn the key no crank, full battery. any ideas. tried to jump it nothing.diconected and reconeccted the batery still nothing. car was starting perfect no problem. Checked the shifter...
Just, Because you removed the battery connections and reinstalled them
will not repair a bad battery conection. Sounds like you have a bad conection at the battery. You'll need to remove the battery ends and clean
them with, a wire brush or a battery cleaning tool. Always, remove the NEG
conection FIRST,then the POS. After cleaning install the POS FIRST,Then
the NEG. Also, I believe there is a small conector on one of the cables.
Be sure to clean that conection also.
You, did not say if the lights are working.
Mike
Oct 18, 2009 | 2005 Jeep Grand Cherokee
Wiring diagram for radio
2005 Nissan Murano Car Audio Wire Diagram
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Location: N/A
Oct 02, 2009 | 2005 Nissan Murano
Rear speakers
If your factory wirig harness has been cut< take a 9 volt battery and touch diffrent wires, once you touch th negative and positive side of one speaker you will hear a small static sound out of that speaker. that may help you locate th speaker. and th brown will be your ground on each speaker
Apr 06, 2009 | 1999 Audi A4
Need to replace rear speakers in 1998 deville.... how is this done?
If it is the factory installed speakers.They are come out thru the inside.You need to remove the rear deck carpet...Easiest way is to remove both back seats first .
Remove the bottom seat first by pushing the seat towards the back of the car / then lift it up.
Then you will release the other seat by (using a socket set) to remove 2 nuts inside the trunk.then the seat will be release to simply lift out of the car. remove the top deck carpet .
The speakers are held in by 4 angled clips.
From inside the trunk, release the 4 angled clips,disconnect the speaker wires.Then push the speaker inside the car and your done. Hope this helps.
Feb 22, 2009 | 1998 Cadillac DeVille
Back door wont open and window wont go down
The rear window has to be completely down in order to move the tailgate! You should be happy that your window is stuck up, unlike mine which is stuck all the way down! I have to completly take apart my tailgate!! If you want to try a trick to get the rear window down, my bronco has a rear window switch right next to the headlight knob, take the 2 purple wires on that window switch, and cross them, if your motor still works and if the wires are good, that should make the window go down!!! good luck, hope that helps!
Oct 05, 2008 | 1995 Ford Bronco
Logitech mm50 speakers
Pirate_ecu
Hi, there is no way to fix that, if the problem is from the control on the speakers, that is a problem inside the conector that fix the volume, have to open carefully, and clean all contactc, that should fix that, but do it carefully.
Dec 25, 2007 | Apple Logitech Inc MM50 Portable Speakers...
Right Speaker Hit the Floor
Im sorry to say so, but the fact that speaker can still monitor volume has nothing to do with its disability to produce sound. Im not a speaker wiz, but I can think of two possible reasons for what happened: 1. something has broken inside the speaker. in this case you will have to get it fixed\replaced. 2. some disconnection accured from the hit, a wire got teared or loosed. in this case, you might get lucky. open the speaker, and search for any torn wires. if you are handy you may be able to weld, replace, etc.
Mar 24, 2006 | Altec Lansing VS2121 Computer Speakers
Bose VCS-10 Center Speaker Logo
635 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
