Televison & Video Logo
Posted on Dec 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My second television I have freesat ,the remote a goodmans will not work,it is not the batteries,have only had the goodmans free sat for a couple of weeks is there anything I can do?
Arthur Tang
Level 3:
  • Master 734 Answers
  • Posted on Dec 03, 2010
Arthur Tang
Master
Level 3:
Answers
734
Questions
0
Helped
157848
Points
2179
First find out how many digits of code your remote neeeds for your TV? Then you can input the code on number at a time until it works. Some remote only use two digits, but the lat model TV may need five digits. You can google the codes for goodman's remote for freesat if you know the TV brand name..
Goodmans tv is stuck in radio mode, the radio/tv button doesn't change it. How do I get back to tv?
It is most likely that button is damaged. You can change that button and see if it works.
1helpful
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
1helpful
I have had SKY Freesat for a few years with no problems. Suddenly, over the past two weeks, I have been losing the signal nearly every day. I press the remote to change channel and I get the message...
Try forcing a reset by holding the "Backup" button whilst powering up the unit. Hold for 15 seconds or so until the display changes and then wait for it to finish downloading. That will force a global reset and load the latest firmware. (depending on model).
Hope that helps.
1helpful
2answers
Hi i need the code for one for all urc-7562 for my tv goodmans GTV42P3
Goodmans:
0036 0072 0037 0009
0264 0516 0179 0374
0487 0371 0499 0556
0343 0235 0035 0480
0217 0335
I’m happy to help further over the phone at https://www.6ya.com/expert/william_83fc156eee2b555e
1helpful
Goodmand 42'' TV turns itself off
Check to see it your TV has a timer and it was accidentally touched to activate. Good luck.
How do i wire up my phillips surround system to my freesat hd box
Hook free sat up like you normally would and either 1. if it has a second audio output, just run that to your input on the surround sound. or 2. use audio output on tv to surround. or 3. get two A\V splitter cords. Its a cord with two male ends on one end and one female on the other. Just put the splitters on the audio wires from the free sat, and run one to the tv and one to the surround
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
