Washer stuck My machine has just stopped. It seems that the cycle will not change to the next stage and is getting stuck before the final phase. i have a zanussi turbodry wdt1085 washer/dryer now what happened was i loaded it with washing ,closed the door but without noticing it a sock was hanging out, now the washing machine was filling up and filling up and going all over the floor with the door closed but the sock was making a slight gap for the water to come out. now because of this problem the timer does not turn it is stuck and i have to operate the time manualy but it does work in drying mode please can you help
  • dwb_39 Jun 27, 2008
    its stick on every cycle i have to manually change it, this problem only started after sock problem
  • douglas smith May 11, 2010
    iu have the same machine as it happens. timer sticking is not related to the sock hanging out. wherabouts in the cycle is it sticking?
I am assuming that water comes in at the start of cycle and machine does not then progress. Points to a timer fault unfortunately. These timers are expensive and quite hard to fit. don't recommend repair in view of age of appliance.
honestly can't see how related to sock problem
Posted on Jun 27, 2008
Zanussi zwf1421
Thermostat or heater most likely causes. Does timer button move round without doing anything? Timer knobs on Zanussi notorious for breaking off inside.
Apr 28, 2012 | Zanussi F1245W Front Load Washer
Washer tumbler does not spin in final stage
hi sounds like the gearbox has slipped a cog and stuck that will cause the belt to burn
Nov 01, 2011 | Frigidaire FEX831CS Top Load Stacked...
We have a WGL 10 US model F&P washer. Most
Are you waiting long enough? Ours seemed to stall but eventually would start up again. Have you tried diagnostic mode? email me at Yahoo.
Sep 01, 2009 | Fisher and Paykel GWL11 Top Load Washer
My Kenmore Washer 110.92281100 won't stop
I purchased a new timer, installed and solved the issue.
May 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Maytag neptuneMAH9700 front load washer
Another computer generated flaw.The worst thing is alot of times that "flaw" can be a costly one
May 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Front load washer wcvh6260fww
The problem may the pump filter which is hidden behind the lower front panel. To access the filter, unscrew three screws at the bottom of the panel and carefully remove the lower front panel. Make sure to unplug the machine. With the panel removed you will see the pump filter. Get a bucket and some towels ready, because when you open the filter, you may get a gallon plus of water coming out. GE failed to put this in the use and care manual for the 6260. But low an behold, GE put an access door and explicit instructions on cleaning the pump filter in the updated 6400.
You may have burned out your washer pump. That is what happened to me. The machine would not drain or spin properly and so I kept pushing the blinking start/pause button to get it going again. Then it finally did not drain at all. I installed a new pump and with the cleaned filter, the machine worked like new. For some, simply cleaning the filter allows the pump to work properly. As the filter gets clogged the pump has to work harder and harder to pump out the water. When this happens the cycle times get extended . One symptom of a clogged filter is the final minute (spin cycle) takes much longer. Obviously this is a "design flaw" that GE "fixed" in the recent version of the 6260.
Mar 25, 2008 | GE Energy Star WCVH6260F Front Load Washer
When the washer go s on rinse the prewash flashes Problem
Mine has been doing the same ... each time it goes to the next part of the cycle the red light flashes but the machine doesn't do anything ... so up till I have been able to get the machine moving to the next stage by pressing the "Start" button ... unfortunately the machine will pause on each stage - meaning I have to press "Start" at each stage!
Dec 15, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Won't cycle to the next step
maytag neptunes are the worst appliances to get. i worked for maytag and the neptunes are over price and break very easy. plus the cost of repairs are very expensive. i would recomend getting a new washer. youve put enough money into this one and getting it fixed is going to be expensive. especially when the fix is only temporary. something else is going to leak or break.
Feb 02, 2007 | Maytag Neptune MAH5500B Front Load Washer
Final agitation and spin do not happen, timer does not stop
check your knob and sleve on the timer to see if they are the right ones or if they line up. if they doit might be the pin in side the timer.or it might be faulty. another suggestiion is check everything out twice. good luck
Nov 20, 2006 | GE WBSE2090A Top Load Washer
Washer stuck
First, make sure the lid is closed completely. Check to see that the power cord is ok and that it is getting power. If it is, the machine's overload protector may have tripped. In this case: - Take out some of the articles to reduce the load and let the protector reset itself, then restart. - If it doesn't help, Check whether the programmer/timer is linked to a controller board. Generally this is hidden away underneath and is difficult to see. This may have an intermittent fault or may be getting damp or there may be something amiss with the wiring. - Check the switch contacts with a meter. Also check there isn't a blockage in the 'spigot' that joins the hose to the drum (Poke a piece of wire up the hole if needed).
Apr 03, 2006 | Zanussi FS1155W Front Load Washer
Washing Machines Logo
168 people viewed this question
Top Washing Machines Experts
