Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon 18-200 autofocus lens won't focus and therefore the shutter will not open. Autofocus with 18-55 lens works fine.
  • Rob Feb 11, 2009
    i have a D2xs with the same lens 18-200 and i am having the same problem have taken the lens on and off and still no go. what can i try next
  • Rob Feb 11, 2009
    18-200 lens on my D2xs will not focus even when i have taken it off and on again. it happens now and again. help before i throw it out
OK I just fixed it, thanks to Ken Rockwell.com who says:
"Once in a blue moon my Nikon 18-200mm won't focus on my D200. Manual focus works fine, but the lens won't autofocus no matter what I do. It's annoying!
Of course the camera needs to be pointed at something with contrast, lines or texture. Point it at the sky and nothing autofocuses. That's normal.
One time this was so bad I thought for sure I was going to have to send my lens in for service, since nothing would get it to go.
Then I discovered the problem: I had knocked the AF switch on my D200 to M. This switch is easy to knock and I had forgotten to check the obvious. There also is a switch on the lens which is not easy to knock, but I have left the lens set to M shooting at night, and I forgot to return it to A/M the next morning.
This fixes most of my problems.
Rarer is when the lens honestly won't focus. When this happens I turn the camera off and on. If this doesn't fix it, turn the camera off, press the lens release button and rotate the lens back and fourth a couple of times. This will clear any dust off the electrical contacts and focus returns."
Posted on Jan 19, 2009
  • jeffh999 Sep 21, 2011
    This was posted on the Flickr forum and it worked for me, take off your filter and tighten the small grey ring on the inside of the filter threads as follows (use a lens cloth so no smudges or scratches):
    "Just Check the top part of your lens.You will see a gray ring with 2 small holes
    where you should hold this ring and turn clockwise to tighten it.It is quite
    simple.Just don't scratch your lens,be gentle.You can even clean the inside by
    turning this ring counter clockwise and unscrewing the front element.There is
    nothing you can do wrong unless you scratch the glass.So even if you are still
    not sure,just go ahead and try it.Your lens will have no problem at all...I
    guarantee....;-)...Just don't scratch it..."
Nikon d5100 Blurry photos When I take photos of a party, at night, my photos are very blurry. How can I fix..
Use autofocus if you have a AF lens on it.
Usually you get a kit 18-55 AF lens that has a A/M switch on the side. The switch should be facing the A side so it's set on autofocus. Then you have 9 points on your viewfinder, those are the autofocus points. It should usually be set to center, because you usually want the object in center of your photo to not be blurry.
Remember to press the shutter button halfway and give some time for the autofocus to focus. Then you can press it all the way, you should have your photos nice and clear.
If you happen to have a manual focus lens, you should be watching through the viewfinder and turning the focus ring on the lens and determine if your object is in focus. It's hard at night, but get some practice at home when you have some more light so you get more familiar with the focus.
Dec 26, 2012 | Nikon D5100 Digital Camera
All of a sudden every picture I take with the 55-200 zoom lens is blurry and slightly out of focus. Pictures with the 18-55 lens are still sharp. I have been using that 55-200 lens for years for sports...
Simplest answer is that you may have accidentally flipped the focus switch (A/M) on the lens to M. This turns off autofocus for that lens (which you might need to do if autofocus just can't resolve the image). Try turning it back to A.
Another possibility is that you're using an autofocus target different from the one you're expecting. The problem would be apparent regardless of lens choice, by being in focus in a different part of the image. You can press the arrow keys (while holding shutter release down halfway) to change AF targets, or change a menu setting to simply choose the closest target.
The shooting modes have no effect on focusing ability.
The camera would likely detect other focus-related problems (like servo failure).
May 09, 2011 | Nikon D40x Digital Camera
Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
Jan 02, 2010 | Nikon D3000 Digital Camera
I have a nikon d-40 is there a seeting on it that well let the cameras lens focus when you push the button half way down. I took picture but I had to manual focus I don't know if it the lens or this camera...
Any of the autofocus settings will attempt to focus when the shutter is pressed halfway. What lens are you using? If it doesn't have an internal focus meter, then the D40 won't autofocus with it no matter what. If it does have an internal motor, then check to make sure the lens is set on autofocus.
Check Custom Setting 12. If it's set on AF-On then the shutter button won't focus.
If this doesn't fix it, specify the lens and any other details.
Oct 09, 2009 | Nikon D40x Digital Camera
Automatic focus not working
The D40x only autofocuses with the latest AF-S (and old professional AF-I) lenses. Most traditional (screw-type) AF lenses from 1986 through today will not autofocus on the D40x. If your lens says "AF-S," you're fine.
Most lenses sold today for the D40x are AF-S, and so is the included 18-55mm kit lens. Many non-Nikon lenses from Tamron, Tokina, Quantaray, Sigma and anyone other than Nikon still won't autofocus on the D40x. Try before you buy, but honestly, there isn't much the included 18-55mm lens won't do.
Autofocus systems are fast, but not usually instantaneous. You have to hold the shutter down halfway as you compose the first shot so the AF system can focus and lock, and then the camera fires instantaneously when you press the shutter the rest of the way. See Preventing Shutter Delay for more.
Jul 14, 2009 | Nikon D40x Digital Camera
Sigma 70-300 Macro Motorised Lens for Nikon has stopped autofocus
If you just purchased the lens I would take it back sounds like the lens is jarred and defective should still be on warranty
Jan 22, 2009 | Nikon D80 Digital Camera with 18-135mm...
No autofocus
We tried the same lens on another Nikon (D90) and auto focus did not work.
We mounted a new set of lens on the original D40x, and it worked.
Turns out the 2 year Nikon lens (18mm-135mm) was bad. Nikon lens have a 5 year warrantee. The lens will be sent back to Nikon with no service or shipping charge.
Thanks,
K
Dec 08, 2008 | Nikon D40x Digital Camera
Nikon d40 autofocus
Look on the left side of the lens. Make sure the button is on A for auto focus and not M for manual. OR not stuck in the middle. Hopefully that will solve the problem.
Jul 11, 2008 | Nikon D40x Digital Camera
Autofocus will not work,
Camera wont let you take a picture until focus is locked, why are you using M (manual focus) if you expect autofocus to do it for you? In M mode it is up to you to focus correctly or camera will not take the picture.
Apr 13, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
2,557 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
