Question about Hampton Bay 24002 Ceiling Fan
Fan comes on by itself
My fan will from time to time turn on bt itself. Even if I take the battery out of the remote control. Why? Can it be fixed?
  • Anonymous Jul 01, 2008
    My fan turns off by itself. it will be running for 1 or 2 hours and then just turn off.
  • Anonymous Feb 21, 2009
    Hampton Bay fan lights turn on by itself - can't figure why it's doing this - when we bought the house the fan was already there. We've been living here for almost two years and now the light are turning on by itself, sometimes it's in the middle of the night - how spooky is that. How can I fix this?
You might have a number that has a similar remote on the same frequency. Try changing the DIP (dual-inline-pin) switches on the remote and receiver (located on the housing of the fan) to a different setting. The settings on the remote and fan have to be the same.
Posted on Jul 25, 2008
I had the same problem with my light. I changed the code on the receiver and the remote and it works great now.
Posted on Jul 13, 2008
  • 67 Answers
Change the capacitor
Posted on Jul 07, 2008
My light on my ceilinf fan will only stay on dim.. What can I do to fix it.. It only operates bt remote
if fault is not on remote , you may need to bring down the ceiling fan and check on stuck electrical contacts and sensors to fix the problem.
Dec 28, 2013 | Hampton Bay Indoor Ceiling Fans and Light:...
Is there a way to take remote controll off of a fan mine stoped working after kids pulled fan or light pull
My ceiling fan loses remote control every time there is a power outage. The first thing to do is turn off power to the fan at the circuit breaker. Take the battery out of the remote and push all the buttons to eliminate a stuck button as a possible cause. Reinstall the battery. Turn on power to the fan. Check operation. You may have to pull a chain to "reeducate" the remote but you should be back up and running soon.
Dec 31, 2012 | Hunter 52" Ceiling Fan With Light And...
My Hunter remote controlled fan worked great for the first few years, but now the the light comes on and the fan turns off at the same time without me touching the remote or the switch on the wall. Wakes...
Sorry to read about your problem, I hope this helps you out.
you may have a defective remote reciver or even a bad remote.
Take the battery's out of the remote for a couple of days, if the fan turns on, the remote is good.
you can have the remote receiver replaced, they run around $60.00
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a Hampton remote ceiling fan with lights.The Redington 11
the carbon of remote which help to connect the points of remote is not working so purchase the liquid carbon and put on the inner points on remorte buttons
then i feel it strt working.
Apr 29, 2010 | Universal Remote Control Hampton Bay...
Ceiling fan and light with remote turns on and off by itself
Both the remote and reciever in the fan base have the ability to have the codes changed. What is happening is you are getting radio interference that is causing the problem. Change the codes by either switching the switches in different positions or adding more dip clips that came with the fan. In any case change the codes in both the reciever and remote to the same code and you should no longer have a problem. Usually the place to change the code in the remote is in the battery area and are small switches (usually 5 or 6 of them) and unfortunately you will have to take the fan down to do the one there.
Oct 12, 2009 | Hunter 52" Ceiling Fan With Light And...
Wall remote that controls ceiling fan & lights not working
Either the bulb is blown or the connection under the wire nut is loose. First check the bulb then turn off the power at the panel and check each wire nut by unscrewing it and making sure that the wires are tightly twisted together before reinstalling the wire nut.
Mar 26, 2009 | Hunter 27187 Remote Control
Ceiling fan/light quit working with remote
Fan does not respond to remote, checked and replaced batteries in remote. No response, and unfortunately it is now well out o warranty but have the same fan in another room purchased same year 2003 which is moving along fine. Cannot find instruction book for either one. Please help. Thanks
Dec 11, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
After installation fan and light will not work
Did you make sure the wire nuts were tight in the fan and in the box? Is there a switch controlling this fan?
Nov 26, 2008 | Hampton Bay 52 In. White Redington...
Remote Control
Change the remote control batteries. Because of the motor construction, it needs to turn on in the highest speed setting. This is why it defaults to the high speed mode. Put new batteries in the remote and that ought to fix it.
Mar 04, 2008 | Hampton Bay 48670 Flemish Pewter Finish...
Hampton Bay 24002 Ceiling Fan Logo
459 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
