Question about Dell Latitude D505 Notebook
On / off switch on Dell D-505
When I push the button to turn on the unit, I have to push it real hard or it won't go on.
  • 2,028 Answers
Take off the plastic strip with the power button on it. It will pull up on the right side and snap up and off. Then try starting it by pushing the power button on the board. If you have to press this button hard then it's worn out and will have to be replaced. If you don't have to press hard then the power button in the plastic strip is worn and misaligned and the plastic strip needs to be replaced.
Posted on Jun 26, 2008
Dell Axim X50 PDA won't turn on
try a hard reset
Dell Axim x50 / x50v / x51 / x51v:
Make sure the device is on before performing hard reset. To hard reset, press and hold the power button and press in on the reset button (reset hole) on the back of the unit for about 2-3 seconds. Release both buttons and you will see a confirmation screen asking you if you would like to clear all data in memory. To do so press the Contacts button. To cancel press the Mail button.
IT may be that the mainboard is faulty and would need to be replaced.
Aug 03, 2008 | Computers & Internet
My microwave won't heat
The real clue here is strangely enough the table not turning.
All units have a switch in the side (usually the right side) of the cabinet--when door is opened it allows the unit to work but will not heat or the table (usually both) will not work.
It has to be got at from the inside of the unit--little plastic holder with the switch which looks like a leaf switch.
What I have seen several times (including a unit I own) is that from countless opening and closing the door the holder may break or even melt and the contacts on the switch no longer are in position to work when door is open.
The purpose of such a switch is simple---it prevents the unit from being used if the door is OPEN.
Not a hard or expensive repair
Dec 06, 2012 | GE Profile Spacemaker XL 1800 36"...
Dryer buzzes but won't start
see the diagram :
1) O.k if the thermostat 2) Thermofuse is o.k is good resultant BUT please 3) Test the door switch for open or defective , if the remain open the motor will NOT START. see the diagram. 4) After changing the switch if the problem remain the same the motor is faulty( centrifugal swithc, etc) need repair or replace. 5) Test the push button start for diryt or open, test the wires for loose, broke, or burn wires too.
God bless you
Jun 09, 2012 | Whirlpool LER4634J Electric Dryer
LCD TV DELL 2600 remote does not work until tv is turn on, also tv is very hard to turn on with manual button.
hi,hard to push bottons on TV manual controls usually happens because they are not use for a long time carbon accumulates inside the switches.You can just use a contact cleaner spray (windex) just spay it directly to the button and press repeatedly until dry..good luck1
Apr 07, 2012 | Dell W2600 26 in. LCD Television
The 'boost' button on my aqualisa digital shower won't switch off. It comes on when I press the shower on (without actually pressing the boost button) and when I press the boost button to try...
Good Morning drlesleyanne. The issue you describe will down to the PCB inside the push button controller. If this does not send the correct signal to the processor box it can cause the unit to 'fail safe' and this is why the unit needs a power reboot. The remedy to this is to replace the push button control itself and once installed should allow the shower to work correctly again. All our digital products have five year guarantees, so you can always call our Customer Service line on 01959 560010 and they will replace this for free.
Kind Regards,
The Aqualisa Team
Jul 29, 2011 | Home
My garmin turns on just fine but it won't allow me to push any buttons. How to I fix this?
There it should be a lock switch on top of the unit that prevents you from touching buttons by accident.
May 18, 2011 | Garmin Nuvi 680 GPS Receiver
My GE DHDSR46 gas dryer won't start, what should I
505 is the thermal limit.
Looks like this:themobilian_2319.jpg
Hunt for junk and clean that out, then replace this fuse if it is bad.
See the white button to the right of the driver?
Thats the door switch, if open, that dryer won't run.
More Here
May 07, 2011 | General Electric DHDSR46GGWW Gas Dryer
My 1999 f250 brake lights do not work, but the turn signals do, and the tail lights do too, I put in a new brake light switch but there does not seem to be any power coming out of the switch
take the hazard button and tug and wiggle it real hard when pushing the brake pedal, if they start flickering, you will need a turn signal switch replaced.
Sep 23, 2009 | 1999 Ford F250 Regular Cab
Dell 2300MO NOT STARTING UP Problem
Try the remote control.  You may have a problem with the contact switch in the power button.
Oct 02, 2007 | Dell 2300MP Multimedia Projector
Dell Latitude D505 Notebook Logo
100 people viewed this question
Alun Cox
