Question about Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W I have had my Zanussi FJS1225W for 6 years with no problems atall, I did a wash load today and it seemed fine. However i put a load in tonight and the washer is filling up and going round then all of a sudden it goes onto a fast spin and is hitting the cupboards on either side, i checked the filter and cleaned this out,, then started it up again after draining it and it did the same again, now i am scared of turning it back on because of the noise its making, it also appeared to be leaking from underneath aswell. Could you please help me, also the beeping noise is not working, it stopped once before then started to make a noise again and has now stopped again!
  • 1,462 Answers
Fault is probably the motor tacho( bit that measures motor speed) has dropped off or the circular magnet inside it has broken.
tilt the machine back at a good angle so you can get underneath and look at the end of the motor shaft (opposite end to the pulley). you should seea circular coil with 2 fine wires coming out of it. this coil is held in by a clip and it has probably loosened.
Posted on Jun 26, 2008
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
Zanussi washing machine will not start cycle.
check water level device,must have in manual,or water pump filter.
Feb 16, 2009 | Zanussi FJS1225W Front Load Washer
Washing machine wont spin
kink in waste hose (also unscrewed filter at bottom of machine and cleaned same) seems to be working now thank you for your help.
Dec 07, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi fjs1225w nasty smell around door seal and inside machine
Are yo;u susing front loading detergent? My smell went away when i switched.
May 14, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi aquacycle 1000 xc washer
faulty fill valve. or tap not switched on correctly if it has the blue tap remove the top of the tap and use pliers to switch it on
Jan 26, 2008 | Zanussi FJS1225W Front Load Washer
No spin
Your problem is that the carbon brushes on the motor have worn out and need replacing.. eaisly done
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi turbodry w 1042 w
probably short to earth on the dryer elements. to check. take top off, disconnect dryer elements then run on dry program. if the trip stays in, then you have identified the fault
May 16, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
209 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
