Question about Mitsubishi VS-50607 50" Rear Projection Television
Mitsubishi vs 50607
Tv turns off sometimes turns right back on sometimes it takes a while i did the test and get a 2 4 code how do i go about fixing the problem its still a good tv worth saving it its not too expensive
  • muse923 Jul 07, 2008
    I have the same problem with my roughly 5-years old 46 inch projection set by Mitsubishi. I'll be watching the set and it will just spontaneously turn itself off. It's happened about 4 times in the last several months. A couple of times it would not turn on again for about 15 minutes, one time it wouldn't turn back on for about an hour and the fourth time it wouldn't turn on again for about 4-5 hours.
    I talked to a few repairmen in our area about the problem. None of them recognized the symptoms and all they could suggest was that they could haul the set into the shop and try to figure out what is wrong, notwithstanding that, when they would be looking at it, the set would be turning itself on and off in a normal fashion.
    Let me know if you learn anything about this problem. Thanks.
    muse923@aol.com
  • 927 Answers
Good Day, gntjige73 & muse923;
Let make this short and sweet, code 24 means you have a vertical problem. Four common things can cause this:
1. Bad connections on the convergence IC's,
2. Bad cap's in b + to vertical circuit,
3. Bad connections/or failing vertical output IC,
4. Or fluid on the PC board, leaking from the crt's.
The companies you called DO NOT call them back, but call a factory authorized service dealer, they will help you, but always remember to get a written estimate before you proceed with the repair. Good Luck, big IRISH>
Posted on Jul 15, 2008
What do I need to fix my mitsubishi TV that has a 2-4 error code (vertical protect)???
I had three tv's VS-50607,VS-50605, same problem.I called Mitsubishi and got no help.Took me two years to find because the sets were not acting up when I was there.Last set was out completly with 2-4 code. Found problem to be cold solder connection of DY (Yokes) on vertical .I bent the tip on my Weller gun and used a mirror and soldered. It was a sure repair.I went back to the first set,and soldered and it repaired it!,The second set got junked out before I could get to it.
Sep 18, 2011 | Mitsubishi VS-50607 50" Rear Projection...
Power shut off right after turning on
If the unit is not overheated, you may have the dreaded green blinking light (sometimes never stopping blinking). Usually, it takes a capacitor kit to fix this (assuming you have that problem), which is available for many models on the internet. Mitsubishi may be of some help also as this sounds like a common problem.
Jul 18, 2009 | Mitsubishi VS-50607 50" Rear Projection...
VS-50607 Mitsubishi code 24...replaced caps now code 22
Well, I don't know about your original problem but I can guarantee that 95% of the time when a Mits projection set gives a 2-2 code it's because the convergence output IC's are drawing too much current. Replacing the convergence output IC's usually fixes the problem.
Jun 05, 2009 | Mitsubishi VS-50607 50" Rear Projection...
I have a Mitsubishi VS-50607 and it will turn on then off.
This solution fromtroylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jan 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi rear projection tv model ws-65907
Your problem is in the power supply section,,all the solder there holding the parts is crack or loose already need to resolder so performance will back again.
Jun 19, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi 50607
22 is the code for short protection. Which means the set has shot down due to one of the components being shorted. My quess would be at least a 3 to 4 hundred dollar repair maybe more depending on the shops integrity.
May 09, 2008 | Mitsubishi VS-50607 50" Rear Projection...
VS 50607 50 inch
Deflection Protect is the problem. You can check C411 and C412 on main board to see if bad. More info ctechnicians.com
Nov 17, 2007 | Mitsubishi VS-50607 50" Rear Projection...
The VS 50607 won't turn on.
I'm not sure of the fix, but my manual says the 2-3 error code is due to Horizontal Deflection Failure. Hope this helps. I just uploaded my service manual, it should be available in 24 hours pending fixya's approval.
Oct 30, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS50607 Self Diagnosis 2-3
  1. Turn on your TV. If he TV request your secret code press QV and 9 at the same time.
  2. Press menu to view the main menu.
  3. Use up or down key to select "Chip Parent Lock" and press enter.
  4. The on screen display wil ask for your current passcode. Press QV and 9 at the same time.
  5. The on-screen display will now ask you to enter a new code.
  6. To cancel the passcode permanenly, press menu or home.
  7. To change to a new passcode, use the number buttons to enter a new code, then press enter.
  8. You must use the remote control included with thisTV. You cannot use a universal remote.
Oct 21, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mistu VS-50607 Error Code 2-4
C411 and C412 can be the problem, for more info ctechnicians.com
Oct 17, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
111 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
