-   This just started. When I turn on my camera the first info screen comes up but the image screen never comes in on the monitor. Then the camera turns off. Is this a setting problem? Any help would be appreciated.-   lostind40x
Jun 26, 2008
-   At first, the screen turns on, than it shuts off. -   mike_kawata
The display screen on my DSC-T1 shows a perfect, clear picture when the memory stick from another...
(More)
The display screen on my DSC-T1 shows a perfect, clear picture when the memory stick from another Sony camera is inserted and a photo is selected. But when the camera is switched to exposure mode, the screen is blurred badly, with basically vertical streaks and lines of the image being focused on. If the shutter is tripped, that blurred image is the result. One clerk in a photo store says he thinks the sensor is at fault, because the screen will show a good picture from a stick coming from a different camera. Bob Thurgood 425-485-4416
Canon 40D with Canon 50mm 1.8 lens ERR 99 Shooting is not possible Turn the power switch to and...
(More)
Canon 40D with Canon 50mm 1.8 lens ERR 99 Shooting is not possible Turn the power switch to and again or re-install the battery. I did all of it several times. Removed all except time battery not sure where it's stored. Plan to clean contacts and try another card and lens. This seems to be a common err problem. Does it require installing software? update like computer problems? Thank you for any suggestions Fernand
