Question about SnapGear SME 550 (990065) Firewall
Flashing Lights All of the lights are flashing and won't stop. I moved the device from our old office location and when I plugged it in all I get is flashing lights.
  • 29 Answers
The flashing lights meen there is a configureation problem with your snapgear. Check your settings to make sure thay are current for your new location. Just because you own an IP/DNS from one service does not mean that it will be valid from another service. Some services use a system where you set your router to DHCP and they assign you your static IP/DNS. Also Snapgear routers have configurable ports so they are going to be picky about what is plugged into what port. Hope this helps
Posted on Sep 12, 2009
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
Lights on fridge freezer won't stop flashing
Make sure light bulb is screwed in pretty snug
Feb 24, 2013 | Freezers
When i plug my dlink DSL-2640U router the lights start flashing and every time it flashs the wireless just drops down and i have to enable it from the settings .. then the router's lights flash an
The led always flash with activity. They are transmitting and receiving data. If they stop flashing your ISP signal has stopped. Could you explain this statement" the wireless just drops down and i have to enable it from the settings"?
Dec 20, 2012 | D-Link Computers & Internet
The lights are flashing and won't stop. I tried to unplug and replug same results ...what should I do?
As far as I know, the flashing lights are an indicator that the slow cooker is on, but awaiting instructions. You need to put in a time and then a temperature and then it will stop.
I personally find the power button very disconcerting and keep having to stop myself pressing it once I've programmed the slow cooker, and accidentally switching the thing off.
Nov 05, 2012 | Rival 38601 Smart Pot 6-Quart
Lt 35 flashing glow plug light
In my case, the flashing glow plug indicator is caused by me replacing the stop lights with LED bulbs. Therefore, a cause for this flashing indication could be a blown stop light lamp. The test for this condition is; while the glow plug indicator is flashing, press and release the break pedal. This should stop the indicator from flashing. Check your stoplights. Or add a load resistor to your LED lamps if you have fitted these.
Jun 01, 2012 | Volkswagen Volkswagen Cars & Trucks
Nyko charger won't charge
Had same problem with blinking lights and not charging.
Plug charger base in (blinking lights), remove controllers, and plug USB cable into front charge slot (behind hinged panel). This reset charger base and lights stopped blinking. As FYI - the USB was connected to other device (charging it). Add the controllers and correct charging lights show up - including the controller 1 and 2 symbols. Controllers now charging.
Feb 07, 2012 | Nyko Charge Station 360 For Xbox 360
Printer stopped printing, all lights flashing
Sounds like a bad cartridge. 45's, 15's 23's & 78's seem to do that. Replace the cartridge, but try wiping the copper strips on the cartridge and where they fit into the printer as well with some alcohol on a paper towel. if , not, put the old ones back in. if it still does it, it might be simply dying.
Jun 05, 2007 | HP DeskJet 895cxi InkJet Printer
SnapGear SME 550 (990065) Firewall Logo
996 people viewed this question
Top SnapGear Computers & Internet Experts
David Payne
David Payne
Are you a SnapGear Computer and Internet Expert? Answer questions, earn points and help others
