Question about LG 37LC2D Television
Volume using remotes either ramps to max or all the way down
When using remotes, the volume will only ramp to max or to its lowest setting. The manual volume on the TV works like it should. I have removed batteries from the remotes and unplugged the TV for a time hoping that the problem would go away through a reset of sorts but that did not work. Do you have any ideas?
  • 44 Answers
Go into the service menu and reset the main board.
Posted on Jul 03, 2008
When my daughter goes down a ramp the wheelchair tilts forward and the back wheels are off the ground! Why is this happening?
ramp too steep and not made to a safety standard
person too high in chair
person too far forward in chair
front wheels not positioned far enough forward
carer not paying attention to the ramp and possible risks
talk with disability persons equipment retailers as they have a good idea of the risks involved with wheel chairs and can advise you on how to overcome the problem
Jun 21, 2016 | Health & Beauty
Tip
Safety concerns with car ramps.
Alot of people feel just a little bit uneasy when it come to getting under a car when on car ramps. A little trick is to drive the car on the ramps, put blocks, or wheel chucks behind the grounded tires. Then using a jack, jack one of the ramped tires up enough to remove its ramp. Reverse that ramp and then lower the vehicle down. It can't roll down the ramps because it is wheel locked inplace. Please though reverse that prcedure to drive it off the ramps.
Please note, I selected Chevy as the manufacturer only because 'any' is not an option
on Dec 08, 2009 | Chevrolet Chevy Cars & Trucks
Nordic track elliptical clunk
I had a clunking everytime I would use my Nordictrac 1300, the clunking was on the right side. I opened everything up searched everywhere was about to scrap it, when I found the wheel that attaches to the stride handle was cracked. it is the wheel that rolls along the ramp while you are striding, looks like a roller blade wheel. I downloaded the manual. looked up the part and found them at Amazon for $60 per wheel, very expensive! after looking at everything, it looked like the wheels that raised the ramp up and down were the same. So using an allen set, I pulled the wheel that raises the ramp up and down and replaced the cracked wheel with it. I then took the cracked wheel and placed it on the piece that raises the ramp up and down, since it doesn't get as much activity as the stride wheel. if you have to do this know you will need a pair of pliers that takes those C ring clamps off, because the wheels are secured with those rings. took a damp rag, cleaned out a little dirt from the rails, tested it out, runs smoothly at low and high intensity, no more clunking!
Nov 28, 2012 | Nordic Track Flywheel For The Healthrider...
Any real time function is there in hitachi VFD..? VFD need to operate it certain speed based on time.
Ther are settable ramp up and ramp down times and there are settable speeds (max and run)
Mar 27, 2010 | Hitachi Variable Frequency Drive Inverter
The volume ramps to maximum. I can adjust it back
Sounds like the circuit board for the button keys in front has a shorted tactile switch causing sound to keep increasing, Replace all switches on this board or get new board. I believe it is called a HS board or very close to that.
Dec 30, 2009 | Sony FD Trinitron WEGA KV-32FS200 32" TV
My KDS-R60XBR1 turn up volume to maximum loud and stays loud
Question:
Take the batteries out of both the remotes and then try to turn the TV on with it's On/off switch built into the TV.
If it turns on and the volume stays the same, then it must be an issue with one of the remotes.
If the tv turns on and the volume ramps up to max. Please check if volume knobs/buttons on the tv itself to see if they are sticking.
If they aren't, there is something wrong with one of the boards in the tv of course. This sure should be something a Sony Service Shop can fix. I don't think it will be expensive. Maybe a $100 to $200 repair if they do the work.
Blessings,
A/V Media Guy
Nov 20, 2009 | Cameras
Hitachi AX-M131U several weeks old, remote not controlling, on manual switch on the volume ramps to max, unable to reduce. Have tried reboot and holding on off button. Any advice???? Regards Geoff Law
This should still be under warranty. It sounds like the internal CPU is confused. This could be a simple power suplpy problem or something a bit more complex. Return it for warranty service.
Keep us posted.
Dan
Jun 10, 2008 | Audio Players & Recorders
Televison & Video Logo
133 people viewed this question
Computer Repairing
Computer Repairing
