Question about Casio Cameras
Outdoor photos I have a casio camera. the inside (flash) photos are good but the outdoor pics all have a blue tint. I probably need to change a setting but haven't a clue what to do. Please help,.
The settings, according to what you've said, might be the problem. You didn't say how new the camera was or if its been damaged before, so if that is the problem, i can't help. However, it sounds like your white balance may be preset to flash mode. Maybe if you messed around with the menu you accidentally set this. The specifics of menu navigation are unknown to me, but some of the usual settings in white balance are Auto, Daylight, Tungsten, Fluorescent, and/or open shade. If you are wanting to just set forget it, I would suggest going with Auto. Otherwise, with a little studying, you can improve photos a lot by picking the right white balance. If you have no clue where to find this, your manual should be able to direct you toward that menu.
Here is two links that you might be interested in. The first one is pretty basic but should give you an idea of what to do with your white balance. The second one goes more into the theory behind it. It is quite technical but a good read if you can digest it.
http://www.photoxels.com/tutorial_white-balance.html
http://www.cambridgeincolour.com/tutorials/white-balance.htm
Hope that fixes the problem your having. If not, maybe some more information can go a long way to finding someone that can help.
Posted on Jun 26, 2008
What would make my pictures and videos come out with a lot of blue tint?
Regarding Blue tint of Photos and Videos - This is tied directly to your White Balance Settings. When you White Balance is set to Auto, the Camera determines the best setting to use to for White Balance (How much Blue or Orange needs to be added for best White). To get a Blue Tint, the Camera's White Balance is most likely set manually to something like Incandescent or Indoor. First you will want to see that your White Balance is set to Auto - If it was not, then Auto should fix your problem. But If it is alrready on Auto, and you are still getting Blue tint both Indoor and Outdoor, then the Camera's Software may be faulty.
Hope this helps!
Jan 12, 2016 | Cameras
Photos have a blue tint, can you suggest a cure.
What do you have the white balance set to? What happens if you change to another setting?
Dec 10, 2012 | Canon PowerShot G10 Digital Camera
Hi. When I use my Olympus SP 570 UZ in an Indoor Party Hall, I get Orange Tinge or Orange Coloured Photographs. Please Help me to avoid this,
This is called "white balance"-- the indoor lights have a bit of a yellowish tint, while sunlight has more of a blue tint.
Try changing the white balance to Auto-- if you get bad results on Auto, try using the Indoor or Incandescent settings. You may have the white balance set on the "outdoor" or "flash" setting.
Mar 06, 2011 | Olympus SP-570UZ Digital Camera
When taking pictures outside or from inside through a window, the picture comes out white with faint red outlines of some images. Inside the house and darker areas it takes pretty good pic's. What can be...
First the camera has a flash to allow for darker areas to be illuminated to capture pictures. The type of camera may bot allow to capture outdoor pictures with the camera flash on. Power off the flash when outdoors to capture daylight pictures.
Jan 30, 2011 | Canon PowerShot SD700 IS Digital ELPH /...
Blue tint to all my photos
You may have the white balance set to something other than "auto white balance". If the pics look ok on the camera and on your computer, but the prints are blue, I would suspect the printer.
May 13, 2010 | Olympus EVOLT E-500 Digital Camera
Images fine inside but outside natural light images overexposed
CCD is going for Failure !
it starts like this first indoor ok and outdoor over exposed then
indoor pics also when u see them closely turns pink or green in shades then horizontal vert lines appear then completely blank
just check with casio if they have issued service advisory for the CCD failure problem as all others have issued they will do it free of charge
see link
http://www.imaging-resource.com/badccds.html
Apr 11, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Outdoor shots are blue
Hey VickylnStL,
What I believe is going on is your white balance setting has been set to incandescent light which on your camera is a light bulb. For outdoor shots you should have the camera set to auto white balance, or have the white balance symbol set to the sun icon or the cloud icon depending on the conditions outside. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 08, 2008 | Olympus Stylus 720 SW Digital Camera
Casio Exilim s500--horizontal lines in picture and autofocus creates blurry pics
It appears this problem is due a failing CCD device in many brand cameras. All the manufactures use the same source(s). I have not persued Casio as yet, but other companies are offering a recall to replace the CCD for free. I plan to use this approach with Casio. Search the web for "failing CCD in digital camera", it describes exactly what we are observing.
Dec 02, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Flash not working
Sounds like a burn out, or a bad lamp.  The flash is subjected to a huge jolt of electricity each time it fires, and breaks easily, especially when hot.   If you are taking many flash photos, you should stop after 15 or so, to let the flash unit cool.
Good luck with Casio, if you are still under warranty.  It will probably mean mailing them the camera for fixing, or replacing.  Sometimes you can take it back to where you bought it for repair.
Nov 28, 2007 | Casio EXILIM EX-Z1000 Digital Camera
Images seem over-exposed
Time for a new one I guess- too old to consider remedial work.
May 17, 2007 | Casio QV-R40 Digital Camera
Cameras Logo
113 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
