Question about 3M Post-it Purse-shaped Note Dispenser - PD654
How do I load my purse post it dispenser? - 3M Post-it Purse-shaped Note Dispenser - PD654
    New Friend:
I had the same issue until I discovered just now that the copper spring-like piece goes BEHIND the Post-it notes. Hope that helps :)
Posted on Nov 26, 2012
  • 2 more comments
  • pisces_girl7
    pisces_girl7 Nov 26, 2012
  • minmanmo
    minmanmo Mar 12, 2013
    Press down on the tab in the center/top back of purse, That little lever releases the lock that holds the two halves of the purse together.
  • Maritza Drummond
    Maritza Drummond Jan 30, 2014
    Do I have to get special post it notes? I, nor anybody in my office can figure out how to reload it wihtout the regular sticky notes getting stuck.
  • LaShelle Cross
    LaShelle Cross Feb 17, 2014
    yes there are specific post it note for it. you have to buy the ones with the accordian symbol on the package
    New Friend:
I purchased this dispenser and had the same issue. I just did "trial and error". So for me the easiest way to reload the dispenser is to lay the back of the purse down and place the metal piece in position (with the short end in laying face down on the bottom piece with the curve sticking out) and then place the loaded front piece on top of that (so the metal piece does not move out of position) and then snap it shut.
Posted on Sep 19, 2016
4 Suggested Answers
SOURCE:
  • 40 Answers
SOURCE: Hi . . . feel
Hi, the purse dispenser snaps open from the bottom of the purse. You do need to use the proper post it notes that are made for dispensers, they look like an accordian, if you were to spread open the pad. When you insert the new pad in place have the first post it note extended out of the purse, like it would be ready for use. I hope this is helpful for you.
Posted on Feb 07, 2011
Testimonial: "Thank you Orchid Lady!"
  • 40 Answers
SOURCE: How do I refill the Post-it Purse dispenser????
The dispenser snaps open from the bottom of the purse. Be sure to refill with a pad that is made for dispensers as they are different than the regular post it pads.
Posted on Feb 10, 2011
  • 40 Answers
SOURCE: How do you refill a
Hi...The dispenser snaps open from the bottom of the purse. When you replace the post it pads be sure to use the pads that are made for post it dispensers, they are different than regular post it pads.
I dropped my phone and it turned white with colored lines in ot bit I can see half of the screen
I had a BB9900 and while I did not drop it, my screen too when white with rainbow coloured lines across a portion of it. The screen was not repairable; simply replace it. Before you do, consider simply changing up your hardware entirely as the cost differential between a screen replacement and new device can (depends on many variables) be nominal.
Mar 11, 2014 | 3M Post-it Purse-shaped Note Dispenser -...
How to refill a pebble post it note dispenser
Please use the following steps to load the Post-It(R) Pebble-Shaped Pop-Up Note Dispenser:
1) In order to remove the lid from the dispenser you will need to twist the dispenser in half. While holding the top of the dispenser with one hand, use your other hand to support the base. You will need to twist the two part and then pull them apart to separate them.
2) Once the back is open, place one pad of Post-It(R) Pop-Up Notes into the top opening of the dispenser, feed the top sheet from the pad through the slot on the front panel. Make sure you are using Post-It(R) Pop-Up Notes and not the standard Post-It(R) Notes, as the standard notes do not have the alternating adhesive format and will not pop-up properly.
*Please note that we recommend that yo u use one pad at a time.
3) After the pad has been loaded into the dispenser, you can put the top cover over the base and twist them back into place.
Oct 25, 2012 | Office Equipment & Supplies
Cannot open it Tried both suggestions push back button but cannot find how to open from bottom either What is corerect?
Push little tab at back...DOWN with your finger and immediately pull back off with your thumbs on either side...I struggled for a long time with this. Easy when you know how!!!
Aug 01, 2011 | 3M Post-it Purse-shaped Note Dispenser -...
How to refil post it
The answere was still not answered. Once the dispener is opened then how are the notes loaded? infront of the bar, behind the bar, upside down, what?
May 12, 2011 | 3M Post-it Purse-shaped Note Dispenser -...
Hi . . . feel kind of funny asking this question but . . . we can't seem to be able to figure out how to load the post it pad into the purse post it dispenser. Any instructions come with this thing? :)
Feb 07, 2011 | 3M Post-it Purse-shaped Note Dispenser -...
This doesn't tell me HOW to refill the 3M Purse Dispenser. I have it open, I just don't know which way the refill goes in or how to place the spring thing that is in there. I have tried just about...
You may have purchased the wrong post it notes. The ones needed for this, (& all of their dispensers) will pull apart like an acordian they are not the everyday regular post it notes. The correct notes will say they are for refilling the dispensers.
Feb 01, 2011 | 3M Post-it Purse-shaped Note Dispenser -...
How do you refill after post it notes are gone and do you have to use post it brand in it?
The bottom of the purse snaps open for refilling. You do not have to use post it brand but you do have to use the same type of sticky notes, the papers in these dispensers open like an acordian.
Jan 21, 2011 | 3M Post-it Purse-shaped Note Dispenser -...
Jan 19, 2011 | 3M Post-it Purse-shaped Note Dispenser -...
How do you refill a post-it purse? (purse-shaped dispenser)Does it have to be opened up? I can't figure it out.
Jan 15, 2011 | 3M Post-it Purse-shaped Note Dispenser -...
3M Post-it Purse-shaped Note Dispenser - PD654 Logo
11,988 people viewed this question
Top 3M Office Equipment & Supplies Experts
ray gallant
ray gallant
Tom Chichester
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
