Question about Codegen POWER SUPPLY CG|PS-350XA-12 RT (PS350XA12) Power Supply
350w switching power suply
My computer is just shutting down with no warning. I took off sides to make sure all 3 fans are working and they are. I am thinking that the power supply might be bad. The unit is not getting hot. Any ideas.
  • 36 Answers
Michael
at first chack at which time it shutting down. if it happen when u click on any drive or when u using cd/dvd drive then power supply cant regulate power. then chack switching transistor and filter section capacitor.
(Be careful about filter capacitor in primary section because some time it stored high voltage dc after plug of power supply at first discharge this two capacitor.)
** also chack supply voltage r stady or not.
Posted on Jun 27, 2008
My computer shut off out of nowhere with no warning.
They are a problem when they overheat. No warning just off. Try cleaning the fan and radiator. You will have a fighting chance then.
Mar 09, 2014 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
Shuts off for no apparent reason. Running Windows XP Service Pack 3, AMD Athalon 64 processor with 1GB RAM
If it shuts off randomly it could be to things it could be power suply or virus. i would first off make sure that there is no viruses. make sure u run a virus scan and there is no viruses. if it turns up none i would look into a power suply. if it still shuts off i would look into making sure the heat sink on your cpu is seated correctly and has good heat sink and fan as it could be over heating
Jan 13, 2011 | Dell Optiplex 740 Desktop Desktop Computer...
When pressing start button the machine starts but only runs for 1 second. the led lights up the message (turn on power supply)
this souinde like your power suply switch is turned off. if you look on the back of your computer were the power cord goes into the computer thats your power suply. if you look closly there is a switch on there this switch proble got shut off. you wanna make sure it is turned on.
Jan 07, 2011 | HP Compaq Evo Workstation W8000...
I have a model 5BS520C. The light works but when I pull the chain for the fan, I hear the sound of three speeds but the blades do not turn. ed.pfohl@gmail.com
Here some toubleshooting:
Problem 1. Fan will not start.
Probable Cause
1. Fuse or circuit breaker blown.
2. Loose power line connections to the fan, or loose wire connections in the switch housing.
3. Reversing switch in neutral position.
Suggested Remedy
1. Check main and branch circuit fuses or circuit breakers.
2. Check line wire connections to fan and switch wire connections in the switch housing.
3. Make sure reversing switch position is all the way to one side.
WARNING: Make sure main power is turned off.
Problem 2. Fan sounds noisy.
Probable Cause
1. Blades not attached to fan.
2. Loose screws in motor housing.
3. Screws securing fan blade flanges to motor hub are loose.
4. Switch housing binding against the blade hub.
5. Wire connectors inside switch housing rattling.
6. Screws holding blades to flanges are loose.
Suggested Remedy
1. Attach blades to fan before operating.
2. Check to make sure all screws in motor housing are snug (not over-tight).
3. Check to make sure the screws which attach the fan flanges to the motor hub are tight.
4. Check to make sure that the switch housing does not bind against the blade hub.
5. Check to make sure wire connectors in switch housing are not rattling against each other or against the interior wall of the witch housing.
6. Tighten screws securely.
Problem 3. Fan wobbles
Probable Cause
1. Setscrew in motor coupling is loose.
2. Setscrew in the hanger ball/downrod assembly is loose.
4. Fan blade flanges not seated properly.
5. Hanger bracket and/or outlet box is not securely fastened.
6. Fan blades could be out of balance.
Suggested Remedy
1. Tighten the setscrew in the motor coupling.
2. Tighten the setscrew in the hanger ball/downrod assembly.
3. Check to be sure screws which attach the fan blade to motor hub are tight.
4. Check to be sure the fan blade flanges seat firmly and uniformly to the surface of the motor hub. If flanges are seated incorrectly, loosen the flange screws and retighten.
5. Tighten the hanger bracket screws to the outlet box, and/or secure outlet box.
6. Interchanging an adjacent (side-by-side) blade pair can redistribute the weight and result in smoother operation.
WARNING: FOR YOUR OWN SAFETY TURN OFF POWER AT FUSE BOX OR CIRCUIT BREAKER BEFORE TROUBLESHOOTING YOUR FAN!!!
Hope helps.
Sep 02, 2010 | Monte Carlo Dryers
I took my gateway gt5620 in because it would shut down by itself. It would restart. They took the graphics card out and it worked for a while. Now it is doing the shut down again. I took the side panel off...
Sounds like an overheating problem. May want to remove the processor and check the heat sink material. While you have it out you can clean the fan and the heat sink. Make sure your air flow isnt blocked in any way and neaten up the cables if necessary. You could also consider adding another fan.
Oct 01, 2009 | Gateway GM5620 PC Desktop
No signal to monitor, fans run full speed
maybe your cpu is faulty or ... maybe power suply ??
Mar 31, 2009 | E-Machines W3107 (RBW3107) PC Desktop
My DR-B300ATX power supply is failing.
STOP...
Dont try to repair your Power suply unless you know what your doing. They can hold enough charge in its capacitors to electrocute you.
Just remove it from P.C. take it to a computer store and say: Eh hem, I need one of these to replace this one.
Make sure its got at least the same amount if not more connectors as the original, make sure its also the right type I.E. ATX POWER SUPPLY, and I would recomend getting one a little stronger than the one you blew out, something like a 350w
Probably get one for under $80.
replace and enjoy.
Dec 01, 2008 | Apex Computer Technology Apex DR-B300ATX...
My Philips Freevents sometimes wont turn on and when it does it shuts down without me shutting it down
If the computer shuts down with no warning then it could be your power supply is faulty, which explains it not turning on sometimes. Just check the back of the PC to make sure it is plugged in properly (TURN OFF ALL POWER TO THE PC BEFORE CHECKING). if this does not help, get it looked at by your local qualified computer technician if you don't know how to replace a power supply. Also, a connection to the motherboard to the Power button may have a fault somewhere, which also means take it in for a look if you don't know what to do. If it does give you warning with 'Windows is shutting down' it can be the following things.
1- Your power button on the PC is sticky and movement causes the computer to think you have pressed it and so it shuts down, which can also explain why it wont turn on all the time. Just use some household grease cutter and spray it on the outside of the button, turn off the power supply to th computer and press it in and out a few times to get it back to working order
2- A Virus is shutting your computer down on you, but this does not fully explain why it won't turn on but this could be an effect of the virus so use a virus checker to see if this is the case
3- Your computer system is getting too hot and usually a computer has setting which shuts it down before permanent damage happens. Check your PC fans to make sure they are running and feel around where your computer sits to see if its warm or hot and replace the fans or put your PC in a cooler environment
Hope This helps
Nov 18, 2008 | Computers & Internet
Pc switches off
something could be overheating. does the video card have a fan? is it working? when is the last time you blew dust out of the cpu fins and internal fans?
Nov 17, 2008 | Computers & Internet
The fan alert warning when you start up the computer says "WARNING CPU FAN FAILURE SHUTTING DOWN cPU TO AVOID DAMAGE" AND THEN IT SHUTS OFF.
I am going to assume (and we all know what assume means) - that you have a desktop. With the power disconnected, take the side of your computer off. Take a can of air (you can get them anywhere) and blow out your fans (all of them) dust and dirt can cause the fan to stop working, dirt and dust can even short out your computer. I don't suggest using a vacume cleaner - for the parts (on a vacume cleaner) are so large you can bump a circuit or diode that can break off.
Once you have air cleaned the fans, while the side is still off, power up your computer and see if any of your fans are not working, if one is not - that is what needs to be replaced.
Mar 30, 2008 | Computers & Internet
Open Questions:
Toshiba Virus Removal ' Remove Toshiba Virus - DataAlign ' Call +1888784-9316 Toshiba Corporation is a Japanese multinational company that is headquartered in Tokyo. It produces products and services like information technology, communications equipment and systems, electronic components and materials, power systems etc. Toshiba products are innovative and cost efficient which provides best solutions for home or business use. Toshiba has become the world's seventh largest IT Company which launched its first laptop in 1985. All Toshiba products have the best qualities like high efficiency in very affordable pricing, innovation at its best, ultra- portability with faster working laptops and desktops. As known by everyone, every Toshiba user require good Toshiba Customer Care and thus requires a good customer support. Likewise, Toshiba laptops also require a reliable support for the proper working of Toshiba laptops and desktops over a longer period of time. Dataalign provides best in class Toshiba Tech Support exclusively for the Toshiba customers. Dataalign tech support is provided by the highly knowledgeable and expert technicians who have years of working experience in this field and these tech support engineers have been particularly trained to be able to solve the issues related to Toshiba products. Toshiba Support of Dataalign has following features: 1. Slow speed issues are resolved. 2. Toshiba support technicians of Dataalign analyze the issue very carefully and follow proper trouble shooting steps to get to the real cause of issue for properly suitable resolution. 3. Blue screen of ***** and other errors are resolved. 4. Issues like virus, malware, spyware is resolved accurately. 5. Tech support experts providing Toshiba Support to the Dataalign customers have years of experience in the field of providing helpful assistance to customers with accuracy. 6. Dedicated staff with lots of knowledge makes the support team of Dataalign the best. 7. Customer satisfaction is taken care of every time. 8. Highest productivity is ensured after services to Toshiba laptops. 9. Resolution is provided over remote access so that Toshiba customers can witness the issue and the overall process of resolution applied. 10. Toshiba Customer of Dataalign works 24/7 and 365 days a year. For any kind of help in Toshiba products contact on the Toshiba Tech support number of Dataalign :- +1888784-9316
May 23, 2018 | Toshiba Computers & Internet
See all Codegen POWER SUPPLY CG|PS-350XA-12 RT (PS350XA12) Questions
Codegen POWER SUPPLY CG|PS-350XA-12 RT (PS350XA12) Power Supply Logo
229 people viewed this question
Top Codegen Computers & Internet Experts
Lyle Siemens
Lyle Siemens
shaun taylor
Gil Davis
Are you a Codegen Computer and Internet Expert? Answer questions, earn points and help others
