Question about Sharp AL-1655CS Copier
Sharp Al1655-cs Copy Issue
Our printer will make one copy from tray one with some strange noise, or grunt more like it, then it will think that it needs more paper, even when its full of paper!
  • sawarshauer Jun 27, 2008
    i already cleaned them and also adjusted the resistance %
  • Sharp Master
  • 2,794 Answers
It could be the feed tires might need to be cleaned or replaced. You should check it our with a copier technician in your area.
Posted on Jun 27, 2008
The printer says to replace the td cartridge and we just replaced it with a remanufactured one from Staples. The copier is a Sharp AL1655 CS
You may have just answered your own question.. Did you follow the instruction and take off all the tape.. Also, need you shake the cartridge side to side to looosen up the toner... If that does not work.... You know what to do
Apr 07, 2010 | Sharp AL 1631 Copier
Sharp AR-M237
please clean the sensor and feed the paper
Mar 17, 2010 | Kyocera CopyStar CS-3060 Black and White...
Sharp copies AL1655 CS: what does error code (L1-00) mean
check scanner home position sensor & scanner motor
Jan 13, 2010 | Office Equipment & Supplies
Copier says ready to print. when button is
you will require to check several things like ink toners alignments and settings try resetting the wholesystem. top of all there may be some software problem try reinstalling the softwares if it is connected to computer
Jul 21, 2009 | Sharp AL-1655CS Laser Printer
Woodpecker noise II
A technician should look at this. There could be a gear going bad on it. Ive see a fee cases where the drum gets bad and cant turn any more.
Are there error codes on the screen?
Make sure the right door where the bypass tray is closed all the way.
Jun 16, 2008 | Sharp AL 1631 Copier
Upper feeder tray copies work fine, main feeder does not print, makes odd noise
Found the answer.
Problem:
Wide blank area on Lead Edge, or Misregistration possibly accompanied by noise. The noise may be described as a clicking, buzzing noise while making copies. The noise may stop for short periods while making copies. Cause:
The registration Sol. pawl is not capturing the clutch to keep it from turning. This is caused by the Registration Sol. return spring being out of position, or when installing the Main Drive Assy., the pawl is "trapped" in the actuated position. Solution: Free the Spring, by rotating it. Ensure that the Pawl moves freely in and out, and engages with the clutch.
Apr 02, 2008 | Sharp AL 1631 Copier
Al1655
i need the driver of my 1655 cs for xp , where i found, www.sharpusa.com no,
Feb 12, 2008 | Sharp AL-1655CS Laser Printer
Sharp AL-1655CS Copier Logo
73 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
