Question about Oasis Industrial Strength Dehumidifier
Ice on dehumidifier OASIS 3800HG
There is a blcok of ice on the back of the deshumidifier. ít's a problem of lack of gas?? Which gas use the dehumidifier?
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
What does E1 mean on the display of my dehumidifier
follow this steps and fix it. God bless you
E1 error code : Deshumidifier
indicates generally an issue with rh sensor on the back of the control. However, at this time we would like to gather further information relating to the application if possible.
Oct 29, 2013 | Haier DE65EK 65 Pints eco-Friendly...
Esco Oasis 2700L dehumidifier ices up. Is there a filter to be cleaned and if so, how to I get to it?
The most common cause of frost and ice buildup on a dehumidifier is because the unit is operating in temperatures that are too cold. Many dehumidifiers are not equipped to run at temperatures below 65 degrees Fahrenheit.
To fix this problem, Position the dehumidifier in an area where there is at least one foot of clearance around the unit in order to allow for proper air circulation during its operation. Close all windows, doors and other outside openings to make sure your unit isn't attempting to remove moisture from areas outside of the immediate room. Determine the temperature of the room by checking a nearby thermostat or by using a hand-held thermometer.
Check the filter for dirt and buildup. Unplug the unit from the electrical source and check the filter by opening the filter compartment. If the filter is dirty, it will restrict airflow through the unit and lead to freezing. Soleus recommends lightly vacuuming the surface of the filter to remove dirt. The filter also can be washed in warm water if it is extremely dirty. Once clean, place the filter back in its compartment. Allow for the ice to melt and then restart your dehumidifier.
Jul 03, 2011 | Dehumidifiers
The unit is freezing up on the filter screen. Approximately half the screen is coated in about a 1/4" of ice after 24 hours of operation. The water that is removed falls into the bucket instead of...
could be a couple of areas to check temperature set to low filter plugged unit low on charge fan motor needs to be replaced or fuse or breaker blown or off
Jun 08, 2011 | Whirlpool AD50USS Dehumidifier
The coil keeps iceing up
is the filter and coil clean? In high humidity the unit mat run too long and freeze. Try turning the humidistat a little lower
Aug 21, 2010 | Oasis Dehumidifiers
How use this deshumidifiers, people in the room or not?
People in the room will not bother this unit nor will the unit bother the people...
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 01, 2010 | Dehumidifiers
Settings? how do I set the temp on Danby DDR601
Since the DDR601 is a deshumidifier, there's no temperature settings. It's built for humidity control, not for temperature control.
Aug 13, 2009 | Danby DDR601 Dehumidifier
Why does the filter in the back ice over after awhile of running
ice is a result of low refrigerant charge or lack of airflow across the coil
Jul 30, 2009 | Dehumidifiers
Icing on back of dehumidifier
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Mar 25, 2009 | Goldstar DH3010B Dehumidifier
Danby water tank
this part is the indicator to activate the interlock that stop your deshumidifier when water tank is full. It activate a switch on the top right of the placeholder of the tank. when the switch is relaesed it tells you either thank is not there or full and light a red signal. the center of the wheel should be back the pivot. if the pivot is broken, i don't suggest you to forced the switch activated unless you use the direct drain, or you might have water spilled over a full bucket! Martin!
Aug 04, 2006 | Danby DDR451 Dehumidifier
Oasis Industrial Strength Dehumidifier Logo
247 people viewed this question
Top Oasis Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you an Oasis Dehumidifier Expert? Answer questions, earn points and help others
