Question about Maytag MMC5000 Microwave Oven
Microwave oven will not heat food
Goldstar over-the-ranger MV1502W
  • veraeatmon Jul 01, 2008
    Thank you the repair said the same things
  • Anonymous Mar 18, 2014
    there is caked on grease and food
MAYTAG MICROWAVE OVEN MDL 1153AAB WILL NOT HEAT FOOD
Posted on Mar 16, 2009
  • Maytag Master
  • 9,098 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
While I don't have the exact manual, I have a similar manual which I have uploaded to our site. It may help you or a friend with diagnosis. It's here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 29, 2008
How can I get a copy of the installation instructions for the LG MV1502W over the range microwave oven? I can find the user manual, but not the installation instructions.
Try ManualsLib here: https://www.manualslib.com/manual/638625/Goldstar-Mv1502b.html . This is the Goldstar MV1502W (or MV1502B). Since the LG MV1502B manual refers to the unit as the Goldstar MV1502, this is probably the same model.
I hope this helps.
Feb 17, 2017 | LG Microwave Ovens
Goldstar mv1502w
no just a fuse inside
Nov 24, 2013 | Microwave Ovens
I have a Goldstar Microwave: Goldstar Model # MV1502W/01 Serial # 703TAHQO1537 Manufactured March 2007 The microwave won't power on at all. what troubleshooting can I do?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 26, 2011 | Goldstar MV-1501 Microwave Oven
I have an old Goldstar microwave (MV1140T) that just stopped heating. The fan still works but the food won't heat up. What can I do?
The problem is caused by a bad magnetron, "common problem" or the high voltage capacitor and diode, all three work together to heat the food. The repair cost for parts and labor will be high enough to consider buying a new microwave oven.
Feb 23, 2011 | Goldstar MV-1501 Microwave Oven
MV1502W/B It just stopped heating. It turns on.
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts (including a fuse and the diodes), then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Aug 16, 2010 | Goldstar MV-1501 Microwave Oven
I have a Goldstar microwave and it is not heating up the food. It is running the lights are on the tray is rotating but the food is not heating up at all.
Basic Microwave Oven TroubleshootingTips
heatman101//./.
Jun 24, 2010 | Goldstar MV-1526 Microwave Oven
Food will not heat everything else is working
If it does not heat, with all other functions working, the problem lies with the magnetron circuit. The magnetron is the part that makes the microwaves to heat the food. Typically, the magnetron fails and shorts out. Symptoms when this occurs is a loud hum from the oven and does not heat the food. The replacement magnetron costs are close to the price of a new microwave oven, so it rarely pays to have it fixed.
Feb 16, 2010 | Goldstar Microwave Ovens
Microwave doesnt heat food
Microwave not heating problems are the result of one or more of the following problems -
1) Bad fuse
2) Bad diode
3) Bad capacitor
4) Bad transformer
5) Bad magnetron.
You would need to have special equipment to test the 2nd, 3rd, and 5th items.
Reply back of any other questions/help you may need.
Feb 03, 2009 | Whirlpool GH8155XM Microwave Oven
Microwave problem turntable spinning after replacing door switches
Make sure the switches are connected EXACTLY as the original ones, maybe one was connected incorrectly. It also can be the controller board.
Feb 16, 2008 | Whirlpool MH2155XPS Microwave Oven
Maytag MMC5000 Microwave Oven Logo
274 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
