Question about Wintergreen (P4M800C24X) PC Desktop
NEW 320 GIG HD CAN I USE SUPPORT CD TO INSTALL XP HOME ON IT?
As far as I know the support CD is the only disc that originally came with the PC. Just really need to know if I can use that CD to install XP Home on the new drive and then reuse the original HD for some other purpose like data storage. I know the support CD has all the device drivers, but is it also used as the XP Home recovery disc as well. Thanks, BNG in Texas.
  • 1 more comment
  • lppena Jun 26, 2008
    Oh, my second issue would be how easy it would be to make a disc image of my original HD on to the new HD and attach it as my primary HD and then put away the original HD as a backup drive if the support CD can not be used to do a clean install of XP Home on the new 320 gig HD.
    Thanks for your reply, but 2 of my previous PC's did include recovery versions for both Windows 98 and Windows ME both were Hewlett Packard models.. Therefore, your first statement is basically incorrect about never including a Microsoft disc with the computer. This PC should be no different, so you basically haven't answered my original question. Can the support CD be used to do a clean XP Home reinstall on my new HD? On the second question it mostly depends on the first question being doable as if I do screw things up I need a way to minimally recovery the original operating system. I do appreciate your response, but I need a more knowledable repondse.
    I've explored the support CD and found references to Microsoft files on it, but I'm uncertain about whether or not theses files are the XP Home recovery files I need to reinstall the OS in the event that I need to reinstall my computers original OS again. Does anyone out there actually own another Wintergreen PM800 and have a clue as to whether or not the XP Home recovery files are actually on the support CD?
    President:
  • Wintergreen Master
  • 1,314 Answers
1. Computers often come with microsoft discs; all the ones I build do as well as dells, sonys, averatecs, and a host of others.
2. Use a program like acronis to make an image of the hard drive to your new drive. Then you can boot off of the new drive no problem.
3. I do not know if your support CD has the operating system on it or not. The easiest thing for you to do is point #2, image the drive over to the new one and then you can boot off of it.
Posted on Jun 26, 2008
    President:
  • 357 Answers
Hi there
1) A computer never comes with a Microsoft Disk so you will not be able to recover you Windows XP Home, unfortunately the best thing to do is just buy the Genuine disk from Microsoft, and the reason why i say unfortunately is because these disks turn out very expensive.
2) What you need to do is set up your new hdd as a slave and then copy everything from your main hdd to your new hdd then shut down your pc and take both the master and the slave hdd's out and then change your new hdd to be the master hdd and you should be set! All you need to do then is connect it back to your pc and start it up. Please also remember to give this solution a good rating.
Kind regards - Hope this helps you!
Dustin Ellse
Hi there , i have an acer travelmate 6592 laptop , the original 80 gig hard drive crashed , and i dont have the recovery disc , the hidden partition wont re install either , i have bought a new 320 gig...
You cannot get the full 320Gb capacity because the BIOS can only support a maximum of 127Gb.
You only hope is a BIOS firmware upgrade that can support 320Gb. Check out the Acer WEB site to see if a BIOS upgrade will solve your problem.
OTHERWISE
Install a 127Gb hard drive in your Acer and put the 320Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive because it is not affected by the BIOS limitation.
Jun 13, 2011 | Computers & Internet
Windows xp professional won't complete setup.
Its an hardware error. You have tech support with MS since you bought the new XP try to see if they can tell you what is the hardware its complaining about.
Feb 26, 2010 | Microsoft Windows XP Professional With...
I am installing a new WD3200AAJB HD in a Dell Dimension 4550. This is the only HD in the system. There are also 2 CD drives and a floppy drive. I used the jumper settings the drive came with which pins...
Reinstall your old hard drive as master and install the new hard drive as slave.
Here is the link to jumper settings from Westrn Digital;
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1540&p_created=#jumper
If you've got your jumper settings wrong and installed your os on the 127 GB section of the 320 GB Hard drive and you change jumper settings and then you have problems you may need to reinstall the old hard drive as master and the new hard drive as slave. Reformat the new hard drive as 320 GB, and as a bootable drive. You can either do a disk copy from old to new or reinstall your os on the 320 GB drive. Please let me know how this goes. You can get to me @ johnkariotisjr91741@yahoo.com
Oct 25, 2009 | Dell Dimension 4550 PC Desktop
Windows XP background loads but no icons/task manager/start menu
well copying the files may be the problem! for instance you need a recovery cd or dvd if you made one and use that to reinstall ur OS like the day you bought it!
try making or getting a windows installer disc then either install ur original OS like home or professinal or use the repair feature that shoud install all the drivers and .dll file you need
Aug 27, 2009 | Microsoft Windows XP Home Edition
HP Compac NX5000 wont load XP Home on new hard drive
This situation leads me to believe that the CD or DVD drive is faulty,,or the install disc you are using is scratched or dirty.
Try cleaning the disc and begin again.
Another option is to take the hard drive out and using a 2.5 to 3.5 inch HD adapter ,,plug into a desktop PC as a slave.
And copy your WinXp cd onto a partition on your laptop HD.
Then using a Win98Se floppy boot disc you can access the winXP and install from there.
Nov 12, 2008 | HP Compaq nx5000 Notebook
Reinstalled windows xp profesional after hd crash. Did not have the original acer aspie 5100 recovery disc to install. Now the cd dvd rom is not recognised by laptop
if you originally had Vista on then the bios is updated from the older XP bios and wont see the drive, check here for bios downloads, or put Vista back on.
If you have a full XP disc you will need to do a full format and installation, do not use somebody elses restore disc as it's not the complete windows that you will need.
Aug 31, 2008 | Acer Computers & Internet
Trying to install new Ultra-ATA hard drive on my six year old SysteMax Tiger PC.My BIOS recognizes the hard drive,but Windows XP will not install for some reason.I've been told to re-install the...
update your system bios first. as far as parition magic's related error.. if you were you delete the parition and recreate it, you should be ok. What's the error message you receive when you try to install windows on it?
Jun 17, 2008 | Systemax Computers & Internet
Trying to use old HD
You need to install Windows. You'll have to buy a Windows XP Home (preferably) installation CD with Certificate of Authenticity and 25-digit registration key. You'll put the CD in the drive and boot the machine, it should boot off the CD and start the Windows XP installation process. Once that is done, your computer should run perfectly.
Jun 10, 2008 | E-Machines T2682 (000002965) PC Desktop
O S disc, Toshiba L35-S1054
No unfortunately XP home and XP media edition are different but not completely. The only difference is the entertainment factor like TV control and live recording and pausing , viewing photos etc and media center is considered to be a bit more secure than XP home but i find this just a wrong perception of people as i also have XP home and also had media center, makes no difference at all regarding security but yes if u want much more features or facilities as far as entertainment is considered media center edition is far more good than XP home.......
IF U INSTALL XP HOME THAT DOES NOT MEAN U INSTALLED XP MEDIA CENTER
Now there are 2 ways to solve ur problem
1. Either get a NEW disc from microsoft or any computer shop for media center and then install it.
OR
2. Install XP home on your system and then try to put the CD for media center , it will update XP to media center . In this way u will get the media center back and u will also not lose any previous stored data.
NOTE: In both the above cases u will have to get the CD for Media center......
Wat matters is losing the data that is already stored on your system.
BUT AGAIN I WOULD LIKE TO REMIND HERE IS THAT INSTALLING XP HOME WILL NOT GET BACK U TO MEDIA CENTER AS THEY ARE DIFFERENT BUT IT MAKES NOT DIFFERENCE WHETHER IT IS XP HOME OR MEDIA CENTER AS ONLY DIFFERENCE IS ENTERTAINMENT>>> IN THE WORLD THERE ARE MORE PEOPLE USING XP HOME THAN MEDIA CENTER>>>
I would recommend to cont. with XP home
Feb 19, 2008 | Computers & Internet
Original boot discs
I'm afraid, you can't install XP home over XP Pro; it could be done the other way around. you'll have to  backup your important files then format your drive and restart from scratch.
if you have 2 partitionon in your HD e.g C: and D:
you can copy all your important files in the D:\ drive and just format and install XP home in the C:\ drive.
Oct 28, 2007 | Acer Aspire 3000 Notebook
Wintergreen (P4M800C24X) PC Desktop Logo
51 people viewed this question
Top Wintergreen Computers & Internet Experts
David Payne
David Payne
Are you a Wintergreen Computer and Internet Expert? Answer questions, earn points and help others
