Question about Canon PIXMA MP780 All-In-One InkJet Printer
Re; Response for faxing problem
What is a hard reset?
My canon mp780 fax will not fax all my pages. one page my go threw while i refax and none will go. my error report shows ng for result.what does that mean??
Posted on Jul 09, 2008
I'm not sure what type of machine it is but I think it's a Brother. It has a separate fax line and isn't connected to a computer or network or anything like that. The machine will receive faxes fine but...
Are you working with a line over VOIP like Vonage? If so faxes can be hard to send and receive because of line condition.
Also, if you have DSL make sure that you have the proper line conditioners in place so you have good line condition.
If those aren't a problem then contact your phone provider to discuss the issue.
Mar 03, 2011 | Office Equipment & Supplies
Faxing
did u try to do a hard reset to clear this error?
if nt try it please
Jun 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Our fax machine just stopped faxing!! We keep getting the response that it's busy!! What could this indicate!!
bad modem or bad phone line...reset mach by menu * 2864 01 will reset machine. 99 exits diags
Nov 08, 2010 | Brother Office Equipment & Supplies
Fax Machine just died on me.
Look for a fuse and see if it is blown. Also check for a reset button. Are you sure the wall outlet is providing power?
Jan 31, 2009 | Office Equipment & Supplies
Beeping sound when try to fax. report says busy/no response
hi,
check it out weather it is in fax mode not in phone mode
Dec 15, 2008 | Brother IntelliFAX 2800 Laser Fax
Hp-laser jet 3055
hi, just try to reset the memory the of fax. i think that's the cause that's you cant send and recieved fax..i hope it would help you...
Oct 20, 2008 | HP LaserJet 3055 All-In-One Printer
No dial tone/message window says printing
Use Hard Reset to reset machine after power loss. See today's post.
Jul 02, 2008 | HP 1020 Plain Paper Thermal transfer Fax
GETTING COM AS 634 INSTEAD OF OK STATUS WHAT IS THE REASON
This is what the code means:
Redial was not successful due to no response from the called station or wrong number dialed.
Note
: If busy tone was not detected, the machine will only redial once.
So the your fax machine is getting no response from the fax you're calling.
Hope that helps...
Jun 13, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
HP X4270 5 YEARS OLD. CONTROL PANEL READS HAXMNTE KHONKY B --NOT FAX,COPY,SCAN CONTROL PANEL DOES NOT RESPONSE TO BUTTONS. i UNINSTALLED AND THE SAME PROBLEM OCCURS WHEN I REINSTALLED WITH THE CD. NEW...
Step 1 Remove the power suppply from the back of the printer...
Step 2 press and hold the stop/clear button (the button with the red X)..
Step 3 Insrt the power supply into the back of the printer...keep holdin the button...
Step 4 The printer would display the language as english
Step 5 Select the desired settings
Vola ...ur printer should be back to normal...
Else contact on 1-800-332-4120
May 02, 2008 | Office Equipment & Supplies
I can't fax! BUSY/NO RESPONSE
go into menu
go to fax settings
find send
click auto not manual, please make sure that when you push the hook key you hear a dial tone. always reminder that every fax machine has the capablitiy of either dial or tone. now if everything is set up properly  the problem will be in the tx portion of the board. if you can link up with somebody close to you and try to transmit back and fourth that will let you know if it is their problem or your. it may not be your problem.
Oct 21, 2007 | Brother IntelliFAX 1840C Plain Paper...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
261 people viewed this question
old marine
old marine
