Question about Apple iPod MA446LL/A MP3 Player
Apple ipod black
I think there is a problem where you put in the headphones. i have to hold the headphones at the spot where the jack and headphones meet. Is there a solution to this problem And I have changed the headphones it doesn't work with all of them thank you
  • vatrell Jun 26, 2008
    when i completely insert my ipod headphones or i hold them where the jack and headphones meet i still cant hear and i have used different headphones so the problem is the ipod
  • loulabell59 Jun 26, 2008
    my ipod is the first video ipod issued and its a lot weathered! wellis it worth a repair or a replacement?
The middle botton doesnt work on my 80 gig ipod
Posted on Jun 26, 2008
  • 137 Answers
It's a hardware issue. hopefully you purchased the extended warranty because it has to be repaired. my 30 GB iPod has the same problem and any headphone I use has the same issue. How old is the iPod?
  • nsindian
    nsindian Jun 26, 2008
    I'd replace it and make sure to get the extended warranty, in case.
Speakers not working
Try restoring the ipod or cleaning the ipod jack first. Usually it is caused by the dirt accumulated inside the jack. The ipod thinks there is a headphone inserted even when there is none.
Feb 19, 2014 | Apple iPod Touch 8GB 32GB 64GB 3rd...
Four weeks ago I bought an iPod Touch 32GB. After listening to my iPod on an external speaker I tried using the headphone and the sound is just too low. I thought my headphone was damaged but I tried it on...
Sounds like plugging the external speakers in has damage the spot were the headphones go in. If this is under warranty that bring it to apple store.
Jan 19, 2011 | Apple iPod touch
My 1st generation 8gb ipod touch wont play any sound via the headphones. I have tried multiple sets of headphones but all tono avail. I have tried restore via iTunes, I have tried to hold down power...
It sounds like you have a headphone jack failure. Have you had any difficulty inserting the headset? Was there any event that happened when headphones were in and working.
May 03, 2017 | Apple iPod touch 1st Generation (8 GB) MP3...
Music only comes from the left headphone
This is a common problem with the headphone jack - if you google "ipod 30Gb headphone jack repair" there are both places that will replace the jack and places that will sell you the new "ribbon" connector and hold switch and jack (it's all one unit). If you're comfortable opening the iPod and have a TINY (#000) jeweler's philips head screwdriver you can replace the unit with no soldering. It helps if you have patience and small fingers and good light; you'll have to fasten the ribbon connector carefully. I paid under $10 for my last part but I've seen the same part for $30+, so caveat emptor. For that price they should put it in for you...
Mar 29, 2010 | Apple iPod MA446LL/A MP3 Player
Black apple screen
Connect the ipod to your desktop computer Rear USB port and charge it for at least 4 to 8 hrs
Then try to reset the ipod
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Jul 15, 2008 | Apple iPod MA446LL/A MP3 Player
IPod MA146LL/A no sound
You should check and see if the headphone jack is broke or not. That sometimes accounts for the reason why sound won't come out.
Go here to see about replacing/fixing a broken headphone jack:
http://store.ifixipodsfast.com/ipod-parts-/-installation/ipod-video/ipod-video-headphone-jack-/-hold-switch/prod_69.html
May 10, 2008 | Apple iPod MA446LL/A MP3 Player
Sound out of one speaker only
I think it's probably a damaged audio jack. If you're still in warranty, get it off to Apple. If not, you've got 3 choices;
1. Attempt to fix it yourself. I managed to get stereo again by opening the ipod up and inserting a staple in the bottom of the jack, to fit between the headphone and the ipod's audio input. This took some fiddling around, using tweezers, and will probably not last long if I take it out somewhere. I might attempt removing the audio jack and seeing if I can bend the metal connects for the right audio channel so they touch the headphone cable again. An alternative to this method would be to put some cardboard in the audio jack socket and adjusting it so that it brings the hardphones back into contact. Someone did this and posted the results on their blog, but I forgot the URL...
2. Buy a new audio jack and replace it yourself. There's an ipod repair wiki out there, and several of the replacement jack suppliers have detailed instructions. It's about 40 UK pounds for the replacement though....
3. Get someone to repair it. Expensive, about 60 quid, but perhaps worth it if you're scared of further damaging your precious beast.
Note though that there have also been issues with software updates and audio output, search the apple discussion boards for more details...
Nov 08, 2007 | Apple iPod MA446LL/A MP3 Player
Problems with Headphone and USB plugs
I share the same problem - I'm worried it's due to routine wear-and-tear on the jacks, so the connections are no longer solid. I hate to think I need to get it serviced for this. Usually buying a new cable has worked, but that gets expensive too... Anyone have a fix??
May 06, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
44 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
