MSI Wind U120-020US Netbook Logo
Posted on Dec 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reset password cmos msi wind netbook u100 - MSI Wind U120-020US Netbook
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2031
Points
When i turn on my net book there is a password and i cant remember the password and i need it reset how would i reset it?
Anonymous
Level 2:
Scholar:
  • Expert 98 Answers
  • Posted on Dec 03, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
98
Questions
0
Helped
32782
Points
298
How to reset bios password?
find the location of the coin cell battery for your laptop. Remove it for 5 minutes or more . Replace it and reboot your computer.
1helpful
Bios locked forgot password
To reset the BIOS password read the information from this link.
In case of your MSI laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
I have msi u100 netbook.i lost bios password. how can i format my netbook?
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
I cant install my bluetooth in msi u100
Not all MSI Winds were sold with bluetooth. If bluetooth doesn't switch via fn + f11 then the hardware isn't present even if the software is installed.
Cannot remove msi u100 bios password.
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
2helpful
I have a msi u100 series netbook.my problem am having is with the bios password i remove the battery and wait a minute but the password still remains does this module have a jumper?
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
My msi u100 mini laptop won't reboot
Hello..
When you encounter this kind of problem you need to check directly to the HDD. This is an HDD problem which the cable are not good. Try to change the SATA or IDE cable. Or you may reset the CMOS jumper you can see the CMOS jumper near the CMOS battery. Good luck!
6helpful
3answers
U100 msi wind netbook, webcam problems
You should be able to start the device with a default windows driver. Open windows explorer. Look at the left FOLDER pane. Under My Computer you should see USB Video device. Select it to start the webcam with default drivers. This confirms the device as working. Now, loading the correct drivers will give proper resolutions and other device-specific features of the device.
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
