Getting CDO.Message.1 (0x80040213) The transport failed to connect to the server in asp page. plz. help
  • 24 Answers
SOURCE: Every time i turn on computer i keep getting an
It appears that you are trying to automatically update a program or driver. You have to locate the app or device and try deleting it.
Posted on Oct 19, 2009
Hi ..I can't connect to my yahoo messnger..And it says here's the problem..hope u can help me.. Checking virtual IP servers... [VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED] [VIP Raw]...
can you get an internet connection?
click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in yahoo.com)
check your firewall settings make sure yahoo is allowed
click start type in cmd press enter
you should have a black screen you are in dos mode
type in ipconfig
you should see all of your connection details
type in your default gateway adress into your browser (search engine)
hope this helps you
Oct 18, 2011 | Yahoo Messenger
Nikon FotoShare
I would suggest reinstalling the application. Let me know how it goes.
Mar 17, 2008 | Cameras
Messenger is showing the following message Checking login servers... [Login] Connecting to login server 124.108.97.193... [Login] TIMEOUT I also cannot get into my emails, it says the link may be...
Connecting to login server 124.108.97.193... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12029' *** [Login] FAILED This are my problems i cant log in my yahoo account and i cant open the yahoo page please help me thanks....
Oct 01, 2010 | Yahoo Messenger
The server will not fully power down. It attempts to (sputters)and then the fans just run and the lights on the front just flicker, no alarms. AMI Megaplex 2 mother board 2816 MB ram DB 960 2...
We would issue remote shutdown commands and sometimes
the system wouldn't completely shutdown and it went into the undead state.
Anyone connected to the machine still worked but no new connections allowed
and no access to the console. Found out from Microsoft the shutdown command
isn't the greatest and so I wrote a VBScript that has resolved the issue.
This isn't the greatest code in the world, I should correct it so the values
are all defined in the variables section but use it if you find value to it.
Option Explicit
' Program - RemoteReboot.vbs '
' Author - Paul Bergson '
' Date Written - 08/15/07 '
' Description - Is a more drastic remote reboot '
Dim OpSysSet
Dim OpSys
Dim strComputer
Dim iMsg
Dim iConf
Dim Flds
Dim strSubject
Dim strHTML
on error resume next
strComputer = WScript.Arguments.Item(0) 'Get server name
If WScript.Arguments.Count = 1 Then
Set OpSysSet = GetObject("winmgmts:{(Shutdown)}\\" _
& strComputer _
& "\root\cimv2").ExecQuery("select * from Win32_OperatingSystem where
Primary=true")
For Each OpSys in OpSysSet
OpSys.Reboot()
Next
Else
Wscript.Echo "Server Name required. Reboot operation Aborted!"
Wscript.Quit
End If
'Send out an e-mail on the reboot
set imsg = createobject("cdo.message")
set iconf = createobject("cdo.configuration")
Set Flds = iConf.Fields
With Flds
..Item("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
..Item("http://schemas.microsoft.com/cdo/configuration/smtpserver") =
"Yoursmtp.YourDomain.com"
..Update
End With
strHTML = strComputer & " has been automatically rebooted by YourServerName"
_
& " on " & FormatDateTime(Date(),1) & ", " & FormatDateTime(Time(),3)
strSubject = strComputer & " has been rebooted"
With iMsg
Set .Configuration = iConf
..To = "Notification Email@YourDomain.com" ' Destination e-mail address
..From = "ServerName@YourDomain.com"
..Subject = strSubject
..HTMLBody = strHTML
..Send
End With
set imsg = Nothing
set iconf = Nothing
Jan 27, 2010 | AMI MegaPlex II 9U (S657820000000) Server
Error message
That's just a standard " Page failed to load " error message. Nothing's wrong with your computer.
I hope this helps.
Oct 14, 2009 | Dell Inspiron 530s Desktop Computer
Server system hanging
system hanging when i connect server system
Mar 12, 2009 | Computers & Internet
Sending mails using asp.net
ASP.net is a programming environment, not a freaking e-mail MTA. If you knew why the transport connect failed, that would give you a clue how to fix your program. I imagine you are not; however, programming. Are you trying to use a .Net Mail program?
Stop calling for Sir, too; smart girls might hook you up, and then you'll be behind even if you can send e-mail. Which I also suspect; really, you should not.
Mar 10, 2008 | Microsoft Windows XP Home Edition
I try to connect PSP, but I get "connection with the server timed out"
Well I can help. do you know what Internet service provider you have?
Feb 11, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
174 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
