Question about Samsung Televison & Video
Samsung flat screen wide
Screen has developed a greenish hue around peoples hair on TV and squiggly lines in back ground. What can this be? TV is only one to two years old (not sure).
Thank you,
Josi
You need to move your speakers away from the tv. turn the tv off and on about 10 times. it has a degauser built into the tv it will take the green out. also a vacume cleaner can cause this to happen. as long as it is a tube type tv.
Posted on Jun 26, 2008
How do I keep my samsung ln46c550j1f in wide screen picture size? Every time I switch it to wide screen it turns back 16.9 screen size every hour or so.
Hi
Your TV is set to "Store Demo Mode", this means people can play with them in the shop and it always returns back to a normal picture every hour or so. Here's how to fix it :)
Press Source - select TV.
Press Menu - Select the Setup menu (its the picture of the cog on the left 4th picture down)
Select "Plug and Play"... the default pin is 0 0 0 0
Select your language
Make sure "HOME USE" has a yellow box around it.
Select your country.
Scan in your channels if you need to?
Fixed :)
By the way... I have the same tv ;)
Michael
Aug 24, 2011 | Televison & Video
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
Jul 24, 2011 | Toshiba REGZA 52RV530U LCD TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
I have a PS42A410 Samsung that has developed a 10cm black line
Your control board needs replaced most likely. Does it work fine on a cool morning when you first turn it on, then develops the line when it warms up? Good indication it is the control board.
Feb 23, 2010 | Samsung PS42A410 42 in. HD-Ready Plasma TV
Blue horizontal line on my lcd tv
change the channel up 7 times and go back to the station
Nov 14, 2009 | Televison & Video
Green hue
Unplug the TV from the wall and plug it back after 45-60s should fix the problem. However, it will come back from time to time so the same procedure will reset the video board. You'd want to upgrade the firmware on the ATSC tuner as well because old firmware was built before the final standard and when the TV goes digital in June 2009, it wreak havoc on all older HD TV. Go to hitachi website and download new FW for your TV. Copy the FW to an SD card and follow procedure from Hitachi to upgrade. It works wonder for my TV after the upgrade.
Sep 22, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Wavy coloured lines on the screen all the time & hue
Tv repairman. the green picture tube has an intermittent short in it. This is an expensive fix.
Mar 30, 2009 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
138 people viewed this question
Henry  Thomas
Henry Thomas
