Question about LaCie (300728U) 250 GB Hard Drive
Data recovery hello, I am a soldier in Iraq and have a LaCie Big Ethernet 1TB drive that according to LaCie has a bad interface board and is out of warranty. I have the ability to hook up to the drives as a USB drive and my system recognizes the drive but it dosen't show up in my explorer list. I don't think the drives are bad because the system just stopped working one day. Dose LaCie have a special software on their interface board that will only allow you to access the data through the software? Regards, SSG Tewell Alpha 2-150 FA Q-West Base Complex, Iraq APO AE 09351 email: jeffery.tewell@us.army.mil
  • 734 Answers
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Posted on Dec 12, 2008
My iMac does not recognize the Lacie 1tb big disk extreme external hard drive. No icon appears.
the first step will be to verify your power supply. When it is plugged to the wall power outlet, it should be silent (no hissing or high pitch noise) and the green light should be on on the power supply.. If it is not the case, replacing it might solve your problems.
Second step is to verify if it is an interface problem. Try using a different port on the drive.
If no success, start Disk Utility and look to the left if you have any mention of a drive of 1TB. If you do, the partition of your drive might be corrupted. You can try running First Aid from Disk utility if its available, else you will need to try a partition repair software or a Data recovery program.
There are a few available that you can get a free copy to see if the data is available before you buy.
Regards,
Jan 07, 2011 | LaCie Big Disk Extreme with Triple...
Help is it possibol to upgrade lacie big disk extreme 500gb to 1tb or 2tb. thanks. FC
Maybe. If the current disk-drive has an IDE interface, then your 500GB disk-drive already is the largest IDE disk-drive ever produced. Or, if the current disk-drive has a SATA interface, then the sky (or the thickness of your wallet) is the limit.
Nov 15, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
LaCie BIG HD suddenly invisible to my Mac
from the description either th drive or the 1394 logic board has failed. Try having the technicians at you local PC shop swap the actual hard drive from the Lacie enclosure into a new enclosure and test it. If it works, buy the enclosure and you're back in business, if it oesn't and you need the data on the drive comment back with your Country, State & City and I'll refer you to a good Data recovery specialist in your region.
Hop this helps FixYa,
Chris
Jun 27, 2009 | LaCie Big Disk Extreme with Triple...
LaCie Big Disk Extreme 1TB Hard Drive - continuous beep, no power
Hi, Lacie isn't very forthcoming with beep codes but it definitely means one of the two. You can try moving the hard drive into a new enclosure, if it works it was the enclosure, if not the HDD. Hate to say it but warranty on these drives is a moot point the moment unique data is stored on them as you can't even diagnose the problem properly without voiding it and no drive manufacturer will waranty data. If you have no unique data and it's under warranty, send it back. If you have unique data on it that you value, take it to a local computer store and have them move the drive to a new external enclosure and test it. If it works, you're done. If it doesn't, you've confirmed that the HDD is faulty and you will need the help of a data recovery Pro. If the latter is the case, reply by commenting here with your location (country, state city) and I'll recommend a closeby facility for you. Chris
Jun 04, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Trouble seeing my lacie drive possible mounting issue
It sounds like the RAID controller in the LAcie drive may have failed. When this happens generally the data on the drive is left intact but you will require a new casing for the drives and the help of a data recovery pro to get the files off before you can re-initialize the set. Unfortunately all the good free/cheap utilities work only on single drives so you will need the help of a pro with high level software and additional equipment to retrieve the files.
If you are in North America I would recommend Armor-IT Data Recovery, they're listed in the FixYa service database for most US states. If you're outside North America, post your location and I will help you find an appropriate service.
Chris
May 28, 2009 | LaCie Big Disk Extreme with Triple...
I've using my "LaCie Big Disk with Triple Interface" over four years I guess and recently it was keeping making clicking sounds and was turning on and off my itself a lot. Then now it doesn't turn on. I've...
If the hard drive(s) have been clicking for a long time, and rebooting randomly for some time, I'm leaning toward the drive(s) being dead. You'll need to do a data recovery on the drive or restore from backup. You should get a new hard drive. Clicking is bad.
May 05, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
Lacie hadr drive problem
Data recovery software.
Check this link:
http://www.software.com/view/8384/72/easeus-data-recovery-wizard-professional-4-x
Feb 06, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
LaCie (300728U) 250 GB Hard Drive Logo
181 people viewed this question
Top LaCie Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
